KhausticMess Posted July 27, 2012 Report Share Posted July 27, 2012 So yeah my rusted ass muffler finally fell off on my way home from a job interview, atleast I start a new job on monday. Gonna be saving up for headers and new muffler and whatnot. It came off right about where the cab ends, you can't see it in the photo. Z22 and I already have a Weber Carb. Should I spend the extra money on Doug Thorley headers? Any recommendations on muffler? Anything else I need ? I am slowly replacing things as I can afford them with upgrades any additional info you guys need that would help with recommendations? I also have a small leak you can see it in the photo, should I be worried ? ...and a pic so you can laugh. Quote Link to comment
KhausticMess Posted July 27, 2012 Author Report Share Posted July 27, 2012 I was expecting this to happen saw how bad the pipe was a couple weeks ago, but no money to fix it before it happened, Didn't notice the leak when I was looking at it then. Quote Link to comment
Alec 720 Posted July 27, 2012 Report Share Posted July 27, 2012 hmm Yeah I cut my muffler system out, and want to get a new system after I have more money :devil: And with that leak you don't need to worry about it because its like at the end of the pipe anyway, I can't figure out the 2 pipes :confused: Quote Link to comment
KhausticMess Posted July 27, 2012 Author Report Share Posted July 27, 2012 It busted where the clamp held it up and the weight of that busted it by the cab on the way home. the leak is the wet spot on the rear axle ...? not sure what else to call that part its where the driveline meets up with the axle. I still have everything but its all so rusted that it's pointless to salvage. Truck was used on a small farm for most of its life and not very well taken care of. Quote Link to comment
Alec 720 Posted July 27, 2012 Report Share Posted July 27, 2012 Ohh a Differential leak... I would check your fluid level, it looks like its leaking from your plug so I would make sure its tight. Quote Link to comment
KhausticMess Posted July 27, 2012 Author Report Share Posted July 27, 2012 Yeah sorry I know shit about vehicles, never had a car I liked enough to learn until I bought this truck. Quote Link to comment
Alec 720 Posted July 27, 2012 Report Share Posted July 27, 2012 Your Differential should still be good because it probably still has "enough" fluid, but I would still check the fluid level. Quote Link to comment
ggzilla Posted July 27, 2012 Report Share Posted July 27, 2012 I wouldn't put headers on. The stock manifold is a free-flowing cast header design Just put a new muffler on. Quote Link to comment
KhausticMess Posted August 8, 2012 Author Report Share Posted August 8, 2012 Does anyone know what size the plug is on the differential mines leaking, you can see it in the photo and I can't find anything that fits it. Quote Link to comment
datzenmike Posted August 8, 2012 Report Share Posted August 8, 2012 It's designed to use a 1/2 ratchet or Johnson bar (without socket on it) The bottom one is for draining it and it has a magnet on it to collect chips and filings. If you have never changed the oil it's time you did. For now remove the one half way up to check the level. Reach in and you should be easily able to touch the oil with the tip of your little finger. It should be up level with the hole opening. Should I spend the extra money on Doug Thorley headers? Any recommendations on muffler? Anything else I need ? I am slowly replacing things as I can afford them with upgrades any additional info you guys need that would help with recommendations? I also have a small leak you can see it in the photo, should I be worried ? ...and a pic so you can laugh. Gawd no don't waste a penny on a header. Headers are noisy. Sure at first they sound cool but it wears off quick and then it's just a noisy pain in the ass to have and no way to tone it down. Worst of all you paid for it to be this way. You might gain 3-4 hp (not really enough to feel) above 4,000 RPMs (where you don't drive much) which works out to $50 per hp. A poor return on investment. Unless you spend the bucks and get ceramic coatings it's going to rust and it isn't going to last for ever. Just look at the pipe in your picture. Now go look at that cast iron manifold on the engine. It's over 30 years old and look just like the day it was driven off the line. Headers come loose, don't always fit right, they can leak, and they have more surface area so radiate more heat under the hood and floor. Instead spend the money on a good exhaust pipe and muffler that will last you. Have a system custom bent using a pipe that is 1/4" larger diameter and fits a larger than stock muffler. Or get a stock system if cheaper, you won't notice the difference anyway. Quote Link to comment
Ranman72 Posted August 8, 2012 Report Share Posted August 8, 2012 It's designed to use a 1/2 ratchet or Johnson bar (without socket on it) The bottom one is for draining it and it has a magnet on it to collect chips and filings. If you have never changed the oil it's time you did. For now remove the one half way up to check the level. Reach in and you should be easily able to touch the oil with the tip of your little finger. It should be up level with the hole opening. do it on level ground too Quote Link to comment
ggzilla Posted August 8, 2012 Report Share Posted August 8, 2012 do you mean breaker bar? That's what I use. Johnson bar is what the hand-brake lever is. This also is called a Johnson bar: Quote Link to comment
datzenmike Posted August 8, 2012 Report Share Posted August 8, 2012 Sure, breaker bar. Quote Link to comment
KhausticMess Posted August 8, 2012 Author Report Share Posted August 8, 2012 hmm, I tried a 1/2" and it was a rather sloppy fit. Thanks for the advice and additional info about checking the fluid its helpful since I haven't done it before. Quote Link to comment
datzenmike Posted August 8, 2012 Report Share Posted August 8, 2012 It may have oily dirt packed in there. Quote Link to comment
banzai510(hainz) Posted August 8, 2012 Report Share Posted August 8, 2012 After getting up there in age myself I would just up size the pipe to 2in and run a quiet muffler. Use aluminized pipe not the cheaper steel stuff. Maybe gewt a Dynomax turbo muffler. or a cheery bomb turbo 2 muffler with a smal case. Headers dont even worry about it. If you have to save up already your already on the edge of being broke. Worry about more pressing issue whith your truck. Its old it will break soon enough,save the money for that Quote Link to comment
Alec 720 Posted August 8, 2012 Report Share Posted August 8, 2012 12mm not many nuts are in standard size on the Datsuns most of the size nuts are 10mm 12mm 14mm 16mm Quote Link to comment
KhausticMess Posted August 9, 2012 Author Report Share Posted August 9, 2012 It definetely looked to be a 1/2" breaker bar would work its just a simple square inset slot on the head, but its larger than 1/2 by a few milimeters and way smaller than 3/4" I'm assuming metric of some size, just haven't been paid yet at my new job soon as I get paid I'm gonna tackle the leak, possibly the muffler, but I may wait on that. Quote Link to comment
ggzilla Posted August 9, 2012 Report Share Posted August 9, 2012 yes, you are correct. We all use 1/2 drive wrenches with no problems, but if you want you can buy the special tool from Nissan or from Snap-on. Quote Link to comment
datzenmike Posted August 9, 2012 Report Share Posted August 9, 2012 Yup, when money is tight you have to prioritize. A ticket for faulty muffler is counter productive. Safety related things like brakes, tires and steering come first. I've removed many a diff or tranny bung using a 1/2" ratchet so it does come off. Push in hard when turning. I also have a short piece of pipe to slip over the handle to increase leverage. Quote Link to comment
I'm BLUE Posted August 9, 2012 Report Share Posted August 9, 2012 Yup, when money is tight you have to prioritize. A ticket for faulty muffler is counter productive. Safety related things like brakes, tires and steering come first. I've removed many a diff or tranny bung using a 1/2" ratchet so it does come off. Push in hard when turning. I also have a short piece of pipe to slip over the handle to increase leverage. Yeah totally agree Quote Link to comment
