Datsy620 Posted February 3, 2012 Report Share Posted February 3, 2012 Ratsun.net is my problem solver. well anyways, i need help... AGAIN! this morning i woke up to move my datsun 620 . and my clutch didnt want to go in gear. it goes in gear when its off but when its on it doesnt want to go in gear. there's like a force that doesnt let me put it in gear and when i try to put it in reverse it grinds. please help me. i need to drive it in a couple of hours to go to work,.. thank you Quote Link to comment
INDY510 Posted February 3, 2012 Report Share Posted February 3, 2012 my clutch didnt want to go in gear. it goes in gear when its off but when its on it doesnt want to go in gear. there's like a force that doesnt let me put it in gear Mine goes into gear when it's off too ..... :rolleyes: ... .. and of course it's not going to go into gear when it's running ..... sounds like your clutch is doing absolutely nothing .... .. check the clutch master for fluid?? Quote Link to comment
Eagle_Adam Posted February 3, 2012 Report Share Posted February 3, 2012 sounds like a clutch slave issue, its connected to the side of the trans. Check the fluid leves in the resivor and try to push the piston in on the clutch slave. Im no pro but its a place to start Quote Link to comment
Datsy620 Posted February 3, 2012 Author Report Share Posted February 3, 2012 the clutch master fluid is filled Quote Link to comment
Zeusimo Posted February 3, 2012 Report Share Posted February 3, 2012 Sounds Like Something Is Wrong With Your Hydraulics Start By Bleeding Your Clutch Adjust "Play" On Foot Pedal About 1/16" Check For Leaky Slave/Master Replace If Necessary Quote Link to comment
Datsy620 Posted February 3, 2012 Author Report Share Posted February 3, 2012 @eagle_adam: imma try that right now. Quote Link to comment
INDY510 Posted February 3, 2012 Report Share Posted February 3, 2012 the clutch master fluid is filled Can you get someone to push on the clutch pedal, while you look at the slave cylinder to see if it's moving the clutch fork?? Quote Link to comment
Datsy620 Posted February 3, 2012 Author Report Share Posted February 3, 2012 soo idk wtf i just did but i kept pressing the clutch pedal i heard like cranks. and i was like o.0 oh shit.! well i kept pressingit and now my clutch goes in hear.. man..! thank you guys so much. i wouldnt be alive without ratsun. Quote Link to comment
Laecaon Posted February 3, 2012 Report Share Posted February 3, 2012 Can you get someone to push on the clutch pedal, while you look at the slave cylinder to see if it's moving the clutch fork?? I used my phone to take a video. hit record, run to pedal, pump a few times, run back, stop recording, watch video. 4 Quote Link to comment
]2eDeYe Posted February 3, 2012 Report Share Posted February 3, 2012 +1 for video idear I did that to check my steering :D Edit: Sounds like your slave cylinder is going out and you built up pressure by pumping the pedal. Quote Link to comment
Zeusimo Posted February 3, 2012 Report Share Posted February 3, 2012 That's Weird... At Least Your Problem Is Fixed? :D Check It Out When You Have Free Time So You Can Figure Out WHY. :mellow: Quote Link to comment
bananahamuck Posted February 3, 2012 Report Share Posted February 3, 2012 x3 on the video , i use my Canon point and shoot set to video...instant gratification FTW i am posting this even though your problem might be fixed it`s still a good quickie tip.. Quote Link to comment
INDY510 Posted February 3, 2012 Report Share Posted February 3, 2012 I used my phone to take a video. hit record, run to pedal, pump a few times, run back, stop recording, watch video. +1 ... :cool: .... .. . I probably would just cut a whole in the floor ..... :lol: Quote Link to comment
Eagle_Adam Posted February 3, 2012 Report Share Posted February 3, 2012 another +1 on the vid idea - do like :) Quote Link to comment
datzenmike Posted February 3, 2012 Report Share Posted February 3, 2012 2eDeYe' date='03 February 2012 - 01:55 PM' timestamp='1328306149' post='626327']+1 for video idear I did that to check my steering :D Edit: Sounds like your slave cylinder is going out and you built up pressure by pumping the pedal. Steve I would think it's the master leaking internally and not building pressure. The slave has to move or not move the pressure can't go 'nowhere'. The slave isn't leaking so has to be the master. Just like pumping the brakes when you have air in the lines. I expect this hasn't fixed this and we'll hear more about it. Quote Link to comment
]2eDeYe Posted February 3, 2012 Report Share Posted February 3, 2012 I expect you are correct :D Quote Link to comment
