El dizzy conversion??
spec-bre
Hello "Rats",
I know there must be a bunch of threads on the subject but I am having no luck. Looking for a simple "how to" on swapping my early 77 a14 points Dizzy over to the later 77/78ish El dizzy I just picked up. Need a wiring diagram.. Can anyone point me in the right direction or post up any links on the swap???
thank you in advance!!!
  • Replies 20
If you have the remote igniter type '78 cars only or '76-'78 California models the complete set up is below and includes a remote box usually found under the dash. It can be mounted anywhere that is out of the weather.
If you have a remote igniter but the box is missing you can use a GM HEI module in it's place. The wiring for it is below...GMHEIconnections.jpg
Matchbox type from '79 on.
Don't know which one you have?
Remote igniter
Matchbox dizzy.
Matchbox dizzys have a small black box on the side.... remote igniters do not...DatsunEI005Large.jpg
Thanks for the reply.
Metalmonkey, and Mike, It is a matchbox Dizzy like in the last picture. I also picked up one like in picture# 2. Out of the two which would be the better choice?
Banzai, It's for a 77 B210. I also have the 510 used in my avatar.
So the second diagram is all I need to know?
I'll search the how to section now. I was on my I-phone and having trouble trying to do a search earlier.
Thanks again guy's!!
Will an Accel coil work?? I have one just sitting in tha garage collecting dust. The stock unit is a week out at Advance. I believe it's a dual purpose coil but not 100%. I'll check after work.
If it's the standard Accel round style EL coil, should be fine. Dunno if I'd put a Super Coil on it but I'm sure people have. Just remember to upgrade and re-gap your plugs.
converting this week and have another question. is the black wire from the ignition to the current points dizzy the only wire I need to use from the factory harness?? this is what I'm gathering from the diagram.
make sure to gap the plugs .045
