jbirds510 Posted February 9, 2011 Report Share Posted February 9, 2011 Ok so here is the deal with a few un-needed details haha..Got a wagon (194) and the tank was totally roached...rusted beyond worthwhile repair..windows in it..the car is a 72 and the replacement tank (thanks 510 keeper!(James))is a 69 and older tank and had been sitting with fuel in it.Froze in place like obsidian in the pick up tube.I bent it up to offer a straight shot down into the tank and have been jabbing at the obstruction with a piece of welding wire with a shot of gas in there as a lubricant.Its been a couple hours and NO progress...ANY SUGGESTIONS to make this easier to get done would be soooooooo appreciated! Quote Link to comment
blue72 Posted February 9, 2011 Report Share Posted February 9, 2011 Tried carb cleaner yet? It seems to work pretty well against dried up gasoline varnish. Quote Link to comment
WAGON JON Posted February 9, 2011 Report Share Posted February 9, 2011 did you try fire? heard it might burn away the varnish! Quote Link to comment
jbirds510 Posted February 9, 2011 Author Report Share Posted February 9, 2011 update: tried carb cleaner...nothing..tried muric acid...same..nothing..decided to cut the top of the tank to remove the pick up tube and vent and will tig in a new panel and replace the old tube with a new piece of 1/4 brake line metal tube..seems to fit nice on the rubber fuel line. :) Quote Link to comment
hvyd Posted February 10, 2011 Report Share Posted February 10, 2011 I encountered a similar problem with an old 510 i had. dont cut the tank man. took mine to a radiator shop and had them hot tank it. at the time it only cost like $20. and tank was completely clean. Quote Link to comment
datzenmike Posted February 10, 2011 Report Share Posted February 10, 2011 Or a few gallons of scalding hot tap water and some lye. Quote Link to comment
jbirds510 Posted February 10, 2011 Author Report Share Posted February 10, 2011 well shoot...too late..already cut it up...made a new top piece to fill the hole i made drilled a 1/4 hole and dropped a new line in..soldered the line like the factory did it kinda and it runs line a top and is getting fuel :) Quote Link to comment
HRH Posted February 10, 2011 Report Share Posted February 10, 2011 By any chance, could you take some pictures of the inside of the tank and how that pickup line is routed? I haven't cut my spare one apart yet. Quote Link to comment
jbirds510 Posted February 10, 2011 Author Report Share Posted February 10, 2011 well I didn't think to take a picture of the inside before I welded it up.I did however take a snap of the pick up tube after it was removed.its very basic but not straight down into the tank.There is a slight bend toward the low point of the tank about 1 1/2-2" after it enters the tank. Quote Link to comment
jbirds510 Posted February 10, 2011 Author Report Share Posted February 10, 2011 Quote Link to comment
herculesinwyoming Posted February 10, 2011 Report Share Posted February 10, 2011 best cleaner for varnished gasoline.... is gasoline... some one likes ... as a punctuation......... :lol: Quote Link to comment
jbirds510 Posted February 10, 2011 Author Report Share Posted February 10, 2011 IMAG0345 by jbirds510, on Flickr IMAG0347 by jbirds510, on Flickr sorry first pic attempt. Quote Link to comment
Rustina 510 Posted February 10, 2011 Report Share Posted February 10, 2011 Or a few gallons of scalding hot tap water and some lye. That will dissolve almost anything over time. I say burn it out. But I'm a pyro. ) Quote Link to comment
