wayno Posted June 13, 2014 Report Share Posted June 13, 2014 It looks like a 520/521 frame with the shock tower cut off, and I have done this conversion, as far as I know you will not be able to align this without modifying the upper or lower control arms, also castor is going to be an issue unless you know what to do. If it was a bolt on, everyone would do it, but it's not a bolt on, and there are issues to contend with, I should know, I did this 10 years ago, the first 2 years were fun, not knowing when the driverside upper control arm bolts are going to break is always fun, especially when the frontend drops out from under you when you just touch the brakes. Do yourself a favor, drill out the upper control arm mount bolt holes and tap them for the 720 mount bolts, the 520/521 mount bolts cannot take the stress. If you have any issues with alignment or driving, let me know, I have done all this, I won't do it again, I just mount the 520/521 cab on the 720 frame now. 1 Quote Link to comment
140ypower Posted June 13, 2014 Author Report Share Posted June 13, 2014 Nice front suspension improvement. Why are you putting a heavy axle in back? Unsprung weight degrades smooth ride and handling. because in Finland the shaft may only be replaced to match the original load-bearing capacity and 521 axle weight is 1300kg :( i think before that nissan s14 rear... Do yourself a favor, drill out the upper control arm mount bolt holes and tap them for the 720 mount bolts, the 520/521 mount bolts cannot take the stress. If you have any issues with alignment or driving, let me know, I have done all this, I won't do it again, I just mount the 520/521 cab on the 720 frame now. hmm, have you photos somewhere? :) I understood a little of what you mean .. :) Quote Link to comment
wayno Posted June 14, 2014 Report Share Posted June 14, 2014 because in Finland the shaft may only be replaced to match the original load-bearing capacity and 521 axle weight is 1300kg :( i think before that nissan s14 rear... hmm, have you photos somewhere? :) I understood a little of what you mean .. :) When you bolted the 720 upper control arm to your 520/521 frame, you noticed how much bigger the mount holes were. correct? The 720 mount bolts are larger/stronger than the 520/521 bolts, so when you used the 521 bolts to hold the 720 upper control arms in place on your 520/521 frame, what did you do to take the slop out, did you sleeve the holes? Quote Link to comment
140ypower Posted June 14, 2014 Author Report Share Posted June 14, 2014 When you bolted the 720 upper control arm to your 520/521 frame, you noticed how much bigger the mount holes were. correct? The 720 mount bolts are larger/stronger than the 520/521 bolts, so when you used the 521 bolts to hold the 720 upper control arms in place on your 520/521 frame, what did you do to take the slop out, did you sleeve the holes? aa, now i get it :) I noticed that the holes are loose. I thought that I bolts bushings. and then drill the holes get bigger as you said. is these Other things to consider? thanks :thumbup: Quote Link to comment
140ypower Posted June 21, 2014 Author Report Share Posted June 21, 2014 today i do my 520. cabin is lots of welding. but this is ready and that another. 1 Quote Link to comment
140ypower Posted June 30, 2014 Author Report Share Posted June 30, 2014 I bought a couple of cars last week Quote Link to comment
Willdatsun Posted July 8, 2014 Report Share Posted July 8, 2014 Nice work Do you want a nice pickup bed for your 520? :) Also I have parts for the 910. Quote Link to comment
140ypower Posted July 10, 2014 Author Report Share Posted July 10, 2014 Nice work Do you want a nice pickup bed for your 520? :) Also I have parts for the 910. i have one :D but have you 520 front turn signal, and like this mask and light? i just have that twin light mask.. 910 is good, but bumbers chrome list is not... :) Quote Link to comment
140ypower Posted September 27, 2014 Author Report Share Posted September 27, 2014 bouth boys and new brakes to my 521 :) Quote Link to comment
140ypower Posted November 9, 2014 Author Report Share Posted November 9, 2014 my 521 go to winter sleep... Quote Link to comment
banzai510(hainz) Posted November 10, 2014 Report Share Posted November 10, 2014 I see a orange 510 in the back!!!!!!!!!!!! Quote Link to comment
wayno Posted November 11, 2014 Report Share Posted November 11, 2014 I see what looks like a W53 head, and another one that has had work done on the intake runners. Quote Link to comment
140ypower Posted November 12, 2014 Author Report Share Posted November 12, 2014 yes i have 521x2, 520, 520 van, 510, b310, 910 :D i hav sr20det that 510 ;) yes thei are bouth w53 head :) i have little revined that ;) Quote Link to comment
mrbigtanker Posted November 13, 2014 Report Share Posted November 13, 2014 Looks like every Datsun in Finland is at your house. Good job.. :thumbup: 1 Quote Link to comment
140ypower Posted November 14, 2014 Author Report Share Posted November 14, 2014 every good-looking I thought to collect one ;) Quote Link to comment
140ypower Posted November 16, 2014 Author Report Share Posted November 16, 2014 now i have one toyota B) 2 Quote Link to comment
140ypower Posted November 17, 2014 Author Report Share Posted November 17, 2014 fixing head today 1 Quote Link to comment
140ypower Posted November 30, 2014 Author Report Share Posted November 30, 2014 yes, its fixed now 1 Quote Link to comment
Charlie69 Posted November 30, 2014 Report Share Posted November 30, 2014 Good Grief I hope you have enough heads. Are Datsun parts hard to get in Finland? Quote Link to comment
wayno Posted November 30, 2014 Report Share Posted November 30, 2014 With all them heads, why did you even need to fix that one? 1 Quote Link to comment
140ypower Posted December 1, 2014 Author Report Share Posted December 1, 2014 520, 521 are not to be found anywhere ... just luck if you will be receiving. all others may find occasionally.I have a 4 L engine parts so mekein all heads come in normal operation. and bring the repair did not pay the $ 5, so it was worth it. 1 Quote Link to comment
140ypower Posted April 4, 2015 Author Report Share Posted April 4, 2015 my hilux get today friend 1 Quote Link to comment
Ed-datsun521 Posted April 5, 2015 Report Share Posted April 5, 2015 Damm dude are u drunk in vodka when u buy all these cars :) ! Nice ! 1 Quote Link to comment
140ypower Posted July 26, 2015 Author Report Share Posted July 26, 2015 i have nice weekend, i get new 521 :) maybe i little drunk, but not vodka :D 5 Quote Link to comment
