Uncle Laulau Posted June 21, 2011 Author Report Share Posted June 21, 2011 Brian, I pulled out the two jets from the barrels and the needle jet. I will check to make sure all the surfaces are nice and flat, good looking out. Ok I'm back froma napa with some gasket making paper for the air filter plate gasket, and I'm gonna cut that out and start thoroughly cleaning stuff up. On a side note I found out I can get a clutch on the napa sale for $100 and change, hmmmm. Thanks for everyone's help. Quote Link to comment
banzai510(hainz) Posted June 21, 2011 Report Share Posted June 21, 2011 clutch Offcial Daiken (No made in China) 83 plus shipping http://performance.importrp.com/exedy_clutch/exedy_oem_replacement_clutch_kit/06022/i-125783.aspx Quote Link to comment
yello620 Posted June 22, 2011 Report Share Posted June 22, 2011 Why do you have plastic parts in the chem dip? Doesnt that stuff destroy the plastic? Plastic filter under that 19mm plug at the fuel inlet, and plastic at the throttle shaft ends. Maybe i am wrong about plastic being destryed in chem dip. Quote Link to comment
Uncle Laulau Posted June 22, 2011 Author Report Share Posted June 22, 2011 clutch Offcial Daiken (No made in China) 83 plus shipping http://performance.i...2/i-125783.aspx Thanks this looks good! Quote Link to comment
Uncle Laulau Posted June 22, 2011 Author Report Share Posted June 22, 2011 Why do you have plastic parts in the chem dip? Doesnt that stuff destroy the plastic? Plastic filter under that 19mm plug at the fuel inlet, and plastic at the throttle shaft ends. Maybe i am wrong about plastic being destryed in chem dip. Ummmmmm, I might have made a boo boo. Yikes. I'll check the directions on the can again. It comes with a plastic dipping basket, and to tell you the truth I thought I had taken all the plastic off. Well this is an experiment now. We will see if you can get away with dipping those parts in this product with no ill effects. It runs sweet right now, if that's any indication. Quote Link to comment
808DA6 Posted June 22, 2011 Report Share Posted June 22, 2011 Up and running? Did u strain the solvent? Sometimes it helps to see what was in there....or just cool to see. -B Quote Link to comment
Uncle Laulau Posted June 22, 2011 Author Report Share Posted June 22, 2011 Up and running? Did u strain the solvent? Sometimes it helps to see what was in there....or just cool to see. -B Yah It's running smoooooth. Hope I didn't hurt any plastic pieces I forgot to take off...drrrrrrrr. On a side note, I found out my crank case vent for the pcv was permanently plugged. Wayno pointed it out to me. Nice. What's the deal, I saw people posting on the web it was an old rally car trick?! I really would like to fix the pcv asap. Is the PIR thing still going on? If it is I would love to check it out. Take care Brian. I didn't strain it totally, it's stinky. I did find one nice size hunk of aluminum! Size of a flat apple seed. Nice to suck that into my engine. Quote Link to comment
banzai510(hainz) Posted June 22, 2011 Report Share Posted June 22, 2011 On a side note, I found out my crank case vent for the pcv was permanently plugged. I think I pointed this out also! I dont know about rally car trick but it thay have sidedrafts they open vent it! NOT PLUG IT. Plugn it is a dumbass trick that motor look pretty clean really!!!!!!!!keep it running. glad it runs good Quote Link to comment
Uncle Laulau Posted June 22, 2011 Author Report Share Posted June 22, 2011 On a side note, I found out my crank case vent for the pcv was permanently plugged. I think I pointed this out also! I dont know about rally car trick but it thay have sidedrafts they open vent it! NOT PLUG IT. Plugn it is a dumbass trick that motor look pretty clean really!!!!!!!!keep it running. glad it runs good Thanks man. I just looked at the place the crank case vent used to come out. It looks smashed into the block, like somone took a mallet to it. Really slick. Not. I'm gonna change the oil today and try and stay ahead of gunk build up that may occur. I'm actually going to try and go to jiffy lube, 19 bucks is just to good. I have a funny feeling they will turn me away, dang lawyers and frivolous lawsuits. Quote Link to comment
banzai510(hainz) Posted June 22, 2011 Report Share Posted June 22, 2011 soembody shpould have a spare L16 block tube ,come out the side, late L16s/18/20 have the hole on top and its a 90deg bend on the tubes.I have 2 spare tubes,just open vent it till you get a hose and PCV. Quote Link to comment
Uncle Laulau Posted June 22, 2011 Author Report Share Posted June 22, 2011 soembody shpould have a spare L16 block tube ,come out the side, late L16s/18/20 have the hole on top and its a 90deg bend on the tubes.I have 2 spare tubes,just open vent it till you get a hose and PCV. Sounds good, open vent it till. I took my truck into jiffy lube. It was so funny, they had to use ramps and lift my truck over the lip of the bay, tehee 1 Quote Link to comment
wayno Posted June 23, 2011 Report Share Posted June 23, 2011 I got the tube out of the L16 I have in the back yard Kevin, have not a clue how you will get the one in your block out. You will likely have to remove your intake and exhaust manifolds to do it. wayno Quote Link to comment
banzai510(hainz) Posted June 23, 2011 Report Share Posted June 23, 2011 whats it pluged with? Maybe reach in there with a soem vicegrips and pull the MOFO and slide in the new l16 tube. Quote Link to comment
Uncle Laulau Posted July 6, 2011 Author Report Share Posted July 6, 2011 My truck stay broke! Golly gosh, looks like I need some more Ratsun wisdom. The short of it is when I give it the gas it bogs down, even stalls. I think it is carb issues. Wayno thinks it's missing, as of a couple days ago. Sorry to throw you under the bus man, or at least out there. So here is my first video of the drama. I have a couple others if needed, same type of behavior. Ratsun do your magic, make my truck work with your wisdom and knowledge. Don't let me down, or I will join honda civic racers . net. Quote Link to comment
wayno Posted July 6, 2011 Report Share Posted July 6, 2011 :( This is bad news, you need someone with downdraft carb skills, that isn't me. I always feel sad when a datsun I know is sick.:unsure: Hopefully soon your 521 will feel better. Quote Link to comment
skyblue Posted July 6, 2011 Report Share Posted July 6, 2011 hmmm. did this just start happening out of nowhere? Quote Link to comment
ggzilla Posted July 6, 2011 Report Share Posted July 6, 2011 Downdraft carb skills are the same as sidedraft carb skills. Laulau, I notice in your first pictures that the factory fuel tank vent is not connected. Now, if the tank is not properly vented it can cause driveability and overflow problems. Check that out. How is your tank venting? They come with a sealed cap, and a fuel tank vent line which comes up to the engine compartment. Quote Link to comment
wayno Posted July 6, 2011 Report Share Posted July 6, 2011 Downdraft carb skills are the same as sidedraft carb skills. Laulau, I notice in your first pictures that the factory fuel tank vent is not connected. Now, if the tank is not properly vented it can cause driveability and overflow problems. Check that out. How is your tank venting? They come with a sealed cap, and a fuel tank vent line which comes up to the engine compartment. That line is capped off, I looked at the truck the other day, it never entered my mind, as the vapor separater is long gone on that truck, I just assumed that it would be alright capped off rather than open to the air, as there is no return fitting on the carb. I have been running my truck for years without a vent line, my SU type setup has a return line connected to the pressure regulator, so excess fuel goes back to the tank, so I must have holes somewhere in my system as it has not collapsed my tank, hmmmm, maybe I should look into this one of these days. :lol: Quote Link to comment
Uncle Laulau Posted July 6, 2011 Author Report Share Posted July 6, 2011 :( This is bad news, you need someone with downdraft carb skills, that isn't me. I always feel sad when a datsun I know is sick.:unsure: Hopefully soon your 521 will feel better. Wayno you rock! Thanks mandingo. I'm learning so much with every one on the forum. I'm not sad just was hoping it would run as good as it did before it didn't. Hope you had a rad 4th. Quote Link to comment
Uncle Laulau Posted July 6, 2011 Author Report Share Posted July 6, 2011 Downdraft carb skills are the same as sidedraft carb skills. Laulau, I notice in your first pictures that the factory fuel tank vent is not connected. Now, if the tank is not properly vented it can cause driveability and overflow problems. Check that out. How is your tank venting? They come with a sealed cap, and a fuel tank vent line which comes up to the engine compartment. [/q Wayno saw a tube he thought was the vent tube capped off on the fire wall! man can this be it? Someone who says they're a mechanic earns my trust. Maybe next time I'll ask for there credentials. That sounded vindictive....maybe I'll just take my lumps. Yikes this is turning into a vent session. I'll keep everyone posted, I'm sure it will work out. Quote Link to comment
