l20b backfires when i try to start it
title pretty much says it. i did a motor swap and the engine was running fine before the swap and now when i try to start it all i get is a backfire and no start the exhaust isnt hooked up at the moment so it sounds like a shotgun going off it is coming out of the exhaust for sure why is this happening?
thanks dane
  • Replies 15
ok thanks i will go thru the vacuum system today and check everything and i set the carb to factory specs i just do know why it would be doing this because the motor was running before i put it in my truck it has to be something stupid that im over looking i know i will feel like a jack a$$ after i figure it out thanks again for the help dont know what i would do w/o fellow datsuners
