primo74620 Posted September 30, 2010 Report Share Posted September 30, 2010 I bought a 74' 620 about 2 months ago. When I saw the truck is ran fine. The day I picked it up it stalled on me at a stop when a press on the clutch to stop, it fired right up but I had to keep my foot on the accelerator to keep it from turning off. As I drove it, it started to spudder as if it was out of fuel and I went straight to the gas station and fueled it up. The problem did not go away. A few days past and it kept acting up and eventually wouldn't even fire up (engine turns). I was told that I had no spark at the coil,so I installed a new coil and it still has no spark at the coil. I need help fast, I am getting really frustrated because I have always wanted one of these trucks and now this. Quote Link to comment
banzai510(hainz) Posted September 30, 2010 Report Share Posted September 30, 2010 You ck the points. Since a 74 had points ck to see if the gap is correct. If points are alwas closed the coil will not fire. take this to a old VW shop. they might be able to help w/o ripping you off. Quote Link to comment
primo74620 Posted September 30, 2010 Author Report Share Posted September 30, 2010 You ck the points. Since a 74 had points ck to see if the gap is correct. If points are alwas closed the coil will not fire. take this to a old VW shop. they might be able to help w/o ripping you off. Yeah I installed new points and condenser. But I am not sure if a gapped it right. Quote Link to comment
bananahamuck Posted September 30, 2010 Report Share Posted September 30, 2010 kiss Quote Link to comment
datzenmike Posted October 1, 2010 Report Share Posted October 1, 2010 I was told that I had no spark at the coil,so I installed a new coil and it still has no spark at the coil. Without finding out for yourself, this, has cost you for a new coil you didn't need. The old Datsuns need owners that are willing to work on them, maintain them and learn about them, or if you have lots of money you will become a mechanics dream. Very generally you need two things for them to run. ONE/ spark. Take one of the spark plug leads off and stick an old plug or a screw driver in the end and lay on the valve cover. Crank motor over.... you should see a spark jump from the wire to the grounded valve cover. If no spark this will have to be investigated further. Possible causes: Ignition switch bad, coil bad, distributor cap or rotor bad, points worn or out of adjustment, bad wires. TWO/ gas. Take air filter off and look at front of carb. There is glass cover with an etched line or a metal cover with small glass bull's eye with a dot to represent the proper fuel level. If there is fuel probably everything is fine. If no fuel this will have to be investigated further. Possible causes: empty tank, tank not vented or bad gas cap, clogged filter, bad fuel pump, clogged inlet screen or needle valve, float stuck in up position, Nine times out of ten one of these two things is missing. It is very possible to have both but still not run, but knowing eliminates a lot of other possibilities. Quote Link to comment
primo74620 Posted October 1, 2010 Author Report Share Posted October 1, 2010 Well banzai510, Thanks for your help. I checked the points and regapped them and the truck started right up. Datzenmike: I also thank you for the info. I did trouble shoot the truck as much as I could and I was getting frustrated. Quote Link to comment
moparvwfreak Posted October 21, 2010 Report Share Posted October 21, 2010 here is something i would suggest. convert it to electronic ignition and do away with the points. i did this on my 73 and i wouldn't have it any other way. no messing around with points and upkeep is MUCH easier. Quote Link to comment
Suspect Posted October 21, 2010 Report Share Posted October 21, 2010 On my 620, I've had the wire the goes threw the distributor to the point corrode to where it would get some spark but not enough to run. That was frustrating until I figured it out 2 weeks later, trial and error and learning as you go seems to work for me. Quote Link to comment
Z-train Posted October 21, 2010 Report Share Posted October 21, 2010 here is something i would suggest. convert it to electronic ignition and do away with the points. i did this on my 73 and i wouldn't have it any other way. no messing around with points and upkeep is MUCH easier. Ding,ding DING!!!! Quote Link to comment
