engine bay clean out
datson4life
  • Replies 916
Did u keep the smog canister? I jumped the lines right before it
I connected to the line after I bent it up close to the master brake cylinder, as I have dual SUs, then where it is supposed to connect into the vacuum separator inside the cover in front of the driverside rear fender well, I connected a longer hose that went straight to the fitting on the top front of the tank.
You can see the two hoses that are on the left side of this photo below, the far left hose comes off the fuel pressure regulator and is connected to that vapor emissions line that goes to that separator system in the box.
