ricky Posted April 20, 2011 Report Share Posted April 20, 2011 Ok guys i have searched high and low on this site for the problem with my car. I had a l16 and the motor would run good then it would start to sputter and die and then not start again. Then I would mess with coil dizzy carb a d plugs to see what the deal was after having head rebuilt and a million other parts I pulled it and put a l20b in. I did not use a single part from old motor. Except alternator. I started car and pulled wire to see if it stays running and it did. I start to dive car home. I get about half way there and bam all of a sudden. Same exact thing as l16. Please help. I am thinking maybe its the wiring in my car. Maybe getting not enough spark or inconsistent spark. Can you guys point me I. The right direction I am 100% positive that I am getting fuel Quote Link to comment
510kevin Posted April 20, 2011 Report Share Posted April 20, 2011 if the car does it with a different motor, my guess would be wiring between the car and motor. check all connections on the coil to the ignition switch. thats the only info i can give and its based on problems i've had. mine would run great in the driveway, and as soon as i would take off the black and white wire would give me shit. i fired my car up, and started wiggling wires, it was easiest to find it that way. good luck!!! Quote Link to comment
ricky Posted April 20, 2011 Author Report Share Posted April 20, 2011 I'll start there then thanks for input Quote Link to comment
datzenmike Posted April 20, 2011 Report Share Posted April 20, 2011 The ballast resistor get hot with use. Next time it does this, have a jumper wire handy and connect from the positive battery post to the positive terminal on the coil. This will remove the ignition switch and ballast resistor from the circuit. If this fixes the problem then you have narrowed it down. Quote Link to comment
ricky Posted April 20, 2011 Author Report Share Posted April 20, 2011 Since thishappend I can't get my car to stay running for more then a second. Is the ballast the thing inside dizzy Quote Link to comment
banzai510(hainz) Posted April 20, 2011 Report Share Posted April 20, 2011 You have points or a electronic ignition? If points you need a stock point tyep coil and the ballast resisitor(white ceramic thing on inside fender) this keeps the points from burning up but using a 1.6 ohm coil and a ballast resisitor. page 181 in the Haynes manual has the drawing and on here( I cant post photos on this site) I assume you have a mismatch parts set where too much current is killing soemthing.wrong coil/missin ballast? next is I would ck the valve lash just in case things tighten up since you put a new head on. a enigne cutting out is not reason for a motor pull. find a Datsun owner in your area to help you(not a Datsun cracker) stay running more than a second? You mean it run if you have it in START position on switch? This is a simple FIX. Quote Link to comment
ricky Posted April 20, 2011 Author Report Share Posted April 20, 2011 I think the dizzy I have is points turned into ei it has the pertronix thing inside dizzy. And I am nolomger using the motor that I had head rebuilt on I am using a l20b now. And it ran perfect in drive way and for about half a mile before it emulated my l16. Quote Link to comment
banzai510(hainz) Posted April 20, 2011 Report Share Posted April 20, 2011 Pertronix needs a point coil and the ballast resistor. stock 510 is 1.6 ohm EACH =total 3.2 ohms. so youll use a 3 wire system blk/wht wire (ON) blk/blu is the (START) blk/grn the 510 keeper lives near you have him fix this for you only you know where the ballast resisitor IS or hooked up, and what coil you have. send photo of your coil close up PM you email adress Ill send How I hooked up my Pertronix Quote Link to comment
ricky Posted April 20, 2011 Author Report Share Posted April 20, 2011 ok i cannot find a ballest resistor so i assume that could be part of the problem. how ever i drove my datsun with other motor for several months with out this issue Quote Link to comment
banzai510(hainz) Posted April 20, 2011 Report Share Posted April 20, 2011 how ever i drove my datsun with other motor for several months with out this issue I can only give my best guess. It could go a few months before it pops. It could be the Petronix went bad also. There are a few varibles as I had listed above. Unless that is a 3 ohm coil you have there. But I am here. I dont know where you got it from. If from a newer datsun its a Low ohm coil of most likely .7 ohms and if no ballast that Pertronix was getting HOT. If just a point coil and no ballast The coil could get HOT running at 12-14 volts. Point coils run at close to 6volts or less depending on what ohm ballast. If your sure the valve lash is good and your getting gas. I think its the ignition is the first thing to look at. Quote Link to comment
ricky Posted April 20, 2011 Author Report Share Posted April 20, 2011 I am using an accel universal coil fro Kragen. I will get a ballast and check wires and go from there. The dizzy on my old motor did not have pertronix it was a matchbox. With the big square thing on side of it with a plug Quote Link to comment
ricky Posted April 20, 2011 Author Report Share Posted April 20, 2011 U know I think my coil may be the issue I replaced it about a week before I went on a long drive and when I came back from trip is when this started on the other motor Quote Link to comment
I'm BLUE Posted April 20, 2011 Report Share Posted April 20, 2011 Ok ,,, on the coil side of things ,,, The ballast resistor ,,, when I unplug either of the two wires that go to it on my Z car ,,, it will "fire up" for 1 sec or less ,,, and die ,,, Are you 100% sure the connection is good ? and the wires are hooked up correctly at this area ? ,,, ( I unplugged it as a theft deterrent amongst other things ) Also one of my connectors to the resistor was so loose that at the time ,,, going over speed bumps and what not,,, , it would just pop offf , crazy i know ,,, but it happened :lol: :) Quote Link to comment
ricky Posted April 20, 2011 Author Report Share Posted April 20, 2011 I have no ballast I just ordered it. It will be here tomorrow. Quote Link to comment
banzai510(hainz) Posted April 20, 2011 Report Share Posted April 20, 2011 The Accel small round coil is know as the superstock( i think they are Made in China now). This is a POINT coil. I believe the ohm vaulue is 1.4 which is close enough. But if you dont have a ballast resisitor you Pertronix or coil will get hot. I run a Accell Super Coil witch is the BIG one(.7ohms) and I run 2 ballast resisitors to make up the diffence in the low value but thats another story. I think we are narrowing it down. Just depends what you have as spares at home to run. EI Datsun amd MSD coils are like .7 but can run on 12-14 volts made for the matchbox or remote box Points/Pertronix need more resisitance. You see now you might have a bad Pertronix also so its almost better to start from scatch . You see if you have a EI coil and no ballast best just get a matchbox. If no matchbox you better fnd a point coil and ballast along with a point dizzy(junk yard grab from another datsun) Quote Link to comment
ricky Posted April 21, 2011 Author Report Share Posted April 21, 2011 Ok I took pictures illpost in about an hour Quote Link to comment
banzai510(hainz) Posted April 21, 2011 Report Share Posted April 21, 2011 I wont be here in hr Maybe Datzenmike can help depends if your Pertronix is bad. If bad, almost better to get local used a matchbox dizzy and EI coil. I dont know what a Bad Pertronix looks like. I assume plull the center coil wire and place near ground and see if sparks. Maybe your magnets flew apart ck that also. If you have aspare point dizzy youll need a ballast and you have the point coil. I hope the ballast is at least 1 ohm but better around 1.5 or so. I love my Pertronix and run 3 of them and put a couple in other cars and a Jeep. But the matchbox is better if you have the whole dizzy and timming plate/ mount. if bushing is still good Quote Link to comment
ricky Posted April 21, 2011 Author Report Share Posted April 21, 2011 ok so here are some pics so you guys know what i have on my car sorry they were taken with iphone. this is whats in car this was on the l16 that had same problem coil other motor dose not have this but this is on l20 Quote Link to comment
ricky Posted April 21, 2011 Author Report Share Posted April 21, 2011 so tell me what i need so i can i post a wanted add. what set up should i go with? Quote Link to comment
Duke Posted April 21, 2011 Report Share Posted April 21, 2011 After the car dies, have you tested to see if it is getting spark? Throwing parts at a problem usually won't fix it, but it will eat away money. Quote Link to comment
ricky Posted April 21, 2011 Author Report Share Posted April 21, 2011 Yea the first thing I did when it died was check for fuel and spark. Fuel is good I'm 100% sure on that and it seems like it's bot getting consistent spark or not a hot enough spark. The fact that I'm supposed to have a ballast and don't indicates that to me that it's part of the problem. I have gon over the old motor so much then when I put a new motor and it dose same thing. And I think when I put the new coil in is when to problem started Quote Link to comment
Duke Posted April 21, 2011 Report Share Posted April 21, 2011 Like Hainz said, it is likely that you burned out the pertronix unit. I would recommend getting a new one and a new coil that either has the recommended resistance internally (like 3.2 ohms or something) or using a ballast resistor to achieve the 3.2 ohms of resistance required. I have burned up pertronix units in the past by going to a hot coil and not considering the change in internal resistance. Quote Link to comment
banzai510(hainz) Posted April 21, 2011 Report Share Posted April 21, 2011 Ok his helps with the photos. I didnt know you had a matchbox. YOu still have it? if yes then get a Datsun 79 coil from a 620/720 or 200sx. and just install that. then you dont need a ballast resisitor. blk/wht wire shorted to the blk/blu wire to the + side coil,just double post the +side of the coil so you dont have to cut wires B to + coil C to - side coil If pertronix.(point coil as the accell you got, and the ballast) then use the Drawing I sent PM you What coil you had with the matchbox orginally?If you had a EI coil it should dhave been fine, most proplems are ground corrision on those. was this car ever running right? Quote Link to comment
ricky Posted April 21, 2011 Author Report Share Posted April 21, 2011 That matchbox is on my l16 it was a daily driver I put the accel coil on and when on a 2 hour drive after I came back the car started having issues it didn't seem like electrical to me so I checked everything else finly got topoint where I but l20. Then a half mile later same exactissue. Yes I still have matchbox Quote Link to comment
