rayven14 Posted March 22, 2012 Report Share Posted March 22, 2012 What am I missing? As a result I can't get the motor far forward enough without stresssing the motor mounts ...one of them tore because the motor is 1/2 or 3/4 inch from lining up properly. So, the question is: are the oil pans different from the L16/18, motor mounts to the block, crossmembers? 1 Quote Link to comment
Guest 510kamikazifreak Posted March 22, 2012 Report Share Posted March 22, 2012 Didnt change the oil pan/pick up to the L16/18 one? This is a must 1 Quote Link to comment
rayven14 Posted March 22, 2012 Author Report Share Posted March 22, 2012 Hey 510, I hate to sound like a dumb sh** but ...What do I need to do? use the stock L16/18 or use the L20 one. Im not sure what the hell is on there right now but I guess its the wrong one. I hate the fact that Ive got it all nice and painted, installed and looking good, now I probably gotta pull it all apart, paint the new pan etc etc.... ARRRGHHHHH!!!!! Quote Link to comment
strang3majik Posted March 22, 2012 Report Share Posted March 22, 2012 Use the l16 oil pan and engine mounts. I was told you had to use the oil pickup...but they were exactly the same for me. Quote Link to comment
rayven14 Posted March 22, 2012 Author Report Share Posted March 22, 2012 Got it!!! You boys Rock!!!!! Quote Link to comment
banzai510(hainz) Posted March 22, 2012 Report Share Posted March 22, 2012 use 510 pan. and use the 510 motor mounts. 510 are ez to install the motor. keep all the mounts loose and should go right in 1 Quote Link to comment
rayven14 Posted March 22, 2012 Author Report Share Posted March 22, 2012 Anybody got an oil pan and motor mounts? Quote Link to comment
banzai510(hainz) Posted March 22, 2012 Report Share Posted March 22, 2012 wheres the 510 oilpan and the mounts that should be with the car? take some photos Quote Link to comment
hobbes_the_cat Posted March 22, 2012 Report Share Posted March 22, 2012 Anybody got an oil pan and motor mounts? I have a pan and pick up. no mounts tho. Quote Link to comment
rayven14 Posted March 22, 2012 Author Report Share Posted March 22, 2012 Hobbes, What ya want for it, hopefully its not too much to ship Banzai, I scrapped all the L16 stuff with the idea that I wasnt gonna need it, I knew I shoulda kept the parts car a lil longer!!! Quote Link to comment
hobbes_the_cat Posted March 22, 2012 Report Share Posted March 22, 2012 $40 plus shipping. it's light so shipping shouldn't be bad, probably $10 or so, I can box and weigh it to get a better estimate. it has a dent on the bottom from the motor being set down on the floor, but wasn't leaking or anything. Quote Link to comment
banzai510(hainz) Posted March 22, 2012 Report Share Posted March 22, 2012 rayven14 , Thats a good pan with the splash divider.Not all pans have this. Now get the l16 510 motor mounts. Just to let you know Youll need to know what size flywheel you using cars that had l20s used 200mm(can use the 510 T/O bearing and sleeve) l20 in trucks had 225mm(use the 620 T/O bearing and sleeve. Quote Link to comment
Guest 510kamikazifreak Posted March 22, 2012 Report Share Posted March 22, 2012 also if I remember correctly,switch mounts on the block side for each,helps with the rubbing on the hood Quote Link to comment
rayven14 Posted March 22, 2012 Author Report Share Posted March 22, 2012 damn 40 bills for a pan, that seems kinda high! and I gosta pay for shipping GEEZZZ 510Freak, I'll look into that cause I think I might have a 1/4 inch of clearance... If that!! Quote Link to comment
hobbes_the_cat Posted March 22, 2012 Report Share Posted March 22, 2012 :rofl: If you find a cheaper one thats fine by me. look at what pick n pull charges, plus tax, plus "enviromental fees" plus, you have to pull it, plus you have to find a yard that has one. If you don't want it I will just keep it. saves me a trip to the post office. B) Quote Link to comment
jrock4224 Posted March 22, 2012 Report Share Posted March 22, 2012 I did the same thing... and my 510 l 20 pan looks about the same, i am beating mine straight as possible till now Quote Link to comment
bananahamuck Posted March 22, 2012 Report Share Posted March 22, 2012 damn 40 bills for a pan, that seems kinda high! and I gosta pay for shipping GEEZZZ And here i thought i was the biggest tightwad on here... :rofl: 1 Quote Link to comment
rayven14 Posted March 22, 2012 Author Report Share Posted March 22, 2012 LMFAO!!!! Im not a tightwad... Im frugal and I found a pan for $10 bucks! Thats not beat up... no offense Im just saying Quote Link to comment
hobbes_the_cat Posted March 23, 2012 Report Share Posted March 23, 2012 No offence taken. Im glad you found one cheap I'm always lookin for the best deal too. Its just a pain to pack up and ship things so it has to be worth my time. Quote Link to comment
hang_510 Posted March 23, 2012 Report Share Posted March 23, 2012 LMFAO!!!! Im not a tightwad... Im frugal and I found a pan for $10 bucks! Thats not beat up. didn't you throw one into the scap heap? cheap lesson ;) Quote Link to comment
Ranman72 Posted March 23, 2012 Report Share Posted March 23, 2012 I got one for 45 plus 20 for oil pick up his is cheap 10 is cheaper mine will sit on a shelf for backup before I sell it for 10 Quote Link to comment
