AuosGnaf Posted September 8, 2010 Report Share Posted September 8, 2010 Don't know if this has been asked before, but here it is.... How to remove a stock KA shifter? I found a S13 shifter and was wondering if it would fit a S14 tranny? Not only that how do I remove it so I can install it (if it fits) into mine? There's no screws or anything holding it in place beside the plate. Unless that's it, but I'm not sure. Keep in mind I don't want to go the short shifter route. I just need the shifter. Any help will do. Thanks in advance. S. PS. If you can break it down for me that would be great. Quote Link to comment
datzenmike Posted September 8, 2010 Report Share Posted September 8, 2010 There's a snap ring that has to be pried out. Quote Link to comment
Docsis510 Posted September 8, 2010 Report Share Posted September 8, 2010 its not easier to just unscrew the bolts on the plate and take the hole thing?? Quote Link to comment
521rat Posted September 8, 2010 Report Share Posted September 8, 2010 its not easier to just unscrew the bolts on the plate and take the hole thing?? thats what i did when i installed the short shifter on my 240. dont see why it would be any different installing another stock shifter Quote Link to comment
izzo Posted September 8, 2010 Report Share Posted September 8, 2010 Sawzall works good too Quote Link to comment
Pacific coast Datsun Posted September 8, 2010 Report Share Posted September 8, 2010 You guys are killing me with the "cut it out" comments jeez! Theres a "C" clip / snap ring that needs to be removed then it'll slide right out. When i removed mine i bought a cheapo needle nose plier then ground down the ends so they fit into the clip, squeeze the pliers together & lift out. Im running a 240sx shifter in my HB & it is a few inches shorter. Quote Link to comment
78kingcab Posted September 8, 2010 Report Share Posted September 8, 2010 just take the six bolts out, it does'nt get easyer than that... Quote Link to comment
AZhitman Posted September 8, 2010 Report Share Posted September 8, 2010 ^ This. No need to mess with a snap ring. S13 and S14 transmissions are identical. Quote Link to comment
AuosGnaf Posted September 11, 2010 Author Report Share Posted September 11, 2010 Nice! Thanks guys! Quote Link to comment
