kdatsun610p Posted March 3, 2012 Report Share Posted March 3, 2012 So I bought a electronic distributor at napa for a 79 Datsun pick up for my 74 Datsun 610. I thought cause its the same engine it would work so I connect it to the coils and it's not giving a spark cuz I can't return it now cuz the guys at napa are dicks does any of u guys know how I'd get it to work ? Il get a pick of it up soon thanks so much Quote Link to comment
flatcat19 Posted March 3, 2012 Report Share Posted March 3, 2012 2 different kinds. Quote Link to comment
Jayden71 Posted March 3, 2012 Report Share Posted March 3, 2012 There is tons of info on here about hookin up an EI dizzy. They are pretty cake Is it a matchbox type?? Should be bein a 79 Quote Link to comment
kdatsun610p Posted March 4, 2012 Author Report Share Posted March 4, 2012 It's not match box... And where would I find a EI dizzy Quote Link to comment
laotsu Posted March 4, 2012 Report Share Posted March 4, 2012 try a junklyard. I found mine in a 720 at pick and pull. it bolts right in to a521.nevermind I didnt read closely Quote Link to comment
datzenmike Posted March 4, 2012 Report Share Posted March 4, 2012 The '79 truck WAS a matchbox. You'd better post a picture so we can see. They may have sold you something else. What do you mean it doesn't work??? It won't start? OR it has no spark? Have you checked for spark or assumed there is none because it won't fire up??? Quote Link to comment
crackerjack69 Posted March 4, 2012 Report Share Posted March 4, 2012 You say you're trying to use a '79 620 dizzy on a '74 610. But also says "since they're the same motor". So does this 610 have an l20 swapped into it, or are you trying to use an EI dizzy in a points circuit? Quote Link to comment
datzenmike Posted March 4, 2012 Report Share Posted March 4, 2012 I've got a '79 EI dizzy in my '74 and '76 710s so they do fit and work. It has to be made to work, it just doesn't drop in and go. Has to be wired this way and you need a '78 and up coil. The points coil will heat up and fry so get the right one. Quote Link to comment
kdatsun610p Posted March 4, 2012 Author Report Share Posted March 4, 2012 it looks like this Quote Link to comment
kdatsun610p Posted March 4, 2012 Author Report Share Posted March 4, 2012 The '79 truck WAS a matchbox. You'd better post a picture so we can see. They may have sold you something else. What do you mean it doesn't work??? It won't start? OR it has no spark? Have you checked for spark or assumed there is none because it won't fire up??? it has no spark i check the spark ...i put in new spark plugs and cap and coil Quote Link to comment
kdatsun610p Posted March 4, 2012 Author Report Share Posted March 4, 2012 You say you're trying to use a '79 620 dizzy on a '74 610. But also says "since they're the same motor". So does this 610 have an l20 swapped into it, or are you trying to use an EI dizzy in a points circuit? 610 has a standard L20 in it..its not a swap Quote Link to comment
datzenmike Posted March 4, 2012 Report Share Posted March 4, 2012 it looks like this That's a remote igniter only used on the '78s. It needs the remote igniter box. Quote Link to comment
kdatsun610p Posted March 4, 2012 Author Report Share Posted March 4, 2012 actually i just found this in google imgaes i think this is what i need right? with the 79 coils so it doesnt fry it. Quote Link to comment
kdatsun610p Posted March 4, 2012 Author Report Share Posted March 4, 2012 sry just saw u post that so with this wiring i still need the 79 coil? Quote Link to comment
kdatsun610p Posted March 4, 2012 Author Report Share Posted March 4, 2012 That's a remote igniter only used on the '78s. It needs the remote igniter box. sry saw u post this after i posted it Quote Link to comment
crackerjack69 Posted March 4, 2012 Report Share Posted March 4, 2012 610 has a standard L20 in it..its not a swap Ha! Stupid wikipedia says '75 for first production of L20B! Apparently they are full of it :D I run that '78 remote module dizzy in my '72 truck. Since your harness isn't wired for the stock module, you can easily use a 4-pin GM HEI module. Red dizzy wire to module terminal W, green dizzy wire to module pin G, new wire from module pin C to coil-, new wire from module pin B to coil +. Eliminate resistor, and be sure to use an EI coil. The little module mounts easily w/ 2 screws usually mount by the coil to keep wiring clean. Another thought, the new dizzy might be clocked differently than your old one. Causing rotor to not be directly under cap terminal when coil is triggered to fire. This will cause a no spark. You can put motor at TDC and look under the cap to be sure the rotor is right under the cap terminal. If it's not, you can drop the oil pump spindle and rotate a few teeth until it's clocked right. Quote Link to comment
datzenmike Posted March 4, 2012 Report Share Posted March 4, 2012 L20Bs in 610 from August '73 build date. You will need any EI coil from any model of Datsun from '78 and up. You also need the igniter box in the picture or a GM HEI module as mentioned. Quote Link to comment
kdatsun610p Posted March 4, 2012 Author Report Share Posted March 4, 2012 Do u kno where the box is located?? In th car Quote Link to comment
crackerjack69 Posted March 4, 2012 Report Share Posted March 4, 2012 Your car doesn't have the box. They were only in '78 trucks. That's why it'd be easiest to do a gm module. Othereise you gotta mount that clunky module under the hood, or get a buncha wire and make a harness so it can mount under right side of dash where it normally goes. That would suck. You can pull a gm module from a early '80 gm truck (inside the dizzy) save yourself a lot of trouble. I could ship you a stock box if you insist on keeping it nissan... Quote Link to comment
kdatsun610p Posted March 4, 2012 Author Report Share Posted March 4, 2012 Well il try looking for the gm midule at the. Junkyard today do u kno were in the truck it is if not... Do u have the wiring for the Nissan box and how much would it be for me to buy it from u Quote Link to comment
Guest 510kamikazifreak Posted March 4, 2012 Report Share Posted March 4, 2012 Just use the GM HEI module,less mess and fuss. http://community.ratsun.net/topic/17444-electronic-ignitions-for-l-motors-4-cyl/ ^ All you need to know on the how to is here Quote Link to comment
banzai510(hainz) Posted March 4, 2012 Report Share Posted March 4, 2012 I think Im goin to commit suicide!!!!!!!!!!!!! Do u have the wiring for the Nissan box ??????? didnt Datzenmike just post this up already on the GM module. Quote Link to comment
crackerjack69 Posted March 4, 2012 Report Share Posted March 4, 2012 Well il try looking for the gm midule at the. Junkyard today do u kno were in the truck it is if not... Do u have the wiring for the Nissan box and how much would it be for me to buy it from u You can find 'em on most any early 80's GM truck. Take the distributor cap off, and it's mounte inside the dizzy, like the module on a Honderp. It's really your best bet, because if you use that stock module, you'll want it inside the cab cuz it's big and ugly, and not weather proof. The GM module however, IS fairly weather proof, and is very small. Also way easier to find than the '78 Datsun module. You can buy them new as well at any parts store ( $30-$50). The modules I have are garbage to me, you could have one for the shipping cost, I just can't emphasize enough you should go the GM module route. Let me know what you figure out. Quote Link to comment
wayno Posted March 6, 2012 Report Share Posted March 6, 2012 Just go to another parts store other than the one you went to, and buy a HEI GM module, I beleave they are not that expensive, and wire it like the photo datzenmike posted. You have to know/understand where to look for them at the wrecking yards, I personally have never found one yet, I rarely find a complete distibuter in the yards, someone else always beats me there. Here is the wiring photo datzenmike published. Quote Link to comment
