joewood Posted February 13, 2012 Report Share Posted February 13, 2012 looking to do the disk conversion and really just wondering how good there products are. thanks Quote Link to comment
Guest Rick-rat Posted February 13, 2012 Report Share Posted February 13, 2012 I have beebani's brackets on my 620, I am very happy with them Quote Link to comment
joewood Posted February 13, 2012 Author Report Share Posted February 13, 2012 sweet so good welds and everything on the brackets? Quote Link to comment
datrat77 Posted February 13, 2012 Report Share Posted February 13, 2012 I don't know about bluehands inc but beebanis has some good reviews here. Quote Link to comment
Guest Rick-rat Posted February 13, 2012 Report Share Posted February 13, 2012 Yes good welds, very well made Quote Link to comment
Laecaon Posted February 13, 2012 Report Share Posted February 13, 2012 Bluehands is made by Mklotz, or Mike Klotz. Respected member here. I dont own a truck so cant comment on these things. Quote Link to comment
datrat77 Posted February 13, 2012 Report Share Posted February 13, 2012 Also consider..... mklotz are about 100$ more and are made for using 720 rotors. Beebanis are set up for honda rotors? Quote Link to comment
Guest Rick-rat Posted February 13, 2012 Report Share Posted February 13, 2012 With Beebani's I used Isuzu rotors, with D-21 calipers Quote Link to comment
Skib Posted February 13, 2012 Report Share Posted February 13, 2012 Mike makes very well engineered products. Quote Link to comment
DAT510 Posted February 13, 2012 Report Share Posted February 13, 2012 Yes mike is very good, just look at his belt sander thread.. http://community.ratsun.net/topic/17029-mklotz70-belt-sander-build/page__st__80 Quote Link to comment
wayno Posted February 13, 2012 Report Share Posted February 13, 2012 Fact is Mikes brackets are made for 85-86 nissan 720 hubs/rotors/calipers, easy to find, everything you need in one spot, unlike the other brackets. Mike(bluehandsinc) makes quality products with no issues. Quote Link to comment
datsunrides Posted February 13, 2012 Report Share Posted February 13, 2012 I have products from both and they are both top quality. Should have no issues with either, just depends on which way you want to go. Mark Quote Link to comment
herculesinwyoming Posted February 13, 2012 Report Share Posted February 13, 2012 beebani's brackets are awesome. i am beyond happy with them Quote Link to comment
joewood Posted February 13, 2012 Author Report Share Posted February 13, 2012 thanks for all the feed back much apreciated Quote Link to comment
mklotz70 Posted May 30, 2012 Report Share Posted May 30, 2012 just in case others come across this thread..... The biggest differences..... Mine are made to fit 14" rims. The hubs and bearings are changed. The bearings in the hubs are easy to find and really cheap. Bee's setup uses the stock hubs and bearings.....it can be hard to find the bearings, but I have a fix for that if you go with his. If you have big rims.....get Bee's....they fill up the whee much, much better. If you really want to run 14's or even stock rims.....mine are the only option......but at this point, when more will be made is up in the air. Quote Link to comment
BEEBANI Posted May 30, 2012 Report Share Posted May 30, 2012 Fact is Mikes brackets are made for 85-86 nissan 720 hubs/rotors/calipers, easy to find, everything you need in one spot, unlike the other brackets. Mike(bluehandsinc) makes quality products with no issues. Not sure I get this statement, all the parts used in my setup are readily available via junkyard or any parts store as the rotors were used on 3 different vehicles for a span of 4 years and the calipers were used on hardbodies and pathfinders for at least 10 years. Quote Link to comment
