Eric Posted October 31, 2011 Report Share Posted October 31, 2011 Can i swap cab's en bed's from 620's and 720's? Do the two share frames or are they completely different? Quote Link to comment
510kevin Posted October 31, 2011 Report Share Posted October 31, 2011 Iva always wondered if I could put a 620 body on a hardbody frame. I suppose it could be done, but probably not a direct bolt in deal Quote Link to comment
flatcat19 Posted October 31, 2011 Report Share Posted October 31, 2011 There's a box in the upper right hand corner that will give you answers. See it? It's right below the Street Fighter 510. Quote Link to comment
datzenmike Posted October 31, 2011 Report Share Posted October 31, 2011 Yes they are very close. Reg cab short weelbase onto reg cab short wheelbase, reg cab long wheelbase onto reg cab long wheelbase and KC onto KC frames should work. Because the long wheelbase frames are so similar I bolted my 620 KC cab to a 720 reg cab long wheelbase frame. The two front long box frame mounts had to be cut off and moved aboutr 9" to the back for the bed. Other than that it all fit just fine. Quote Link to comment
jun Posted October 31, 2011 Report Share Posted October 31, 2011 I have a 620 on a 720 4x4 chassis. I didn't do the swap, but the mounts are all really close. Quote Link to comment
wayno Posted November 1, 2011 Report Share Posted November 1, 2011 I put 521 cabs onto 720 frames, although I have never done both the cab and box, the front frame to body mounts under the radiator are exactly the right place(521 to 720), the front and back in cab mounts are no more than 2 inches off, which can be fixed with a 1X2 tube steel with a few holes made in them for bolts. It's not that difficult, just do your homework, measure everything twice. If the wheel base is to long or short, you can always modify the box, make it longer or shorter. What would be cooler than a really long 620 longbox Quote Link to comment
uberkevin Posted October 29, 2012 Report Share Posted October 29, 2012 Wayno, what year 720 did you use when putting your 521 cab on it? or are all 720 frames the same hah. Quote Link to comment
Lee R Posted October 29, 2012 Report Share Posted October 29, 2012 LOL! 1 year post in just a few days..... Quote Link to comment
