phatdave Posted January 28, 2011 Author Report Share Posted January 28, 2011 Great to see you Dave!! I've been wondering what happened to you!! You might check on the valve adjustment....tight intake valve will cause the backfiring. Welcome back!! :) Hi Mike, I got bit by the D' Bug again. It was on Craigslist and couldn't say no when I saw and drove it. Come over and look at it and visit sometime. Still in TheValley. I will adjust the valves , like you suggest, and go from there. Quote Link to comment
]2eDeYe Posted January 28, 2011 Report Share Posted January 28, 2011 That's not what I heard it meant :P :lol: Quote Link to comment
DatDoug Posted February 1, 2011 Report Share Posted February 1, 2011 Glad to have you back Dave. I was looking @ that truck on CL Looks like a sweet one. Have fun with it & I hope to see it soon. Quote Link to comment
hang_510 Posted February 1, 2011 Report Share Posted February 1, 2011 daves not here good to have ya back! :cool: Quote Link to comment
]2eDeYe Posted February 1, 2011 Report Share Posted February 1, 2011 That's a good looking truck :cool: Quote Link to comment
phatdave Posted April 11, 2011 Author Report Share Posted April 11, 2011 I think I found some of my engine backfire problems I ve been dealing with. The carb thats on it(WAS) is a " Weber" 34 DGEC. Its not stamped like a Weber should be, so I think its a phony....also all info I can fgind about a 34 DGEC talks about them being used on 4.2 liter Jeeps. That could cause some problems. Quote Link to comment
phatdave Posted April 11, 2011 Author Report Share Posted April 11, 2011 ...and I just found out they are SOLEX. Not Weber. Quote Link to comment
phatdave Posted April 11, 2011 Author Report Share Posted April 11, 2011 I have a sparkling new Weber 32/36 manual choke coming my way. 263 $ shipped to my door. Quote Link to comment
]2eDeYe Posted April 12, 2011 Report Share Posted April 12, 2011 Brave man with that white under the hood :cool: Quote Link to comment
phatdave Posted April 12, 2011 Author Report Share Posted April 12, 2011 No balls, no blue chips. Quote Link to comment
68Datsun510 Posted April 13, 2011 Report Share Posted April 13, 2011 Damn! You got that for $800? I paid 1400 for mine, somewhat rusty, running, but needing seals, and a slippin clutch. Guess its the sacramento inflation... Post the weber jetting for the J13 when you get it sorted! =) Mine just so happens to have a DGEV! Quote Link to comment
phatdave Posted April 14, 2011 Author Report Share Posted April 14, 2011 The carb is jetted for the 1300 Suzuki Samurai. I'm thinking ( yeah I know..) it should be pretty close to dialed in. Quote Link to comment
68Datsun510 Posted April 14, 2011 Report Share Posted April 14, 2011 Close enough, if anything its probably a tad rich seeing as the suzuki probably breathes a lot more air than the 6 port J. WHatever. if it runs!! I dont know what mine is jetted for, aside from a vacuum leak and a stuck choke, it seemes to run ok. Quote Link to comment
mklotz70 Posted April 14, 2011 Report Share Posted April 14, 2011 Great to see you back Dave!!! Sweet 521!! :) Quote Link to comment
phatdave Posted April 15, 2011 Author Report Share Posted April 15, 2011 Hi Mike ! Weekend project. New 32/36. Quote Link to comment
mklotz70 Posted April 15, 2011 Report Share Posted April 15, 2011 Sweet. Don't they normally put the DFV on the J series because of the clearance at the valve cover? Make sure you take pics of how you put this on!!! I'm sure there's some other J series owners that are going to want to see this :) You might even consider a separate thread in the "how-to" section. Quote Link to comment
phatdave Posted April 15, 2011 Author Report Share Posted April 15, 2011 Mike, I hope not. Youve got me wanting to go out in the rain right now...... :blink: Quote Link to comment
mklotz70 Posted April 15, 2011 Report Share Posted April 15, 2011 Sorry. :( The air mix screw is so close to the valve cover that you'll have a really hard time adjusting it. I'm not sure about the vac adv tube. I know it's been done before, so I'm sure you'll get it on....the DFV is easier. I'm pretty sure Datsunaholic has put the DG on the J......or maybe he's done the DF on the L. ???? I don't remember :( Take pics! :) Quote Link to comment
phatdave Posted April 15, 2011 Author Report Share Posted April 15, 2011 Sorry. :( The air mix screw is so close to the valve cover that you'll have a really hard time adjusting it. I'm not sure about the vac adv tube. I know it's been done before, so I'm sure you'll get it on....the DFV is easier. I'm pretty sure Datsunaholic has put the DG on the J......or maybe he's done the DF on the L. ???? I don't remember :( Take pics! :) Quote Link to comment
mklotz70 Posted April 15, 2011 Report Share Posted April 15, 2011 I got ya. Usually, they need to have the throttle arm on the other side and the fuel hose on this side. Looks like you have the tall adapter? That's good too, in case you end up having to put the throttle arm on the bottom to be able to pull toward the fender. I'm looking forward to seeing how you do it. Too many times, guys(like me) read about all the hurdles and then believe them with out even trying it. Then someone(like you) comes along and just does it like it wasn't a problem. :) Keep taking pics :) Quote Link to comment
phatdave Posted April 15, 2011 Author Report Share Posted April 15, 2011 I got ya. Usually, they need to have the throttle arm on the other side and the fuel hose on this side. Looks like you have the tall adapter? That's good too, in case you end up having to put the throttle arm on the bottom to be able to pull toward the fender. I'm looking forward to seeing how you do it. Too many times, guys(like me) read about all the hurdles and then believe them with out even trying it. Then someone(like you) comes along and just does it like it wasn't a problem. :) Keep taking pics :) Mike, I dont have a clue how to do it. As for the screw you talked about, I guess I could adjust it with the valve cover off . Honestly, I was going to search here on the board for help and information. I feel really strong this will cure the backfiring. I think the 34 was jetted for a 3.2 Jeep and might be in need of rebuilding to boot. Whoever installed it failed to use any sealer or threadlok the studs and allen screws. As far as if I have a tall spacer ?..I dont know.Spacers and gaskets under the carb are about a total of 7/8 " thick. Stay tuned. ( thats a bad pun ,huh ?!) Quote Link to comment
phatdave Posted April 15, 2011 Author Report Share Posted April 15, 2011 Okay it starts here.....why two fuel inlets ? Man thats putty huh ?! Quote Link to comment
phatdave Posted April 15, 2011 Author Report Share Posted April 15, 2011 Okay it starts here.....why two fuel inlets ? Man thats putty huh ?! found this here on Ratsun: This one has one capped off. So be it. But why does his look 180 off from mine ? Quote Link to comment
