Doty (Deal of the year)
skyblue
  • Replies 2k
Went to check out an L20B today with busta nut in Livermore. checked it out asked some questions, pulled out money bought it. then as we are getting the chain bolted up i look at the block stamp and it read L16. i was like, woa woa woa, this is not an L20B. i called the guy over to show him. he was not aware of the stamp and thought since it had a W58 head that made the block an L20B. needless to say he was a Datsun noob. It's a good thing i saw that, cause it would have sucked to see it once we got it to the shop. dissapointed cause i was gettng all stoked on having an L20B. but oh well the search continues. looks like i might just rebuild the L16 and call it good for Canby.
well I was thinkin when the car cuts the tire down the center its to tall of tire to weak of shocks and springs or to lo
wait a minute should have thought of this before
to soft springs or to soft shocks
NEVER TO LOW
yea ive had them in the past and have been very happy with them. Travel is pretty minimal. spring are still settling too so it gets lower day by day. lol.
yea i has no bump stops in there right now. I know i know, bad bad. i will put some in soon.
In due time my friend.
Put her on the rack today and checked out the resonator job. Not. Very happy. They added some stupid curved pipe that now makes it hang low and look ridiculous.
B473455F-5FDF-470A-A9DE-DD633353D798_zps
Hanging low
65B1CE39-D574-4577-BF3D-75FE800B4BA8_zps
Also put bump stops on
378F102A-5E4B-480C-A006-9ED6406F814C_zps
19115299-6BC1-4159-ADEF-3C5E4B98D4B4_zps
And rotated camber plates to get more caster for less rub when turning, apparently.
D664C4B5-6AFB-4283-B85E-59DC7A4834DB_zps
Another angle
C1EC9BF0-7204-4160-8CD3-7B59A70DDE1A_zps
Engine shot
5F9C2735-E5C3-4D6A-A037-A151EB2F8521_zps
Also decided to clean up trans cover.
F20FFAA3-1AF4-4FCC-8077-5CCD8509CE05_zps
A quick sandblast
6EBE9774-8A0A-4D71-98E9-CA30F51F86D1_zps
06207F2B-065B-4840-89E2-0F3CC132A8C4_zps
D4C4B8D1-F706-45CA-A76D-A724B576FF37_zps
521 trans cover screws cleaned up and cleared.
30B266C2-9D45-4C5F-A5C4-1D4AB0566142_zps
Found a metal tokico brake master cover in my trunk that I bought at canby last year. Put it on the clutch master instead if the black plastic one.
C4B4170A-9565-496F-A3DD-A202FEFC55E2_zps
Lastly cleaned up trunk
75F32C2B-3EB0-41B0-B84B-5E5FEBBF56C6_zps
Looks to me you can build another 510 from that trunk,Oh and clean it to.lol
Looking good.
Yea that's the plan. Lol. That is clean!
did you put these this way on purpose for more caster
if not they are installed incorrectly
they should slide 90 degrees to the fender
Yes randy that's what I did. More caster. But it didn't help much with the rubbing. I might just flip it back.
Adding caster by moving the top of the strut back will not help with the rubbing (I'm guessing it's hitting the foot well).  If you add caster by shortening the T/C rods though, it will help with your rubbing problem.
I really love original paint 510's (especially the greens that Datsun offered).  The cars looking good.  It would be rad to see you out at some autocrosses!
Oh really? Ok that's good to know. The rubbing is mostly on the fender lip when I turn the wheel all the way. One of my goals is to take her out autocrossing. Tyler gave me the info.
