mcmlxxxv Posted July 15, 2012 Report Share Posted July 15, 2012 holy cow !!! :o I hope you will post a video of that car , so we can hear that! This is a super nice job ! Quote Link to comment
datzenmike Posted July 15, 2012 Report Share Posted July 15, 2012 I see you didn't have the exposed part of the intake guides ground off flush with the intake port. Also won't the U-67, even if using flat tops drop the compression to 7.8 or so? Quote Link to comment
datsunaholic Posted July 15, 2012 Report Share Posted July 15, 2012 7.8 would be with stock L16 dished pistons. Flattops would be 8.7. But that assumes an unmilled head, and this one's been shaved. Plus tthe large valve heads probably increase static compression. Quote Link to comment
Dirttrack510 Posted July 15, 2012 Author Report Share Posted July 15, 2012 I see you didn't have the exposed part of the intake guides ground off flush with the intake port. Also won't the U-67, even if using flat tops drop the compression to 7.8 or so? Putting this on an L20B :D I don't know why he didn't grind the guides off, I'm guessing he didn't think it was necessary. :mellow: Quote Link to comment
