SSR SuperStar Questions
Hey folks, recently scored 6 of these, in varying conditions. 4 are useable, 2 need repair. Stupid lightweight, like 8lbs. I "believe" they are 13x8s, so.
Can they fit an un-flared car?
What tire size?
They have NO beads...unsafe??
  • Replies 49
It would all depend on the offset. I have 8s on the rears of my 4dr and I could almost tuck an 8 in the front. I have a bit of negative camber and 185/50/15s on them.
Also, since they are 13s, you're going to have a hard time clearing anything but stock 510 brakes.
i was just thinking about that i personally wouldnt want to run stretch with no bead
bolt them up and see how far they stick out past the fenders but i look at them and they seem like they would be just about perfect for a flared car
Guest Rick-rat
Well, what do you call that under the fresca can and on the other side? If they did not have a bead they would be flat all the way accross from outside to outside of the wheel, arte you talking about the small ridges on the wheels on the top?
Guest Rick-rat
I don't wish to argue, I would use them the ouitside is where the tire makes contact with the rims allowing them to hold air. Take one of thse rims to a tire shop and tell them they don't have a bead, see how long before they stop laughing. The inside you think is missing is no big deal on those wheels, just a difference in the way they are made
