Flipper Posted December 16, 2010 Author Report Share Posted December 16, 2010 All things equal, displacement beats shorter stroke. Running 1770 in a 2300 limit is just wrong headed. You are giving away too much. Find a Z20E it has stock flattop pistons and 6" rods and the crank is fully counter weighted so it will rev all day. Stick a L20B head on it or swap into an L20B, all Nissan parts. Over bore the L20B block and install Z22 crank/rods/pistons for and LZ22. Thank you - sound like GREAT ADVICE - any idea what Horse power that be ? Quote Link to comment
troyt Posted January 3, 2011 Report Share Posted January 3, 2011 Here is a link to a guy in Missouri who used to be on this forum but seems to no longer be active here. He races local fairground dirt ovals in the 4 cyl class in a 510 Wagon. As far as I'm concerned, this is the only car I would build to your class's rules if ya wanted to be cool as well as fast. But then again, I'm a little biased... Weld up the rear end, paint it red, pitch it sideways, and get it dirty! wagon dirt oval racer Quote Link to comment
dvboth Posted January 3, 2011 Report Share Posted January 3, 2011 240z 260z 280z 620 510/610/710 wagon b210 i would go with a z, but a wagon would be really cool seeing it rip up the track with the z you could have a fuel injected stock engine. uhhhh! Z's have independent suspension!! Quote Link to comment
620racer Posted January 5, 2011 Report Share Posted January 5, 2011 if you want to build the truck this will go to the front. Quote Link to comment
Eric Garside Posted February 10, 2011 Report Share Posted February 10, 2011 All things equal, displacement beats shorter stroke. Running 1770 in a 2300 limit is just wrong headed. You are giving away too much. Find a Z20E it has stock flattop pistons and 6" rods and the crank is fully counter weighted so it will rev all day. Stick a L20B head on it or swap into an L20B, all Nissan parts. Over bore the L20B block and install Z22 crank/rods/pistons for and LZ22. Can you clarify this? Is putting the Z22 parts in the L20B another option instead of using the afore mentioned Z20E parts? Thanks Eric Quote Link to comment
bonvo Posted February 11, 2011 Report Share Posted February 11, 2011 from what ive seen in the rules you posted a 1200/ b210/ 210(b310) would be your best bet very small light weight the biggest displacement motors to come stock didnt come close to the max displacement you list i personally would take a b210 2 door sedan drop a built l18 in it 280zx front strut swap with coilovers fit the widest wheels you can on it so you get as much traction as possible and beat the pants off of the other boys at the track Quote Link to comment
Dirttrack510 Posted April 3, 2011 Report Share Posted April 3, 2011 510 WAGONS ARE NOT INDEPENDENT REAR SUSPENSION, SOLID REAR AXLE. I RACE ONE NOW. DROP IN A L20B WITH A L16 HEAD AND GO TEAR UP THE TRACK. Quote Link to comment
