420n620 Posted April 15, 2011 Report Share Posted April 15, 2011 your carb needs to be turned 180 degrees. :lol: as for the fuel inlet, it gives you the option to have it entry either from the right or left side, make sure the one not used is plugged off. I would go with the left since thats how I see most of the fuel lines run on a weber. Quote Link to comment
phatdave Posted April 15, 2011 Author Report Share Posted April 15, 2011 I see what you two are saying. In the photo I just sat it down. It in't bolted onto the mani. Sorry. It was pissin rain when I shot that image. So given that, Mike turned 180 the biggest issue will be the tube for the dist. vacuum. More pics to follow. Quote Link to comment
phatdave Posted April 15, 2011 Author Report Share Posted April 15, 2011 your carb needs to be turned 180 degrees. :lol: as for the fuel inlet, it gives you the option to have it entry either from the right or left side, make sure the one not used is plugged off. I would go with the left since thats how I see most of the fuel lines run on a weber. Right on all issues. Thanks. Quote Link to comment
mklotz70 Posted April 16, 2011 Report Share Posted April 16, 2011 The one in the pic is the DFV.....so it's a mirror image to the DGV you have. The idle screw and choke are on the opposite side, but the throttle linkage and fuel keep the same orientation. Quote Link to comment
MicroMachinery Posted April 16, 2011 Report Share Posted April 16, 2011 ... it gives you the option to have it entry either from the right or left side... "Heh heh hmm heh" "Huh huh huh huh huh" Quote Link to comment
Charlie69 Posted April 16, 2011 Report Share Posted April 16, 2011 Okay it starts here.....why two fuel inlets ? Man thats putty huh ?! Dave the upper one is vapor return Here Dave to better explain. Quote Link to comment
420n620 Posted April 16, 2011 Report Share Posted April 16, 2011 "Heh heh hmm heh" "Huh huh huh huh huh" :mellow: :huh: ^_^ :o ;) :D :lol: Heh heh hmm heh" "Huh huh huh huh huh... :blush: Quote Link to comment
Charlie69 Posted April 16, 2011 Report Share Posted April 16, 2011 Dave keep your fuel inlet where you have it your fuel pump is on that side unlike the L motors. Quote Link to comment
phatdave Posted April 16, 2011 Author Report Share Posted April 16, 2011 found this here on Ratsun: This one has one capped off. So be it. But why does his look 180 off from mine ? This on doesnt have it . You see where its capped off ? Quote Link to comment
phatdave Posted April 16, 2011 Author Report Share Posted April 16, 2011 Sorry. :( The air mix screw is so close to the valve cover that you'll have a really hard time adjusting it. I'm not sure about the vac adv tube. I know it's been done before, so I'm sure you'll get it on....the DFV is easier. I'm pretty sure Datsunaholic has put the DG on the J......or maybe he's done the DF on the L. ???? I don't remember :( Take pics! :) The vacuum tube could prove to be a problem. Can't I plug it and get my distributor vacuum from the manifold ? Quote Link to comment
mklotz70 Posted April 16, 2011 Report Share Posted April 16, 2011 The '69 won't have the vapor return for the tank, so you can cap the top port on the carb. Tank didn't happen until after '70 or '71. Sorry, you can't simply pull the vac for the dizzy off the manifold.....it will work opposite of what it needs. You'll have full vac with the throttle closed. You want zero vac with the throttle closed. Other than the holes on the mani not matching up with the proper barrels of the carb, you can probably leave it the way you have it in the pic at the top of this page. you'll use rubber hose to get the fuel to it and a cable setup for the throttle......so it's still "do-able". Quote Link to comment
