Michael.flee92 Posted July 24, 2011 Author Report Share Posted July 24, 2011 Yeah i know the risk... i dont own another car, but i have my motorcycle:lol: so i guess im a little prepared. I dont plan on swapping out very soon. Im just looking into the future and getting other peoples insight on my new baby. I wont drop it... Because i got the car for a steal, and im going to keep the original motor that way i can always have a back if the swap should ever fail. Im definitely not ever selling this car. I want to keep it just like my dad did with his! And work? Not too worried about it... im not going to get fired... seperated maybe, seeing how I am in the military. So money? not too worried about because if all my money goes to the car i stll have necessities like, free housing, free food, and free medical and dental. I get my paid the same time every month. So you know what that means? I get to work on my car everyday!!!! :D I also feel like the car doesnt need much... besides cosmetics, the engine runs great has no problems so far, and if i do run into problems i have money set aside for emergencies, just for the car. Quote Link to comment
Michael.flee92 Posted July 24, 2011 Author Report Share Posted July 24, 2011 Carter Boad sells a VG30.com 5 speed x memeber that needs a 280z mount with it, so the installed height is correct. somebody has the infor on that. are the door hinges good? olddatsuns.com has a fix for that also There was a kid on here Bunchy that has the same color but a wagon. he was 110% working on the car than just dropped off the forum so who knows where the car is. he paid 900$. Usually what happen people will treat it as a 900$ and most have no money to maintain a 40+ year old car is it can be alot of main. esp for a kid. Thats why I think 510 should be a 2nd car for alot of people. If its there only car they wil not be at work all thetime an then FIRED!!!!!!! Its real hard to find a minimum rust car esp up here in washington. but lots of beaters!(they fun too) So that cross member... does that mean i dont have to cut and re-weld the tranny bay for the 280z transmission? Quote Link to comment
Michael.flee92 Posted July 25, 2011 Author Report Share Posted July 25, 2011 So should i go with the bre style or the dobi style air dam? Quote Link to comment
banzai510(hainz) Posted July 25, 2011 Report Share Posted July 25, 2011 If you want to slam the car down I would go with NO AIR DAM!!!!!!!!! lower car first and decide. they usaully get abused. and hard to get jack under as its in the way. Ck Out Dillion SR20 510 it look good w/o a airdam!!!!!!! quick 510 has a 510 your color ck it out(then you wont change the color) has Panasports and is badass your car wouldnd take that much more to llook like this. Just put the coil overs in front and wheels!!!!!!! http://www.motormavens.com/2011/07/center-stage-red-hot-datsun-nickel-dime-510-nissan-bluebird/ Quote Link to comment
Michael.flee92 Posted July 27, 2011 Author Report Share Posted July 27, 2011 Okay in need of some serious help! When ever I shift into reverse it Grinds... and 1st and 2nd are hard to get into. 3rd and 4th seem to be fine. I have to literally force with all my might to get 1st into gear. My buddy said it could be my synchronizers. I was thinking it might just be my clutch, but im not sure. I might go ahead and just change out the synch's just to see what happens. But give me some thoughts on it guys. I have a stock 510 4 speed tranny. I'm going to eventually just swap out the tranny with a 5 speed, but i still need to find one, shorten my drive shaft and get a cross member. Quote Link to comment
hobbes_the_cat Posted July 27, 2011 Report Share Posted July 27, 2011 I would try changing the gear oil in the trans first before removing it. If it has low or really worn oil it could be a huge difference to put fresh lube in it. I have resurrected a few trans. with new oil before. checking the clutch adjustment can't hurt either. Quote Link to comment
Michael.flee92 Posted July 27, 2011 Author Report Share Posted July 27, 2011 Well the last owner said the clutch my need to be replaced... and that if i just press all the way down on the clutch it should be fine and should make the clutch last longer. It has a new slave cylinder on it, with new oil in it. Im not sure if it was bled properly but i can assume it was... i guess i'll try bleading it. and if that changes nothing then i can only assume i need to replace my clutch based on what i know?* And maybe the sync's as well. i'll have to check those to see if they are worn out. **Oh and to add when i step on the clutch its pretty stiff... Quote Link to comment
banzai510(hainz) Posted July 27, 2011 Report Share Posted July 27, 2011 stiff clutch is good.most likely a Roadster pressureplate I would just get a disc and a t/o bearing then. bleed clutch again and adjust the rod at the Fork/slave cylinder. why waist your time/money putting new syncros in a 4 speed????????????? 200sx 77-79 dont need to have shorten driveshafts. 280zx 5 speeds yes Quote Link to comment
Michael.flee92 Posted July 27, 2011 Author Report Share Posted July 27, 2011 Okay I'll try what you reccomended. And yes, I understand the 200sx doesn't need a shortened drive shaft... Only the 280z/zx does. Quote Link to comment
WAGON JON Posted July 27, 2011 Report Share Posted July 27, 2011 This car is WAY too nice to cut up! Get a junker to do that to. The L-20B with the L-16 oil pan and oil pickup tube is the conversion. Use a CANNON intake manifold with a 38/38 WEBER DGAS carb! Will give you some nice power in that beautiful perfect paint 4 door of yours! SERIOUSLY!!!!!! Quote Link to comment
Michael.flee92 Posted August 24, 2011 Author Report Share Posted August 24, 2011 Okay retarded question, but my buddy is parting put his 510 wagon... i was wondering are most of the cosmetic parts the same as my 4dr? I.E. -bumbers -metal trims(for the front) -headlight surrounds -Dash pad -center counsel -grill -cluster -panels for the doors(front and back) etc... I just want to be sure, since he's getting it all shipped from home. help a buddy out guys. Quote Link to comment
banzai510(hainz) Posted August 24, 2011 Report Share Posted August 24, 2011 most stuff is the same unless you have a very early model 510 there are some difference. Just compare the parts Its not hard.wagon rear doors are different form the sedan. or sell me this car for how much you paid for this and dont worry about it. Quote Link to comment
Michael.flee92 Posted August 25, 2011 Author Report Share Posted August 25, 2011 most stuff is the same unless you have a very early model 510 there are some difference. Just compare the parts Its not hard.wagon rear doors are different form the sedan. or sell me this car for how much you paid for this and dont worry about it. Quote Link to comment
Michael.flee92 Posted August 25, 2011 Author Report Share Posted August 25, 2011 Sell it!? not even if it didnt run lol im keeping this car forever. afterall its all paid off now :P Motor is running great. and I finally have my honda cb350 so i dont need to drive my baby everywhere but thanks for the heads up! Quote Link to comment
Michael.flee92 Posted August 25, 2011 Author Report Share Posted August 25, 2011 Okay I need someone to help me out... i know theres got to be a build post for the ka24 and sr20 motors in here somewhere. could someone possibly post the links, please and thank you. Quote Link to comment
H5WAGON Posted September 7, 2011 Report Share Posted September 7, 2011 Okay retarded question, but my buddy is parting put his 510 wagon... i was wondering are most of the cosmetic parts the same as my 4dr? I.E. -bumbers -metal trims(for the front) -headlight surrounds -Dash pad -center counsel -grill -cluster -panels for the doors(front and back)..... etc... I just want to be sure, since he's getting it all shipped from home. help a buddy out guys. ..NO on the back panels, Door release handle is in a different spot.!!!! Same shape though,...Doors are different also.:D You get a 5spd in that thing yet?.....make sure you get the throw out bearing sleeve, when you get the transmission.;) Quote Link to comment
Michael.flee92 Posted October 2, 2011 Author Report Share Posted October 2, 2011 So i've started all the body work... decide i will keep it orange and instead of going with an sr20 or ka24 i will be doing the l18 with the l20b peanut head. Doing all new dual su carbs. Quote Link to comment
Michael.flee92 Posted March 24, 2012 Author Report Share Posted March 24, 2012 Well i drove around with my l20 that I have swapped in for a while now but I have been rebuilding my KA24E that I got for Free. I'll post some pics of the rebuild soon. Quote Link to comment
Michael.flee92 Posted March 24, 2012 Author Report Share Posted March 24, 2012 New arias pistons for my ka24e courtesy of O&J performance for the hook up. Cleaned the head. Valve cover RePainted Before: After: New Timing kit Pics of the block will come today. also got a Camshaft coming from O&J perormance. gotta call them to see where its at then i will post pics when i get. Quote Link to comment
the510keeper Posted March 25, 2012 Report Share Posted March 25, 2012 that VC looks sweet yo Quote Link to comment
Michael.flee92 Posted March 25, 2012 Author Report Share Posted March 25, 2012 [quote name=the510keeper' timestamp='13326 42755' post='659954] that VC looks sweet yo Thanks! It's one of my favorite colors. Quote Link to comment
Michael.flee92 Posted March 26, 2012 Author Report Share Posted March 26, 2012 block: Before after with timing kit Arias pistons installed: Oil pan back on: Quote Link to comment
Michael.flee92 Posted May 16, 2012 Author Report Share Posted May 16, 2012 So i've been busy with tinkering with the engine. Heres an update with the engine nearing completion: and heres my baby with the L16 pulled: Quote Link to comment
Michael.flee92 Posted May 16, 2012 Author Report Share Posted May 16, 2012 Lookin good! Hey thanks i appreciate that! Quote Link to comment
