datzenmike Posted June 23, 2012 Report Share Posted June 23, 2012 Remote igniter unit for a EI dizzy. The only cars with that before '78 were the California ones. Starting Sept '74 the California 710s had the EI remote igniter. Quote Link to comment
TENDRIL Posted June 23, 2012 Report Share Posted June 23, 2012 skib this is dope, respectively i think you will have moar funs with this, just looking at the fucked dime while i was at james' was very sad and demotivational, congrats on this and so the s12 is out? i would like to make it down there for a weekend of shenanigans and check this thing out in person! Quote Link to comment
INDY510 Posted June 23, 2012 Report Share Posted June 23, 2012 and a round of "wtf is this?" There's a stock relay box right there ...... I can check where the green plug goes Quote Link to comment
bonvo Posted June 23, 2012 Report Share Posted June 23, 2012 indy is right thats where the voltage regulator and shit lives Quote Link to comment
Skib Posted June 23, 2012 Author Report Share Posted June 23, 2012 Remote igniter unit for a EI dizzy. The only cars with that before '78 were the California ones. Starting Sept '74 the California 710s had the EI remote igniter. so what dizzy does that run? and what is it need/not needed for? skib this is dope, respectively i think you will have moar funs with this, just looking at the fucked dime while i was at james' was very sad and demotivational, congrats on this and so the s12 is out? i would like to make it down there for a weekend of shenanigans and check this thing out in person! yeah that thing.......... lol that poor prison raped dime... lol Iv been on the look out for a good S12 for like 2 years :rofl: itl come to me one of these days Quote Link to comment
Skib Posted June 23, 2012 Author Report Share Posted June 23, 2012 indy is right thats where the voltage regulator and shit lives iv got the other end of the harness with those plugs on it but havent looked at it yet. wtf can I delete out of all the shit? idk what half of it is on a 710 Quote Link to comment
datzenmike Posted June 23, 2012 Report Share Posted June 23, 2012 The remote igniter box is the same as the matchbox just larger and not miniaturized. All Datsuns had remote igniter ignitions in '78 and all switched to the matchbox in '79. You can run a points coil as long as you find a ballast resister... or a matchbox... but if you can find a remote igniter dizzy it will plug right in. Quote Link to comment
datzenmike Posted June 23, 2012 Report Share Posted June 23, 2012 iv got the other end of the harness with those plugs on it but havent looked at it yet. wtf can I delete out of all the shit? idk what half of it is on a 710 It all fits behind a black plastic cover. Volt regulator, headlight relay, ignition relay, choke heater relay... the headlight wiring harness and the engine harness plugs into this as well as the fusible links . Quote Link to comment
TENDRIL Posted June 23, 2012 Report Share Posted June 23, 2012 that thing.......... lol that poor prison raped dime... yaaaaaeeeeeees that thing muaaaaaahahahahah Quote Link to comment
RedBanner Posted June 23, 2012 Report Share Posted June 23, 2012 Well, every thing is realy tied together , it would be realy hard to start ripping the right ones out. I thin, the key would be tucking it away out of sight. Did the 510 steering wheel hub fit? Thought the splines/shaft size was different, im going down to pull my wheel and mic it now lolol Quote Link to comment
Skib Posted June 23, 2012 Author Report Share Posted June 23, 2012 It all fits behind a black plastic cover. Volt regulator, headlight relay, ignition relay, choke heater relay... the headlight wiring harness and the engine harness plugs into this as well. . deff gotta loose the volt regulator and choke relay dont need that shit :rofl: Quote Link to comment
Skib Posted June 23, 2012 Author Report Share Posted June 23, 2012 yeah the 510 hub fit fine. it sticks out a bit father on the 710 shaft tho so I think Im going to have to mod it a bit to get it to return the turn signals Quote Link to comment
RedBanner Posted June 23, 2012 Report Share Posted June 23, 2012 Oh snap, my box is metal, the car harness plugs fit in the face and the washer bottle covers the front. Quote Link to comment
Skib Posted June 23, 2012 Author Report Share Posted June 23, 2012 not sure if I have that box/cover :P ill have to check Quote Link to comment
RedBanner Posted June 23, 2012 Report Share Posted June 23, 2012 it is the same! Looks like longer roll pins might work. Quote Link to comment
RedBanner Posted June 23, 2012 Report Share Posted June 23, 2012 Theres a pretty good 74 wiring diagram pdf in the elec section, phones to dumb to drop it here lol. Quote Link to comment
Will Posted June 23, 2012 Report Share Posted June 23, 2012 The box under the seat is the starter interlock. It is a device that wouldn't let the car start if the seatbelts weren't buckled. It's probably already been disconnected - everyone hated them at the time, so that's why they were only in cars from 1974 Quote Link to comment
Skib Posted June 24, 2012 Author Report Share Posted June 24, 2012 floors all POR15ed took parts from both dashes (theres a 2 door sedan here too) to make one nice one. my gauge surround had had holes drilled in it for switches and such. nice and clean even got the DZ push button installed dash that was in the coupe had been upholstered at some point so I did a quick repair on the pad from the sedan, not perfect but itl do for now. Quote Link to comment
TENDRIL Posted June 24, 2012 Report Share Posted June 24, 2012 very clean skib, what did you use to fill the cracks? Quote Link to comment
Skib Posted June 24, 2012 Author Report Share Posted June 24, 2012 I cut down the volcanoes and then fill them with bondoglass and then a spread of bondo to smooth it out. I just did a quicky job on it so I sprayed it with a textured under coating to hide the imperfections. later Ill glass a new pad for it. Quote Link to comment
converted_to_datsun Posted June 24, 2012 Report Share Posted June 24, 2012 Wow dude you make progress fast on your car. Too bad I'll never see it up here in oregon Quote Link to comment
datzenmike Posted June 24, 2012 Report Share Posted June 24, 2012 SKIB! Can you take pictures of the back of the tach and how it's wired into the car harness, please. I have one but have the non tach dash at present. When I put it in I don't want to make a mistake with it. Quote Link to comment
Skib Posted June 24, 2012 Author Report Share Posted June 24, 2012 Wow dude you make progress fast on your car. Too bad I'll never see it up here in oregon Ill be moving back to PDX before the end of the year and DDing it SKIB! Can you take pictures of the back of the tach and how it's wired into the car harness, please. I have one but have the non tach dash at present. When I put it in I don't want to make a mistake with it. no prob :cool: Quote Link to comment
datzenmike Posted June 24, 2012 Report Share Posted June 24, 2012 :thumbup: :thumbup: :thumbup: Quote Link to comment
Draynor Posted June 24, 2012 Report Share Posted June 24, 2012 I like this! :thumbup: Figure out a color yet?!?!? Quote Link to comment
