Low620 Posted September 8, 2011 Report Share Posted September 8, 2011 Ok so I installed a match box distributor on my 620 L16, put it at tdc swap all the spark plugs wires to the new locations, put the timing gun to it started right up! With no problems... Wired it just like the write up took of the resister and hooked up the original coil +to + and - to -. Now the problem started a few days later in the morning, I go and pump the gas to start it and it starts right up has electric choke and it idles high then it will turn off! And it takes time to start it up again never did this with the points distribuor. Is this a problem that people have after changing to match box? Any help please Quote Link to comment
datzenmike Posted September 8, 2011 Report Share Posted September 8, 2011 Sounds like a coke thing. You let it warm up? Or kick the choke off too soon? If motor is still cold it's harder to start is the choke is partly warmed. Try pumpung the gas several times and try re-starting. As for the matchbox you can check for spark while cranking by putting an old plug in one of the wires and laying it on the valve cover. I think you will find lots of spark. Did you replace the coil and get rid of the ballast resistor? Last, are your wires in good shape? Dizzy cap and rotor? The matchbox puts out more voltage and if the wires are old it will try to jump to ground any where it can. Quote Link to comment
Low620 Posted September 8, 2011 Author Report Share Posted September 8, 2011 No it dies on it's own I'm not even in the car! I turn it on and walk oway to do other things ... I did remove the resister and left the stock coil.. It's starts fine it just dies in the middle of warming up.. I did kind of check for spark but I was in a hurry I took the coil wire from the center of the cap and I cranked it I dint see any spark but then I put it back in and cranked it for a few and it strated was the deal bad distributor? Quote Link to comment
racerx Posted September 8, 2011 Report Share Posted September 8, 2011 That's why I did the petronix...trying to match this with that..petronix is not that expensive.. Quote Link to comment
banzai510(hainz) Posted September 8, 2011 Report Share Posted September 8, 2011 I did remove the resister and left the stock coil.. ?????????????????????WHY??????? Ballast is removed if ueing a EI coil. You didnt use a EI coil. EI coils can handle the staright 12-14 volts This could be a major proplem. The stock point coil needs a ballast resisitor. Where is this write up? Im sure it says use a EI coil. if ballast resisitor is removed. You can make this work by reinstalling the ballast resisitor(use same coil) and hot start wire(back to stock) but put B of the matchbox to the side of ballast resisitor where the blk/wht wire goes. C is - side coil SIMPLE FIX!!!!!!!! Quote Link to comment
Low620 Posted September 8, 2011 Author Report Share Posted September 8, 2011 Or just get a EI coil and hook it up? Why would it couse it to drop spark? After I get it going there's no problem. Quote Link to comment
banzai510(hainz) Posted September 8, 2011 Report Share Posted September 8, 2011 Or just get a EI coil and hook it up? YES YOU can do that and it should have been in the instructions for that to use the EI coil if the ballast is removed. Why would it couse it to drop spark? Cause you have a point coil in there and it design to keep the current down to keep the points from arching. Once running the point coil is only seeing about 6 volts due to the fact the ballast is cutting the current in HALF. Since ballast is gone your butting double the amount of current thru the coil. I bet if you got it running again I bet the coil is very warm and is either melting the insulation or arching to ground inside. hook it up back to stock with ballast and just hook up the matchbox as I said in above post. Its cost nothing If using the EI coil hook up the 12volt ON wire with the 12volt START wire at the +side coil with B of matchbox Quote Link to comment
ggzilla Posted September 8, 2011 Report Share Posted September 8, 2011 Yes, the stock coil will get very hot w/o the ballast. When it overheats it will stop working -- this could be after a few minutes. The exact same thing will happen with pertronix. It is not specifically a problem with the matchbox. Quote Link to comment
Low620 Posted September 9, 2011 Author Report Share Posted September 9, 2011 The funny thing is that ones it gets going it won't have a problem starting at all it's just in the morning. But I'll go get a different coil Quote Link to comment
datzenmike Posted September 9, 2011 Report Share Posted September 9, 2011 First you haven't proven that the spark has stopped and that this is your problem. Next time it won't start put an old plug in one of the wires and lay it on the valve cover and crank while watching for spark. Either get an EI coil, or put your ballast resistor back on. Won't work for long like that. Quote Link to comment
Low620 Posted September 11, 2011 Author Report Share Posted September 11, 2011 Update Ok so I started it just like I had it with stock coil no resister.. Turned on then after a few min. Shut right off. Put it back to stock with resister and turn on then shut right off checked for spark of the coil and no spark on both test. So I took everything off and got the right coil for the match box distributor and checked for spark and man you can see the big difference on the spark! Plugged it in and turned on and stayed on. I guess running it with out a resister burned the coil. Quote Link to comment
ggzilla Posted September 11, 2011 Report Share Posted September 11, 2011 Congratulations. Enjoy driving it. Quote Link to comment
Low620 Posted September 12, 2011 Author Report Share Posted September 12, 2011 Back to points :( well I did all that I could with this match box distributor! It did it again it left my stranded with the new coil! No spark! I checked all ground all power and still no spark! Took it off put in all my old things and runs like a champ! Any thoughs? On how to fix the distributor? Quote Link to comment
ggzilla Posted September 12, 2011 Report Share Posted September 12, 2011 Yikes. The EI coil may burn out your points, even if you use the resistor. If it drove for a while, then stopped, you may have an intermittent loose connection. Quote Link to comment
Low620 Posted September 12, 2011 Author Report Share Posted September 12, 2011 No I took off the EI coil before putting back in the points distributor I have a problem with the match box distributor! Quote Link to comment
banzai510(hainz) Posted September 12, 2011 Report Share Posted September 12, 2011 the matchbox with EI coil should work fine. Quote Link to comment
Low620 Posted September 12, 2011 Author Report Share Posted September 12, 2011 No it shut off after a few min on. I put in the EI coil hooked it up right turned it on, and it did but then by it self turn right off.... Went it turned off I checked for spark by taking the coil wire off from the cap put it to the block and no spark at all. After a few mins. I checked again and there was spark. Hooked it back in to the cap turned it on then like clock work just turned right off. I need the truck so I put it all back to stock and runs like a champ. So I guess bad distributor? Quote Link to comment
banzai510(hainz) Posted September 12, 2011 Report Share Posted September 12, 2011 So I guess bad distributor? very possible. Most say a gorund issue on those intermidiate failures but I have never run a Matchbox. I use the Pertronix set ups and use a stock resistance coil and ballast and been happy with them Quote Link to comment
ggzilla Posted September 12, 2011 Report Share Posted September 12, 2011 Unlikely to be a bad distributor. More like a bad wire connection. Quote Link to comment
Low620 Posted September 12, 2011 Author Report Share Posted September 12, 2011 Opened the distributor up and the Stator is cracked... Will this cause the problem? Quote Link to comment
banzai510(hainz) Posted September 12, 2011 Report Share Posted September 12, 2011 Opened the distributor up and the Stator is cracked... Will this cause the problem? You think? Quote Link to comment
Low620 Posted September 13, 2011 Author Report Share Posted September 13, 2011 Any know where I can find one? Or who has one extra? Thanx Quote Link to comment
]2eDeYe Posted September 13, 2011 Report Share Posted September 13, 2011 1980 NISSAN 720 PICKUP 2.0L 1952cc L4 2BBL (H) [L20B] SOHC : Ignition : Distributor Ignition Pickup Wiki Price BECK/ARNLEY Part # 1800034 Pick-Up [Wholesaler Closeout -- 30 Day Warranty] (Only 2 Remaining) $7.23 Add to Cart ORIGINAL ENGINE MANAGEMENT Part # 6111 {#22229W5800} (Only 2 Remaining) $14.03 Add to Cart STANDARD MOTOR PRODUCTS Part # LX567 {#22229W5800} Intermotor Choose: $19.37 Add to Cart AIRTEX / WELLS Part # 4P1111 {#22229W5800, 88922475, JA146} $27.79 rockauto.com Quote Link to comment
datzenmike Posted September 13, 2011 Report Share Posted September 13, 2011 To be sure the round cam-like thing in the center is the reluctor, the ring around it is the stator on the matchbox. . Quote Link to comment
Low620 Posted September 13, 2011 Author Report Share Posted September 13, 2011 Yeah it's the stator... I took the 3 screws off then I saw a crack on the bottom side Of the stator, where the screw goes Quote Link to comment
