ehime Posted June 22, 2011 Report Share Posted June 22, 2011 So I decided to other day I want to go low. Very Low. I talked to a buddy of mine Justin Hrenko (you might have seen his slammed 73 Wagon), and he told me he went IRS from a 510, and that it was just shy of misery, but it all came together in the end and now he's running QA1 Airshocks and is very low. I like it. He has another buddy that's running a four-link setup and he's also pretty low. I'm trying to decide on a direction. Pro's and Con's. Difficulty inherit on each. Overall usability, and basically forums opinions on what to do. Here's Justin's IRS (White) next to our friends (Beige) four link. Lemme know what you guys and gals think. Quote Link to comment
ohio510 Posted June 22, 2011 Report Share Posted June 22, 2011 white one is lower isnt that what ru after? Quote Link to comment
zerow Posted June 22, 2011 Report Share Posted June 22, 2011 The four link looks better from a "I'm not gonna wear out tires faster" perspective. As for the IRS, It gives you some better options for different heights...but camber is still a major criteria for me to consider a drop like that. My vote = four link. Quote Link to comment
ehime Posted June 22, 2011 Author Report Share Posted June 22, 2011 The white is the one with IR. Zero what do you think the difficulty in both/either is? Quote Link to comment
Wide14u Posted June 22, 2011 Report Share Posted June 22, 2011 they both would be a pain but i would do the four link :D Quote Link to comment
zerow Posted June 22, 2011 Report Share Posted June 22, 2011 The white is the one with IR. Zero what do you think the difficulty in both/either is? Considerable. Both involve adding coil springs where leafs once resided. Is your frame up to the challenge (structurally speaking)? Are you ready for crap that may not have shown up in another person's wagon (rust, bent or broken parts, etc...)? I would go straight static (block) drop with the live axle. I know its not low enough, but shearing off important undercarriage items is not what I would call "cool" on any rare 38 year old car. Quote Link to comment
datzenmike Posted June 22, 2011 Report Share Posted June 22, 2011 The four link looks better from a "I'm not gonna wear out tires faster" perspective. As for the IRS, It gives you some better options for different heights...but camber is still a major criteria for me to consider a drop like that. My vote = four link. Considerable. Both involve adding coil springs where leafs once resided. Is your frame up to the challenge (structurally speaking)? Are you ready for crap that may not have shown up in another person's wagon (rust, bent or broken parts, etc...)? I would go straight static (block) drop with the live axle. I know its not low enough, but shearing off important undercarriage items is not what I would call "cool" on any rare 38 year old car. Two extremely relevant posts back to back. Kudos zerow. Way to save another one. Quote Link to comment
INDY510 Posted June 22, 2011 Report Share Posted June 22, 2011 . I've seen the tan Solid axle wagon in person,,,,, and it is plenty low for a daily driver,,,,, , ,maybe too low .. . .. but it looks really GOOD ..... .. the white one looks cool and all,,, but I would way rather have the "no camber" look on a wagon it cost me $35 for 3" lowering blocks and matching U-bolts to slam my 710 wagon..... .. funny thing is your friend Justin did the motor swap on my KA24DE 710 wagon .... so he did the ONLY running KA24DE swapped 710 .... . .and he did the ONLY running IRS swapped 610 goon and he said the IRS swap was just shy of misery??? .... . . and you're still considering it why??? Quote Link to comment
INDY510 Posted June 22, 2011 Report Share Posted June 22, 2011 . I took these pics,,, , it looks lower in person,,, , ,hardly any ground clearance front or rear: Quote Link to comment
ehime Posted June 22, 2011 Author Report Share Posted June 22, 2011 The reason I'm leaning towards airshocks is so I can actually get over things though, blades of grass, sideways cig packs, etc. From what I understand using lowering blocks will pretty much mean I am that low, and that low always. Is that an incorrect assumption? Indy do you have pictures of your 710 for reference? Quote Link to comment
INDY510 Posted June 22, 2011 Report Share Posted June 22, 2011 . PacificCoastDatsun and GreenGoon both have 3" lowering blocks and Monroe air-shocks on their 510 wagons .... so you can raise the back for speedbumps or carrying weight .. .. they also modified the leaf springs, shock mounts,,, and GreenGoon raised the shakle mount to the body ThinkOutsideTheBox710 told me he had 3" lowering blocks and stock springs/shocks on his old 710 wagon,,, , so I did the same,, but haven't driven it yet: it took 300lbs of concrete to get this low after 3" blocks: ...... :lol: Quote Link to comment
ehime Posted June 22, 2011 Author Report Share Posted June 22, 2011 Cheers, that actually looks damned good. I didn't know you could use airshocks/bags along with blocks. Of course I'm not necessarily a suspension guy and this is my first real foray into it. Something of some in interest I dug up today though was this little article, what does forum think? http://www.locostusa.com/forums/viewtopic.php?f=4&t=572&view=previous Quote Link to comment
thisisn8n Posted June 24, 2011 Report Share Posted June 24, 2011 if some one were to want an irs on a 510 wagon, what other options are out there. i know people have used irs from 4doors, but i havent really ran into any. ive heard of miata irs aswell.... any other options/ideas? Quote Link to comment
ehime Posted June 24, 2011 Author Report Share Posted June 24, 2011 i just listed above a Miata IRS possibility, and please. no thread jacking. Quote Link to comment
thisisn8n Posted June 29, 2011 Report Share Posted June 29, 2011 i just listed above a Miata IRS possibility, and please. no thread jacking. my apologies.. Quote Link to comment
ehime Posted October 16, 2011 Author Report Share Posted October 16, 2011 it took 300lbs of concrete to get this low after 3" blocks: ...... :lol: Raising this from the dead. So you said 300lbs of concrete in the back to get it that low, did you use it to bend your leafs, or to just get it to look that low after you did it, I.E. there's concrete bags in it right now but its not normally that low. Quote Link to comment
datzenmike Posted October 16, 2011 Report Share Posted October 16, 2011 You can't permanently bend leaf springs by doing that. If so, every leaf spring vehicle would look like that after the first bump. To permanently flatten or re-arch a leaf a hydraulic press is needed. Never never never heat them!!! Spring steel has an elastic memory that returns it to it's former position. The steel needs to be pushed past this to a new memory position but carefully and in small amounts. A press with a jig to add a little every few inches will do. Like this... I had mine done at a shop and they had an electric motor for the hydraulic jack and was quite fast to do. . Quote Link to comment
Rob_the_Goonster Posted August 19, 2012 Report Share Posted August 19, 2012 hey all, i know im a new guy to this hole relm but i think honestly in my opinion that if your looking for more low than just put up with the headaches and work on a IRS swap with bags or airshocks, but on the other hand keeping any and all original/OEM parts and running gear deffinatly adds a whole nother level of awesomeness. also i say this cuz in the last 2 weeks i have dropped 3 DIFFERENT rear ends in my 72 goon and im still working on it for a fourth and im kinda leaning towards the IRS out of a Miata just dont want to have to put up with the lug pattern difference. Vote=IRS Quote Link to comment
datzenmike Posted August 19, 2012 Report Share Posted August 19, 2012 Goon to 4 link = get '82-'83 S110 axle, springs, links and sway bar and over half way done. The rear disc brakes add to the awesomeness Goon to IRS = nightmare. IRS = camber nightmare. Quote Link to comment
jesusno2 Posted August 19, 2012 Report Share Posted August 19, 2012 i recentley 4 linked James 510 wagon if ya want it low your gonna have to fabricate a new floor pan. and notched the subframe or raise it also which needs to happen anyway for proper geometry under the 510. i dunno know if the 610/710 rear floor pans are the same or not. Quote Link to comment
KyushaKai Posted August 20, 2012 Report Share Posted August 20, 2012 im kinda leaning towards the IRS out of a Miata just dont want to have to put up with the lug pattern difference. Miata is 4x100 so you'd still have a different set up. Quote Link to comment
datsunwizard Posted August 21, 2012 Report Share Posted August 21, 2012 Miata IRS in a wagon= a royal pain,lots of work, ask me how I know. Miata is roughly 5.5" to wide, so it's all custom. Miata A arms and uprights. Uprights converted to 5 on 114mm hubs. STI R180 LSD diff. A long term project. Quote Link to comment
