DatDoug Posted February 11, 2008 Report Share Posted February 11, 2008 I recently aquired a weber and a Z 5 speed for my lil 620 p.u. I will be pulling the motor and 4 speed tranny this week. I will clean the motor and paint replace a few gaskets and seals, new t.o. bearing (clutch looks good) and put it all together and b4 I thro her in give the engine bay a good douche and mayb paint. I was thinking of painting it black or gray or just leaving it hte stock color. What are your thoughts and any pics of painted engine bays would b appreciated.:D Quote Link to comment
datzenmike Posted February 11, 2008 Report Share Posted February 11, 2008 Change the $3 pilot bushing too. Quote Link to comment
DatDoug Posted February 11, 2008 Author Report Share Posted February 11, 2008 Change the $3 pilot bushing too. I here ya Mike. I dont have the tool for it tho.:( Quote Link to comment
kiznook Posted February 11, 2008 Report Share Posted February 11, 2008 rent one, or use the hydraulic method Quote Link to comment
]2eDeYe Posted February 11, 2008 Report Share Posted February 11, 2008 soap and a dowel work everytime... ;) Quote Link to comment
phatdave Posted February 11, 2008 Report Share Posted February 11, 2008 Yeah, just tap it in, I did, and Im not real fucking smart:blink: Quote Link to comment
DatDoug Posted February 11, 2008 Author Report Share Posted February 11, 2008 First ya gotta get the old 1 out! Any fool can put 1 in:fu: Quote Link to comment
datzenmike Posted February 12, 2008 Report Share Posted February 12, 2008 Get a small 6" cold chisel that will fit the hole. The pilot bushing is only bronze and 'soft'. Hammer the chisel down one side till it bottoms out, and then in two more places, (if even needed) and the pieces fall out...easy. (any fool can do it :D) Any small scratches on the inside of the hole will just hold the new one better. Takes as long as reading this post! Quote Link to comment
phatdave Posted February 12, 2008 Report Share Posted February 12, 2008 Yeah what Mike said...I wasn't trying to insult you, so relax. It was just a little self defacing humor. Quote Link to comment
DatDoug Posted February 12, 2008 Author Report Share Posted February 12, 2008 I know. I wasnt trying to be a dick. It just comes natural:D Thx for the advice Mike. I have about 3 or 4 of those pilot bearings lying around (new) cause I could never get the old ones out when I did my clutch sets. Now I will take care of bidness the rite way and replace it. Quote Link to comment
]2eDeYe Posted February 12, 2008 Report Share Posted February 12, 2008 ...or, pack that bitch full of soap, get a dowel the same size as the inner diameter of the bushing and pound that shit. The soap will push in behind the bushing and press it out. ...or, use grease and a round punch the same diameter and use the same principle.... Press it out a bit, pack more in, press it out some more and so on and so forth. This is the Hydraulic Method mentioned by Kiz a ways up there... ;) Quote Link to comment
phatdave Posted February 12, 2008 Report Share Posted February 12, 2008 Bushing...not bearing.:fu: Quote Link to comment
yello620 Posted February 12, 2008 Report Share Posted February 12, 2008 2eDeYe;40535']...or' date=' pack that bitch full of soap, get a dowel the same size as the inner diameter of the bushing and pound that shit. The soap will push in behind the bushing and press it out. ...or, use grease and a round punch the same diameter and use the same principle.... Press it out a bit, pack more in, press it out some more and so on and so forth. This is the Hydraulic Method mentioned by Kiz a ways up there... ;)[/quote'] This is the method that i have always used. Pack the hole with grease and the i find a large bolt that just slides into the pilot bearing, then i use a little electrical tape on the bolt until it fits almost snug. Now use your BFH on the bolt, The grease will push the bushing out. Easy. Jason Quote Link to comment
mklotz70 Posted February 12, 2008 Report Share Posted February 12, 2008 I didn't know about the trick until I did the eng swap in my wagon....it works awesome!!!! I used grease and a steel rod that just fit. Didn't even have to hit it that hard. Quote Link to comment
datzenmike Posted February 12, 2008 Report Share Posted February 12, 2008 Tried grease once and didn't get it right and wore it. So I followed Alexanders example when dealing with the Gordian knot. Quote Link to comment
SHADY280 Posted February 12, 2008 Report Share Posted February 12, 2008 Bushing...not bearing.:fu: except on mine, i got the nissan compitition bearing!!!! less resistance to get more power (.000001hp) lol Quote Link to comment
]2eDeYe Posted February 12, 2008 Report Share Posted February 12, 2008 Tried grease once and didn't get it right and wore it. So I followed Alexanders example when dealing with the Gordian knot. That's why I mentioned the soap method first, it's a bit cleaner ;) Quote Link to comment
DatDoug Posted February 17, 2008 Author Report Share Posted February 17, 2008 Well, I didnt get the 5-speed in. My friend that came out to help me says"this sure is a lot of work for 1 more gear!" I agreed. If it neede a new clutch or throwout bearing I would, but there is nothing wrong with it. So, I just pulled all the smog crap (take a deep breath datzenmike) and put on an older ex. mani and intake mani. that was ported out from Datsunfish (thanks Ben) and the ol reliable 32/36 Weber carb. All I need to do now is modify the exhaust pipe to fit threw the torsion bars and get my exhaust done. I also put in a matchbox dist. Oh yeah Hainz the P.V.C. is hooked up!:fu: THE SMOG BEAST! [/img] Ahhhh thats better [/img] Cracky....Shes a wild one! [/img] The MOTORCYCLE MUFFLER that was on my truck [/img] The F-Bomb collection [/img] Quote Link to comment
datzenmike Posted February 18, 2008 Report Share Posted February 18, 2008 I ain't sayin' nuttin'. (as long as it's done right) Quote Link to comment
DatDoug Posted February 18, 2008 Author Report Share Posted February 18, 2008 Your allright Dmike! I dont care what the others say about ya!:D Got it all put back together. [/img] Quote Link to comment
datsunfish Posted February 18, 2008 Report Share Posted February 18, 2008 Kept her gold eh? Quote Link to comment
DatDoug Posted February 18, 2008 Author Report Share Posted February 18, 2008 Yeah D.F. I kept it gold just for you. Now when people ask me why would you go and do something like that for......I can refer them to you!:D:fu: Quote Link to comment
datsunfish Posted February 18, 2008 Report Share Posted February 18, 2008 Once people see how awesome it is they wont care what color it is.:fu:Also no one will ever see it because you will sell it some time next week for what you have into it and buy a different one because you werent too fond of the particular shade of the headliner.:lol: Quote Link to comment
