bustedknuckles Posted August 1, 2011 Report Share Posted August 1, 2011 title pretty much says it. i did a motor swap and the engine was running fine before the swap and now when i try to start it all i get is a backfire and no start the exhaust isnt hooked up at the moment so it sounds like a shotgun going off it is coming out of the exhaust for sure why is this happening? thanks dane Quote Link to comment
Laecaon Posted August 1, 2011 Report Share Posted August 1, 2011 Set the timing yet? Quote Link to comment
bustedknuckles Posted August 1, 2011 Author Report Share Posted August 1, 2011 the timing was good when i pulled the motor and i didnt mess with it at all but i was wondering if that could be an issue but how would the timing get out of whack if i didnt mess with it? Quote Link to comment
Eagle_Adam Posted August 1, 2011 Report Share Posted August 1, 2011 its a 40 year old car - who knows how :P - but seriously check the timing and report back - hopefully with good news :D Quote Link to comment
metalmonkey47 Posted August 1, 2011 Report Share Posted August 1, 2011 Sounds like timing. Mine did this when it was retarded. (the timing, not the car :P) 1 Quote Link to comment
datzenmike Posted August 1, 2011 Report Share Posted August 1, 2011 Wires mixed up... 1342 Quote Link to comment
bustedknuckles Posted August 1, 2011 Author Report Share Posted August 1, 2011 all the plug wires are in the right order i will check the timing in a little bit and let u guys know right now this southern oregon heat is killing me thanks for the help Quote Link to comment
datsunz Posted August 1, 2011 Report Share Posted August 1, 2011 Sounds like your wires are 180 off. Quote Link to comment
Rotary510 Posted August 1, 2011 Report Share Posted August 1, 2011 wires changed, timing, car is pissed and wants to stay home cause it's too hot :cool: Quote Link to comment
racerx Posted August 1, 2011 Report Share Posted August 1, 2011 huh? so does it run now? Quote Link to comment
yello620 Posted August 2, 2011 Report Share Posted August 2, 2011 Wires mixed up... 1342 Counter-clockwise. :D Quote Link to comment
bustedknuckles Posted August 7, 2011 Author Report Share Posted August 7, 2011 checked the timing again and that is good wires are in correct order could there be a vacuum leak someplace that would cause this to happen? Quote Link to comment
datzenmike Posted August 7, 2011 Report Share Posted August 7, 2011 Yes, and severe lean condition will do this. Quote Link to comment
bustedknuckles Posted August 7, 2011 Author Report Share Posted August 7, 2011 ok thanks i will go thru the vacuum system today and check everything and i set the carb to factory specs i just do know why it would be doing this because the motor was running before i put it in my truck it has to be something stupid that im over looking i know i will feel like a jack a$$ after i figure it out thanks again for the help dont know what i would do w/o fellow datsuners Quote Link to comment
banzai510(hainz) Posted August 7, 2011 Report Share Posted August 7, 2011 when you changed the motor did you swap the whole distrisbutor assembly or just pull the dizzy out ????? and used a different dizzy pount or pedastal.????????? this should be EZ to fiz. We are not mind readers but a swap from what to what and what parts were used or changed? Like motor was running fine. If it was why change it? get more specific. Quote Link to comment
ggzilla Posted August 7, 2011 Report Share Posted August 7, 2011 Try 4-2-1-3. When it backfires trying to start, that often is the cause. Especially when swapping engines. Quote Link to comment
