josh_t Posted August 5, 2011 Report Share Posted August 5, 2011 i have a 76 b210 with an a14. it is an automatic as well. i was wondering what i can do to free up some horsepower for free or cheap. i already put a free flowing exhaust on it, advanced the timing 5 degrees, and all the emissions systems are off of it. i wasnt the one who removed the emissions parts though. is there anything i can do to get a few more horses with the dch 306 carb? Quote Link to comment
jesusno2 Posted August 5, 2011 Report Share Posted August 5, 2011 get a 5speed that would be about the biggest gain for your money. Quote Link to comment
josh_t Posted August 5, 2011 Author Report Share Posted August 5, 2011 yea. i have looked into the ratios on this tranny and its geared so high, it's not even funny, An in depth top speed calculator told me it would do 53 in first, 89 in second, and 130 in third at 7500 rpm. my guess is at 80hp thats not gonna be havin much acceleration. i really want a 63 series but i dont have the money or a source for parts. is there a thread on a tranny swap? i need some kind of parts list as well as any fab work that would need to be done to fit it. Quote Link to comment
Skib Posted August 5, 2011 Report Share Posted August 5, 2011 A series isnt exactly a motor know for its HP numbers. its claim fame so to speak was gas mileage. Quote Link to comment
josh_t Posted August 5, 2011 Author Report Share Posted August 5, 2011 yea i know about those ads. but i have seen a few a series motors making low 300. i'm not really looking for much power i just want it to have approximately 100-110 at the flywheel. i'm more concerned with throttle response. i dont care so much about it being fast i just dont want it to be sluggish. Quote Link to comment
Skib Posted August 6, 2011 Report Share Posted August 6, 2011 i have seen a few a series motors making low 300 you know the rules. pics or it didnt happen. i just want it to have approximately 100-110 at the flywheel. L series swap. i just dont want it to be sluggish. 5 speed swap. Quote Link to comment
josh_t Posted August 6, 2011 Author Report Share Posted August 6, 2011 is a video good enough? i know its a turbo setup but its still low 300's http://www.youtube.com/watch?v=IXTn_rdtbhQ like i already said i need something to start with if i need to do a 5 speed swap. i know i need the 63 that is for the a series motor, the clutch, flywheel, master and slave cylinder, and pedal for the clutch. i dont know if i need a different driveshaft, or if the tunnel will need to be modified, etc. Quote Link to comment
Skib Posted August 6, 2011 Report Share Posted August 6, 2011 lol any idea how much $$$$ has been put in that motor? :lol: the best thing for the buck you can do is the tranny swap Quote Link to comment
josh_t Posted August 6, 2011 Author Report Share Posted August 6, 2011 ok. do you have any comments on the work that has been done already? possibly anything to add? i wasnt sure about the 5 degrees past stock advance (15 deg.) i didnt know if it could use more or if it was too much and possbily degrading performance. but the carb has been giving me fits so i can't really compare anything at the moment. Quote Link to comment
king bee66 Posted August 6, 2011 Report Share Posted August 6, 2011 A motors are not as cheap to soup up as youd think. the easiest fastest and cheapest would be to have your head worked on, you probably have an h72 which is open combustion. shave the head, port the intakes and stick a bigger carb on it. alot of people go with the weber 32/36, but that said youll still want a 5 speed. Quote Link to comment
datzenmike Posted August 6, 2011 Report Share Posted August 6, 2011 300hp isn't realistic, in fact it's not believable. Getting over 4 times the stock hp from any engine is insane. Hell getting 50% more is expensive than worth it. Based on the 4 speed gears for your year and the stock 155 75R 13 tires and the 3.70 rear end the top speed in the gears at say 6,500rpms is: 1st........ 33.48 2nd....... 54.21 3rd........ 85.37 4th......117.63 Switching to a 5 speed will not increase hp. In fact it will hurt performance slightly because the gears ratios are slightly wider apart. It will help with mileage if you swap in a 4.11 diff. 1st....... 34.78 2nd...... 58.44 3rd....... 89.66 4th..... 117.63 5th..... 137.75 6,500 rpms is a realistic number for a stock pushrod motor. Getting to that high in 4th or higher is very unlikely. You want about 110 hp, swap in an L20B. Find a 3.90 differential for cheap. This will increase the RPMs (and thus the hp available) at the same speed as the 3.70. A 4.11 or 4.375 would be even better but you may have to swap the entire rear axle from a 710 or something. Quote Link to comment
king bee66 Posted August 6, 2011 Report Share Posted August 6, 2011 im guessing that 1200 is from oz, they do crazy things to A series- like making an a14 an a20, because the engine swap laws prohibit them from doing alot of things Quote Link to comment
josh_t Posted August 6, 2011 Author Report Share Posted August 6, 2011 i know about those high prices. i think its 200 for a regrind cam, 1125 for pistons, and around a grand for rods. at least thats what i found. i kinda want a header because it looks so much better than the rusty pos manifold i have and it flows and sounds better but i know i need at least some new jets for that. carb would be nice. i can get one for less than 200 but i dont know about the gains i will get from it. i do have an h72 head. i have looked into all this stuff already on datsun1200's tech wiki. i'm also interested in getting a pertronix ignitior. i know it will be negligible horsepower wise but what are some things i will notice right off the bat if i get one? Quote Link to comment
Skib Posted August 6, 2011 Report Share Posted August 6, 2011 so your going to spend $1325 building the bottom end of an A motor? :rofl: just go buy a KA instead........ Quote Link to comment
josh_t Posted August 6, 2011 Author Report Share Posted August 6, 2011 i never said i wanted to build it. i was agreeing with you saying it would be more money than its worth to build it. my original post was intended to find ways to hop this motor up without much money at all. more specifically if there was anything i can do to get more power with the stock carb. (jets, modifying the vacuum secondary, etc.) Quote Link to comment
Skib Posted August 6, 2011 Report Share Posted August 6, 2011 toss on a weber and a 5 speed. those are your cheap power mods. http://datsun1200.com/modules/mediawiki/index.php?title=Manual_transmission_conversion Quote Link to comment
josh_t Posted August 6, 2011 Author Report Share Posted August 6, 2011 i got that part already. i would love to. Quote Link to comment
Z chopper Posted August 6, 2011 Report Share Posted August 6, 2011 header should help and port match the head, Quote Link to comment
josh_t Posted August 6, 2011 Author Report Share Posted August 6, 2011 header should help and port match the head, thank you. do have a possible estimation for the power gain from both of those? maybe from experience. Quote Link to comment
Z-train Posted August 6, 2011 Report Share Posted August 6, 2011 A header will actually hurt that motor in MPG's & performance. 1 Quote Link to comment
josh_t Posted August 6, 2011 Author Report Share Posted August 6, 2011 i'm not that worried about mpg. it will still get better than all my friends with chevys. would it decrease performance that much since there is practically no back pressure in my exhaust anyway? Quote Link to comment
ggzilla Posted August 6, 2011 Report Share Posted August 6, 2011 i just want it to have approximately 100-110 at the flywheel That will take around $2500 worth of performance mods to get an A14 or A15 to 100 HP. The stock heads are only good for 85 HP. Or just stick an 110HP L20B in it, no fabrication required. Fits in the B210 tunnel. Uses the stock B210 automatic driveshaft. Yes if you fit lower gears in the back, that will improve accleration across the board. The only problem with that is 3.9 gears are the lowest they used in USA. NISMO used to sell lower gears, you might find them on Craigslist or eBay from time to time. I have 4.11 and it makes a big difference compared to 3.9. NISMO had 4.8 and 4.6 and 4.3 gears. Quote Link to comment
ggzilla Posted August 6, 2011 Report Share Posted August 6, 2011 yes, the header will lessen the performance -- unless you rejet the carb to compensate. A weber 32/36 will pick up some HP if you rev it over 5,000 RPM. It's probably the biggest bang for your buck. But will only get you to 85 HP. Quote Link to comment
josh_t Posted August 6, 2011 Author Report Share Posted August 6, 2011 what happens? the heads can't flow enough for more than 85? or do they just fail? Quote Link to comment
ggzilla Posted August 6, 2011 Report Share Posted August 6, 2011 What happens? You don't get 100 HP. The stock heads only make 85 HP, and that requires a bigger carb and a more agressive camshaft. You can port the head and fit bigger valves as one part needed to get to 100 HP. Quote Link to comment
