75 triumph spitfire
  • Replies 15
sorry all i have for now is shitty cell phone pics.
will it poke out of the hood?
yeah it will poke but the original hood has already been cut/ butcherd so i dont care to cut it a little more. heres a few more shitty pics (the shop has low lighting and camera sucks).
'Fraid that this will fuck the front/back weight distribution and the handling. Well we'll find out. Moar power is always good. L28 would be at least twice as much.
lol yeah just a slight bit, worse case scenario i understeer into a tree or a ditch. if anything it can be a track bitch.biggrin.gif
The L28 can look pretty cool sticking out of the hood of a car.
your car? if not know anything about it?
its known as the zoadster, apparently it was a factory lightweight roadster that someone stuck a L series in. Car was dismantled by the owner and no longer exist.
Put an oil filter on that badboy ,,, keep the dirt out :unsure: :)
Thicker sway bar , and front extra-bracing to firewall/crossmember/etc,,, on that bad-boy !!!
had to take it off for puting the engine in it hit the strut tower, ill be putting a relocation kit on it to clear. The car will be getting a full cage and bracing later on, i dont think ill survive another wreck in a vert (last one i ended up wheels up and a few broken ribs and crushed t10 vertebra)rolleyes.gif Its going to be a slow ongoing project as time and money permits, mostly money lol.
heres a few more pics no real progress as of right now, i still need to make the engine mounts. but i have started going thru the wiring of the car and its pretty bad burnt in some ares so im redoing that right now. hopefully mounts will get made this week once i get the metal.
the original ebrake will have to be removed and placed elsewhere
heres how close the original mounting locations are
cant use the stock 280 mount in any way
  • 1 year later...
  • 6 months later...
