Is this the right Z to get my 5 speed out of?
Llittle_Llama
I found this at the JY today and before I pull/pay for it tomorrow I want to make sure this is correct. I know it's an L series, but I'm not sure if that's the only thing I need to know about it. Besides checking that it shifts into all the gears fine is there anything I can do to make sure I'm not pulling a POS?
  • Replies 21
How far did your shifter move back?
OP...like he said. Non-turbo Z. You found the golden ticket with that one.
I want to say around 3-4 inches.
If your familiar with 521's , you can kinda see where the original spot is supposed to be.
Oh shit. That's not bad at all.
I've half-heartedly looking for one.
Full force now.
Buy yes. I own a couple 521's.
Look at drain bung it has a magnet on the end that traps ferrous metal. It will normally have a black 'paste' on it. Maybe some fine particles.
Relatively normal bung
Not so normal bumg.
My bung.
picture removed by request
Full force now.
Measure the front shaft of your driveline(assuming you have a 2 piece). Next time you hit the yards, grab a front shaft with carrier bearing from a 620 that is approx 4" shorter than your stock one. This way you don't have to pay someone to shorten your stock one. I just can't remember which truck I pulled mine from. King cab and regular cab could be different.
Sorry for the thread jack,dwnshfter
Jeffe, I think they (front) are for the most part the same length. The differences in truck lengths are in the frame behind the carrier bearing on the reg or KC cab. I would thing the rear driveshafts are different lengths.
Hhmmm , maybe I have it backwards? I swear, my memory is $hit.
Ok, grab the the driveline half that's 4" shorter than your stock one.
Don't change anything. You have a '79 right? The zx will swap right in... it's the same exact length as your old 5 speed.
HOWEVER
Being a '79 you are running a 4.11 ratio rear end and the 5 speed (or 4 spd) you have now is differently geared to allow an easier take off in first. Installing a ZX will be a mutherfucking huge jump in gear ratios. Your overdrive ratio is about 12% the zx is twice that at just over 25%. You may have trouble maintaining highway speeds into a light wind.
'79 ratios
1st.... 3.594
2nd... 2.246
3rd.... 1.415
4th.... 1.000
5th..... 0.882
'81- zx ratios
1st..... 3.062
2nd... 1.858
3rd..... 1.308
4th..... 1.000
5th..... 0.745
You meant 4 speed right? I thought it swapped right in, but it's been so long since I was looking at doing this so I wasn't sure.
Oh yours is a 4 spd??? Well exact same gears without 5th.
Don't you mean by popular request? :blink:
........ (yes)
