kiznook Posted April 18, 2011 Report Share Posted April 18, 2011 Looking for a L series head in Portland area. No junk, don't have time to pull out exhaust port sleeves, 210 heads are just to suffocated. Let me know ASAP, the sun is out and so should be the datto. Link to comment
]2eDeYe Posted April 18, 2011 Report Share Posted April 18, 2011 ' Sorry, couldn't resist :lol: Link to comment
yello620 Posted April 19, 2011 Report Share Posted April 19, 2011 I could use some too. :D :rofl: Link to comment
yello620 Posted April 19, 2011 Report Share Posted April 19, 2011 I could use some too. :D :rofl: Skib might still have some around. Link to comment
Guest kamakazi620 Posted April 24, 2011 Report Share Posted April 24, 2011 Skib might still have some around. He is a blowhard!!! Hahahaha, Kiznook I know where a u67 is, for cheap Link to comment
hang_510 Posted May 7, 2011 Report Share Posted May 7, 2011 i have a U67 .510 cam, should get new valve guides Link to comment
Z_Rac3r Posted May 7, 2011 Report Share Posted May 7, 2011 How do you remove the exhaust inserts? I thought you couldn't? I have a w53 and a w58, the w53 I believe has the exhaust sleeves, but a fresh valve job so I wanted to use that on my build, but I hate those damn inserts! the W58 I was going to clean up and port to run on this engine later and compare flow. I have another one at my buddies shop Im not using, its been there almost a year, if I had a quick way to get it to ya, itd be yours Link to comment
Jester Posted May 7, 2011 Report Share Posted May 7, 2011 There was a guy here locally that did a flow test before and after removing them. I don't know what the numbers came out at, but, he did say it wasn't worth the time it took him even though it was a closed chamber. Link to comment
Z_Rac3r Posted May 7, 2011 Report Share Posted May 7, 2011 Wasn't worth... Taking out the inserts? Or the porting? Link to comment
Jester Posted May 8, 2011 Report Share Posted May 8, 2011 He has a closed chamber head with the liners in the exhaust ports. Decided to flow test it with the liners and after he removed them. He said with the amount of work it took to remove them he should have just got a different head to start with. Just saying, don't bother with screwing with the liners, just go for the W58. Link to comment
wayno Posted May 8, 2011 Report Share Posted May 8, 2011 The W58 head is more than likely the head with the inserts, and round exhaust ports. The W53 head is the more desirable head(JDM) with square exhaust ports and more than likely is a closed chamber(peanut) head. I have been told by a more than likely knowlegable source that it is basicly a waste of time to remove the inserts. The W53 is my favorite head if unable to aquire a 219(V912) at a reasonable price, as I am able to buy a W53 head, have large valves installed, and have the intake ported to match the intake manifold for the same price as the more desirable heads(219-V912) are sold in used condition. Link to comment
