AuosGnaf Posted January 25, 2011 Report Share Posted January 25, 2011 Ok so I installed 280zx struts and mounted the driver side tire and noticed it's rubbing the strut. Checked the passenger side and there's clearance. Checked the hubs and wheel bearings and they look fine. Nothing is bent or off centered. Keep in mind the wheels are 0 off sets. I don't know why it's only the driver side, but it's only the driver side. Any help will do. Oh yeah, I've already removed the struts twice and same results...tire rubbing the strut. AHHH! Thanks guys! Quote Link to comment
D52E Posted January 25, 2011 Report Share Posted January 25, 2011 Sorry to hear you are having trouble with your 280ZX strut mod. I would first confirm you have a matched set of wheels by swapping them side to side to make sure the concern is not the unlikely case of a miss-matched wheel set. Second, I would swap the Hubs side to side and see if the rubbing follows the hub (just in case you have the wrong hub). If the rubbing continues on the same side after these two checks, its possible you may have one of two conditions: 1) Previous accident damage of the strut donor vehicle causing the spindle and strut tube to bend 2) The previous owner of the strut donor car replaced the strut assembly with the wrong part. The spindle is an integral part of the strut assembly. The relationship of the strut tube and spindle are constant because they are one piece. I hope other members can chime in with suggestions to correct any mistakes in my advice. Good luck Quote Link to comment
Laecaon Posted January 25, 2011 Report Share Posted January 25, 2011 Also you say 0 offset, but how wide is the rim, and how tall? Tire size too. Quote Link to comment
DRIVEN Posted January 25, 2011 Report Share Posted January 25, 2011 There are two different spindle angles on ZX struts. One is 7 degree and the other is 10(IIRC). Might be early vs late? That's why some guys can just bolt in ZX struts and others need to use camber plates. I was at Mike Klotz's place when we ran across that. It may be mentioned in his 10 page strut mod thread. It looks like you may have one of each style. Quote Link to comment
DISLEXICDIME Posted January 25, 2011 Report Share Posted January 25, 2011 Make sure the. Strut tube is not bent back in the day alignment guys use to bend the strut tube a degree or 2 Quote Link to comment
Pacific coast Datsun Posted January 25, 2011 Report Share Posted January 25, 2011 Thanks guys for the input. Soua is a friend & ive been trying to help him with this issue. Hes running 15 inch Infiniti I 30 rims, tires are 195-50-15. Quote Link to comment
the510keeper Posted January 25, 2011 Report Share Posted January 25, 2011 I had the same problem and the strut tube was bent. The 510 that had the 280zx struts on it was hit hard. Couldn't tell until you put the strut on the next car and tired to bolt up the wheel. Quote Link to comment
HRH Posted February 14, 2011 Report Share Posted February 14, 2011 The 280zx struts I got are at two different angles. Had the same issue with the fatty 205 wide hoosiers. Just lathed off a little bit though, only like a 1/16th into the tire, which was not a big enough deal to do anything. Camber plates don't help you there because it only changes camber, not the spindle angle. Alignment is perfect, and noted as one camber plate is on 6, and one is on 7. Quote Link to comment
