datsunfreak Posted June 1, 2011 Report Share Posted June 1, 2011 So, we were looking for an easy way to cap off the smog ports in the ends of the exhaust manifold. We made some block off plates and those leaked after the first 1000-1200 miles. So... We took the stock smog pipes, cut the "pipe" off, just leaving the pipe's mounts. Then while rooting around found that a beer bottle cap is a perfect fit for the hole the pipe left behind. 8-10k miles later and still doesn't leak. You can even still read the logo on the lid. :P 1 Quote Link to comment
izzo Posted June 1, 2011 Report Share Posted June 1, 2011 Ha, that bottle cap has a patina look to it now Quote Link to comment
datzenmike Posted June 1, 2011 Report Share Posted June 1, 2011 You can't paint patina on.... it has to be earned. Quote Link to comment
MikeRL411 Posted June 1, 2011 Report Share Posted June 1, 2011 This has nothing to do with your excellent fix but I have a mini bottle of Harp Lager and also one of Guinness Stout! A mini bottle Black and Tan? Quote Link to comment
MetalGear1200 Posted June 1, 2011 Report Share Posted June 1, 2011 i live in california. should i use a different type of cap to pass our rigorous emmisions? :P Quote Link to comment
king bee66 Posted June 1, 2011 Report Share Posted June 1, 2011 too bad i can only afford lonestar tall boys. one day maybe. Quote Link to comment
metalmonkey47 Posted June 1, 2011 Report Share Posted June 1, 2011 Cool Looks better then my block offs. I took a piece of thin steel and cut it to match, then used some exhaust sealant to seal it up tight. Quote Link to comment
ggzilla Posted June 1, 2011 Report Share Posted June 1, 2011 Certainly cheaper than whay I did, use a quarter, one on each end. the alloy solution. Congrats on the ratsun solution. Quote Link to comment
datsunfreak Posted June 1, 2011 Author Report Share Posted June 1, 2011 i live in california. should i use a different type of cap to pass our rigorous emmisions? :P Pellegrino. Definitely. :) Quote Link to comment
datsunfreak Posted June 1, 2011 Author Report Share Posted June 1, 2011 too bad i can only afford lonestar tall boys. one day maybe. Good point. Might need to remove these for some Lone Star caps... ;) Quote Link to comment
