Mr Raiders Posted August 17, 2010 Report Share Posted August 17, 2010 Ok I think I figured out why my truck was making a clunking sound every time I started moving. Anyone know if I can replace this (Drive Shaft Center Support Bearing) myself? and if so anyone seen any good deals on them online? Also if anyone has replaced this part before are there any tips that might make it a lot less of a pain to do? any help or suggestions would be great. Thanks everyone Quote Link to comment
datto510 Posted August 17, 2010 Report Share Posted August 17, 2010 Whoa man.... were you driving it like that? Quote Link to comment
thisismatt Posted August 17, 2010 Report Share Posted August 17, 2010 That's totally fiiiiine Quote Link to comment
datsunaholic Posted August 17, 2010 Report Share Posted August 17, 2010 It's been covered here before. The rubber part is generally NLA. The bearing isn't, but your bearing probably isn't bad. Datzenmike had good results wrapping the bearing with strips of conveyor belt; old inner tube or strong rubber matting would work too. Wrap and clamp. Quote Link to comment
izzo Posted August 18, 2010 Report Share Posted August 18, 2010 Or... get a 1 piece drive line in there... Quote Link to comment
lynchfourtwenty Posted August 18, 2010 Report Share Posted August 18, 2010 i too wrapped mine in some rubber stuff. havent put more then a few hundred miles on it tho.. im neglective.. Quote Link to comment
Braden Posted August 18, 2010 Report Share Posted August 18, 2010 can someone please cover how to swap to a one piece driveline? is it the goon shaft that bolts right in?? Quote Link to comment
ariascarlos1990 Posted August 18, 2010 Report Share Posted August 18, 2010 can someone please cover how to swap to a one piece driveline? is it the goon shaft that bolts right in?? Take the whole driveline to a driveline shop and tell them you want a one piece. Should be around $100. Quote Link to comment
datzenmike Posted August 18, 2010 Report Share Posted August 18, 2010 One piece are fine as long as the drive shaft does not hit the cross member when the diff drops down when hitting a sudden dip in the road.. Quote Link to comment
Mr Raiders Posted August 19, 2010 Author Report Share Posted August 19, 2010 Thanks everyone, great idea's. Anyone happen to have a picture of after they wrapped there's? Thanks again for all the replies. Quote Link to comment
jefe de jefes Posted August 19, 2010 Report Share Posted August 19, 2010 No junkyards in your area? Quote Link to comment
