wayno Posted February 23, 2013 Report Share Posted February 23, 2013 I now understand why your looking for a hood, that hood is a mess. :crying: Link to comment
TENDRIL Posted February 23, 2013 Author Report Share Posted February 23, 2013 yes it is, thats why i said i would have had too spend 10+ hrs re-shaping it , luckily i had a hood, windshield, really straight grille and front turn signals delivered to me this last week Link to comment
TENDRIL Posted February 24, 2013 Author Report Share Posted February 24, 2013 put on the 4in blocks before and after the bed is not fully in place in these pics but when i get evrything done i will be happy with it Link to comment
Charlie69 Posted February 24, 2013 Report Share Posted February 24, 2013 Great work Tendril, that has to be the worst hood I have seen yet. Link to comment
wayno Posted February 24, 2013 Report Share Posted February 24, 2013 It's coming together. :thumbup: Link to comment
TENDRIL Posted February 24, 2013 Author Report Share Posted February 24, 2013 just ordered 2 quarts or por-15 ouch!! Link to comment
TENDRIL Posted February 25, 2013 Author Report Share Posted February 25, 2013 replaced and relocated rear bed mounts today, since PO had a 2x6 under there, didn't get pics but it was done well, i just didn't want it and it kept me from lowering the bed on the frame i happy with where the bed sits now, i just have to allign it straight and mark and drill holes , for new mounts Link to comment
wayno Posted February 25, 2013 Report Share Posted February 25, 2013 I had an issue that it looks like you might have, when I dropped my box down onto the 86 720 frame, my taillight buckets hit the frame ends if it wasn't aligned correct. this is from the bottom pointing up, looks like I am going to have the shift the body again. It's looking good, leave a little room for a bit of rubber between the frame and box, otherwise it might vibrate like a drum while you drive down the road. :) Link to comment
TENDRIL Posted February 25, 2013 Author Report Share Posted February 25, 2013 yes it was/is an issue when fitting the bed lower, i haven't gone to far into it yet but it will need to be addressed Link to comment
wayno Posted February 25, 2013 Report Share Posted February 25, 2013 I forgot I was going to mention that I also had fuel tank mount issues, I had to trim one of the ribs on the underside of the box, as it was hitting the rib, actually I still have tank issues, the cab is so low it is resting on the flat part of the front of the tank, transferring a lot of noise threw the cab, not sure if I am going to lower the tank, raise the cab, or pound that part of the floor up an inch or so. Link to comment
TENDRIL Posted February 26, 2013 Author Report Share Posted February 26, 2013 worked on doors to day...omg the bondo was strong with the door from the JY, waynos door was nice and one or two spots with very small amount of bondo... Link to comment
wayno Posted February 27, 2013 Report Share Posted February 27, 2013 Are the front wheels centered in there wheel wells even though there are 2X4s holding it up? The box height looks good, it's coming together. :thumbup: Link to comment
TENDRIL Posted February 27, 2013 Author Report Share Posted February 27, 2013 and are in the same place and you can see the cab mount in the bottom right under the corner of the cab, now the cab sould go back about 2-3 in. and the front wheels should be really close to center..now realistically i can move the the cab back as far as the cooling fan allows, unless i go with an electric fan.. which im unsure what happens when you take the fan off of a clutch type water pump, can i do this and go electric fan? Link to comment
TENDRIL Posted February 27, 2013 Author Report Share Posted February 27, 2013 i looked back on page one and it looks like a bolt on clutch?, i wouldnt have any shifter issues? hmmm Link to comment
wayno Posted February 27, 2013 Report Share Posted February 27, 2013 You are only going to be able to go back so far before the front wheel starts to look wrong/out of center in the front fender well, all you can do is slide it back till the front wheel looks centered, and see what the gap looks like, you can move the box and cab a little past center(closer to each other), but there is a point when it looks strange because the wheels are not centered. As I mentioned before, you can move the rear axle forward a few inches with lowering blocks that are adjustable, but then the driveline and e-brake may need modified depending on the circumstances. Keep upthe good work, your way more motivated than I am these days. I hope the door is usable, it looked good on the truck in the wrecking yard. Link to comment
TENDRIL Posted February 27, 2013 Author Report Share Posted February 27, 2013 well i would only go as far as it takes for the the front wheels to look/be centered, the gap between the cab and box is not going to be big and im sure if its very bad ill do something about it. now which fan works better at cooling water pump fan or stock clutch fan? Link to comment
TENDRIL Posted February 28, 2013 Author Report Share Posted February 28, 2013 cab sanding!....sucks Link to comment
wayno Posted February 28, 2013 Report Share Posted February 28, 2013 well i would only go as far as it takes for the the front wheels to look/be centered, the gap between the cab and box is not going to be big and im sure if its very bad ill do something about it. now which fan works better at cooling water pump fan or stock clutch fan? I am not a good one to ask about fans, but here is my opinion. I will do whatever it takes to use a stock fan, I will trim the blades, I will cut sheet metal to mount the radiator farther forward as long as it doesn't compromise anything, I will go to extremes to use the stock fan, I will lower or raise the radiator to center it on the fan, I have done all these things I have mentioned and more, as far as picking between a clutch fan verses non clutch fan, I have not noticed a difference, although it is said that the clutch fan is quieter. My 47 chevy pickup has always ran hot since I put a rebuilt engine in it(350 V8), I use a stock metal fan on it, but I also put an electric fan on the front of the radiator, as even though I made the radiator 4 inches taller/bigger, it still will not keep that engine cool in city traffic, otherwise no matter what radiator I have used in my datsuns(J block 1300cc rad. cooling a SD25 diesel(2500cc) engine, it still has done the job, although I prefer to use the biggest radiator possible. I do use good clean radiators though, I have a lot of money in the radiators in all of my rigs, as I usually take them in to a rad. shop if there is anything that may worry me. Link to comment
TENDRIL Posted March 2, 2013 Author Report Share Posted March 2, 2013 so ive seen the champion 3 row rads on ebay are these any good? and i notice they have oil coolers build in now are those able to handle engine oil? if i get a oil filter relocation can i send it through those on the rad? Link to comment
wayno Posted March 3, 2013 Report Share Posted March 3, 2013 so ive seen the champion 3 row rads on ebay are these any good? and i notice they have oil coolers build in now are those able to handle engine oil? if i get a oil filter relocation can i send it through those on the rad? That is actually a transmission cooler in the radiator for an automatic, there are not that many older vehicles with oil coolers, my diesel engines have an oil cooler built into the side of them, but that is the only one I have seen lately. My mini has an oil cooler, but they are all aftermarket as far as I know. Link to comment
TENDRIL Posted March 3, 2013 Author Report Share Posted March 3, 2013 so it would not be able to handle the thicker sludgy oil? Link to comment
wayno Posted March 3, 2013 Report Share Posted March 3, 2013 so it would not be able to handle the thicker sludgy oil? It's just a tube going threw the lower tank where the cooler water is, it's not a mini radiator, I have always wondered if it really cooled much of anything, but I suspect it is better than nothing for the transmission. I have no idea how you would get the oil to a cooler unless you use a remote oil filter, and they are just another thing waiting to fail. Link to comment
TENDRIL Posted March 3, 2013 Author Report Share Posted March 3, 2013 ok so i will just find one without the little in/outlet Link to comment
TENDRIL Posted March 3, 2013 Author Report Share Posted March 3, 2013 now for some moar sanding and some fun test fitting oics.... 1 Link to comment
