Hardwyre Posted June 28, 2011 Report Share Posted June 28, 2011 Pick'n'Pull has a '92 300zx that I'm pulling the transmission from. The heads are in the way of from of the trans bolts but they're like some sort of large allen wrench head. Like this: Any idea what size hex driver I need to pick up to pull the z32 head? Thanks forum. Quote Link to comment
Laecaon Posted June 28, 2011 Report Share Posted June 28, 2011 Harbor freight multi pack! Quote Link to comment
spottedog Posted June 28, 2011 Report Share Posted June 28, 2011 10mm hex head 3/8" drive socket Napa, ect. Quote Link to comment
datzenmike Posted June 28, 2011 Report Share Posted June 28, 2011 Most L series are 10mm. Quote Link to comment
Docsis510 Posted June 28, 2011 Report Share Posted June 28, 2011 I just took the head off my ka24de and the bolts are 10mm. I would think most nissan engines are the same. Quote Link to comment
wildmaninid Posted June 28, 2011 Report Share Posted June 28, 2011 10 mm....jdm as phuck Quote Link to comment
Draker Posted June 28, 2011 Report Share Posted June 28, 2011 The best way to remove the Z32 tranny is to remove the rear trans mount and drop it about 6 inches or as much as you can. Use a 36" 3/8 extension and a wobbly to get the upper to bolts by going over the top of the trans. The sides should be accessible enough or you can use the extension again if you choose. Quote Link to comment
Hardwyre Posted June 28, 2011 Author Report Share Posted June 28, 2011 I'm going to say it again; I love a forum that is alive with knowledgeable/experience, situationally mature individuals (regardless of age). If I'd had posted this question on Hondatech, I would have gotten two dozen "your mom is the right size" bullshit and still never had an awesome. The best way to remove the Z32 tranny is to remove the rear trans mount and drop it about 6 inches or as much as you can. Use a 36" 3/8 extension and a wobbly to get the upper to bolts by going over the top of the trans. The sides should be accessible enough or you can use the extension again if you choose. I'm pretty close to having it drop, so I was wondering if I could just hit it from the back like I've done with Chevy transmissions. The way the head and wiring harness are wedged up against the firewall makes me wonder if I'll really be able to drop it far enough though. HarborFreight has various sets. The $7 one goes up to 10mm and the $13 goes, I think, up to 17mm. I'm just wondering if HF sockets will survive being used to torque the VH45 head bolts if I decide to put in a fresh head gasket while the engine is out. http://www.harborfreight.com/catalogsearch/result?q=hex Quote Link to comment
wildmaninid Posted June 28, 2011 Report Share Posted June 28, 2011 I'm going to say it again; I love a forum that is alive with knowledgeable/experience, situationally mature individuals (regardless of age). If I'd had posted this question on Hondatech, I would have gotten two dozen "your mom is the right size" bullshit and still never had an awesome. I'm pretty close to having it drop, so I was wondering if I could just hit it from the back like I've done with Chevy transmissions. The way the head and wiring harness are wedged up against the firewall makes me wonder if I'll really be able to drop it far enough though. HarborFreight has various sets. The $7 one goes up to 10mm and the $13 goes, I think, up to 17mm. I'm just wondering if HF sockets will survive being used to torque the VH45 head bolts if I decide to put in a fresh head gasket while the engine is out. http://www.harborfreight.com/catalogsearch/result?q=hex Quote Link to comment
ggzilla Posted June 28, 2011 Report Share Posted June 28, 2011 It is the same as Chevrolet disk brake bolts -- 10mm hex. Not very JDM when you realize 100 million American cars use the same. Quote Link to comment
Hardwyre Posted June 28, 2011 Author Report Share Posted June 28, 2011 Note I said "situationally mature". Quote Link to comment
Skib Posted June 28, 2011 Report Share Posted June 28, 2011 lol deff use the socket one. the first time I tried to pull a had I just went and grabbed the L shaped hex out of my box.... and fuckin broke it Quote Link to comment
Draker Posted June 28, 2011 Report Share Posted June 28, 2011 Depending on how high you've got the car in the air, you can drop it enough. This is how I always do it. You just need the car off the ground about 12"-18", it will drop and pivot on the engine mounts revealing the upper 2 bolts. Breaker bar + 36" extension and your done. Or if you've got one, cordless impact. :D The wiring harness is no big deal, I know it looks like there isn't much room, but once you drop it you'll see. Removing the head requires removing the plenum with is a huge PITA if it's still got the EGR hooked up. then the lower plenum, then the valve covers, then the heads. I don't know how far you've got it torn down already, just keep that in mind. If the upper plenum is on and it's got the EGR tubes attached you are going to be in for some serious work. You will likely need to just cut the EGR tubes in half, and talk about no space to work. hehe Where did you find this car? Is it a TT? How many good parts are still on it? (Hint: You should take a picture and send it to me!) Quote Link to comment
Skib Posted June 28, 2011 Report Share Posted June 28, 2011 Where did you find this car? Is it a TT? How many good parts are still on it? (Hint: You should take a picture and send it to me!) I posted it in the wrecking yard report :lol: Quote Link to comment
Draker Posted June 28, 2011 Report Share Posted June 28, 2011 Non turbo, Aztec Red (AJ4) Looks decent, is that NA tranny going to be able to support your power needs? Quote Link to comment
Hardwyre Posted June 28, 2011 Author Report Share Posted June 28, 2011 Non turbo, Aztec Red (AJ4) Looks decent, is that NA tranny going to be able to support your power needs? Apparently the NA and TT transmissions are identical internally. The difference is the flywheel is 10mm larger on the TT (250mm vs 240mm NA). The stock NA clutch I think it rated up to 400 ft lbs which is plenty. There are also a slew of upgraded clutches if need be. The car is in pieces. The intake plenum is sitting beside the car, I snagged the timing gears to make an art piece or something. What's strange is it looks like one of the pistons was scrubbed with steel wool or similar. Just a random observation. Quote Link to comment
Draker Posted June 29, 2011 Report Share Posted June 29, 2011 Apparently the NA and TT transmissions are identical internally. The difference is the flywheel is 10mm larger on the TT (250mm vs 240mm NA). The stock NA clutch I think it rated up to 400 ft lbs which is plenty. There are also a slew of upgraded clutches if need be. The car is in pieces. The intake plenum is sitting beside the car, I snagged the timing gears to make an art piece or something. What's strange is it looks like one of the pistons was scrubbed with steel wool or similar. Just a random observation. Yep! I just looked it up and you are right. Looks like the bell housing size is the only difference. Good find! Quote Link to comment
