jesusno2 Posted February 28, 2011 Report Share Posted February 28, 2011 Unless their are some glass guys on here that wanna install a windsheild seal for me?? Quote Link to comment
kmc63 Posted February 28, 2011 Report Share Posted February 28, 2011 Not as tough as you might think.Did mine after paint a few years ago.Read-up and use the rope like they tell you its not bad really.Best to have a friend to help though. Quote Link to comment
Rustina 510 Posted February 28, 2011 Report Share Posted February 28, 2011 I'll intall your windshield for 40$ Quote Link to comment
jesusno2 Posted February 28, 2011 Author Report Share Posted February 28, 2011 I'll intall your windshield for 40$ The old one is still in their, needs removed but your up around portland area, and my cars not quite mobile yet. No mobile glass guy will touch it I called. Quote Link to comment
yello620 Posted February 28, 2011 Report Share Posted February 28, 2011 I did mine in my 620 last fall. Used the rope method. I did not really enjoy doing it at all, but i learned and would do it again. Took the fear out of it for sure. Quote Link to comment
jesusno2 Posted February 28, 2011 Author Report Share Posted February 28, 2011 I've broke them before. I don't. Wanna break my goons windsheild its perfect condition. Rather let a more exp person do it Quote Link to comment
yellowdatsun Posted February 28, 2011 Report Share Posted February 28, 2011 I've installed windshields before, and usually they're pretty easy. The last one I did in a 510 was cake. Back windows are easy too. I did the one on my 71' 510 a year ago. Was a HUGE pain in the ass, which we believe was because of the aftermarket seal. We think the rubber was too thick for the gap between the glass and the body. Normally they're pretty easy using the rope trick. Quote Link to comment
hang_510 Posted March 1, 2011 Report Share Posted March 1, 2011 Not as tough as you might think. Read-up and use the rope like they tell you its not bad really. :rolleyes: doing it alone = worth $40 i (re)did mine 3X alone because the glass or the seal is the incorrect dimension. was also the first time i had done a F windshield. didnt crack till i was showing someone how it didnt fit well... :angry: Quote Link to comment
darin620 Posted March 1, 2011 Report Share Posted March 1, 2011 bring it to me I will do it for free. LOL Quote Link to comment
HRH Posted March 1, 2011 Report Share Posted March 1, 2011 Usually there isn't too much of a problem, just be careful. I installed my new windshield, worked just fine. The key is to use a new rubber if you're installing a new windshield. And to get the old one out, just cut the rubber with a razor blade all the way around, then lift the windshield out. (Unless it's a newer rubber and you're replacing the windshield.) Then you have to be careful. Quote Link to comment
Loren Posted March 6, 2011 Report Share Posted March 6, 2011 west coast metric makes a couple of tools that make the install go smoothly. just search them online for a dealer in your area. one is for fitting the seal to the glass,& the other is like the rope everyone mentioned,except that it has handle that slides so you can keep a bit of tension on the cord without it digging into your hands. make sure the cord is really soaked with the soapy water so it pulls out from behind the seal without tearing. having a friend to hold the glass in place,& put a little pressure from the outside,on the area you are pulling the cord through at would be a big help also. go slowly or the seal will either want to tear,or not seat correctly. it helps to lightly press the seal onto the metal frame right behind where you are pulling the cord though as well,so that the frame seats into the groove in the seal. good luck ! Quote Link to comment
