Voleurz Posted December 22, 2007 Report Share Posted December 22, 2007 Hey, Ive decided to start a project thread.. cause i felt like it. ive got a pretty clean truck to work with and ill update as soon as i get stuff done to it. planning on some nice rims to show off the brakes and buff up the paint a bit. firstly i have to fix a bad body mount doing that after christmas sometime. first up need i say more? then this is going on this updates will be posted when they happen. next update expected around the 29th. cheers. -eric Quote Link to comment
datsun dreamer Posted December 22, 2007 Report Share Posted December 22, 2007 Nice Stock Truck:D Interior looks in good shape! Cant wait to see her lowered:D:D. Quote Link to comment
Pacific coast Datsun Posted December 23, 2007 Report Share Posted December 23, 2007 YESS! another 74 build up :cool: Quote Link to comment
Voleurz Posted December 24, 2007 Author Report Share Posted December 24, 2007 i just got a new water pump for it gunna wait for some good weather to change it mines making some noise ive changed the thermostat still looking for a master cylinder (not really sure what im looking for) trooper rear brake set up gunna do the brakes all at once then still need some nice wheels to put on it ill ditch the seat cover and just lay down a sweet hippie blanket or something. maybe buckets. first things first body mount fix which me and a buddy will do between christmas and new years. -eric Quote Link to comment
datzenmike Posted December 24, 2007 Report Share Posted December 24, 2007 There are differences between a disc and a drum master cylinder. There is a residual pressure valve to keep a slight pressure in the system. On drum brakes where the shoe has to travel some distance to reach the inside of the drum a residual pressure of 10 lbs is common but disc brake pads that are in contact with the rotor are usually about 2 lbs. the wrong valve would cause the disc pads to rub excessively when not in use. I guess the valve could be changed or a rear disc brake master could be used. Some of the 280 zx cars had rear disc brakes I think. Quote Link to comment
Icehouse Posted December 24, 2007 Report Share Posted December 24, 2007 I love the truck!! super clean to!! What happened to the body mount? Quote Link to comment
Voleurz Posted December 24, 2007 Author Report Share Posted December 24, 2007 thanks, i think it must be the NOS floormats that make it. the 2 body mounts are shot. both passenger ones actually. The P/Owner tried to fiberglass the passenger floorboard one and just made a mess. theyre both getting new sheetmetal welded in on boxing day goin up to a buddies house. todays update changed the water pump in 30 minutes thanks to my new set of ratchet wrenches. new personal best. Quote Link to comment
Icehouse Posted December 25, 2007 Report Share Posted December 25, 2007 AWWW you gotta love PO's they do the best work :( I hate the ones that know how to mix fiberglass the works... Ratcheting wrenches are the best!!! Quote Link to comment
]2eDeYe Posted December 25, 2007 Report Share Posted December 25, 2007 Nice truck, can't wait to see the metamorphasis :cool: Ratchet wrenches rule :D Quote Link to comment
Voleurz Posted December 26, 2007 Author Report Share Posted December 26, 2007 ya ratchet wrenches are awesome. update body is staright fixed the body mount went from this: (see how the bullet side dont line up?) to this now i can lower it. Quote Link to comment
PtheDude Posted December 27, 2007 Report Share Posted December 27, 2007 Dude, If I knew where you live I come swipe that bed! REALLY nice! Musta had a top on it! you ever bag on the truck, let me know, go KC or something, I want first crack at the sale. Red is the color or WINNERS! Quote Link to comment
Voleurz Posted December 27, 2007 Author Report Share Posted December 27, 2007 Dude, If I knew where you live I come swipe that bed! REALLY nice! Musta had a top on it! you ever bag on the truck, let me know, go KC or something, I want first crack at the sale. Red is the color or WINNERS! haha im keeping the truck for a little bit atleast. it did have a huge canopy/wood enclosure thing on it if i find a kc im buyin it but only 78 79. Quote Link to comment
Voleurz Posted January 2, 2008 Author Report Share Posted January 2, 2008 got some landcruiser chromies. the price was right so a litle bit of steel wool and autosol and they look half decent. got em mounted today fronts are 205 60 rears 215 65 Quote Link to comment
Voleurz Posted January 9, 2008 Author Report Share Posted January 9, 2008 the pile grows... almost ready to do the swap. gunna see if the 50 amp alternator will fit without having to change the coolant inlet. the guy said i shouldnt have too... Quote Link to comment
iron stomach Posted January 9, 2008 Report Share Posted January 9, 2008 any pics of the new front body mount by chance, if its not too much trouble. mine have like a "hump" around the bolt hole and was wondering if i can just make it flat like you did your rear when i replace it. (if any of that makes sense. lol) thanks! Quote Link to comment
Voleurz Posted January 9, 2008 Author Report Share Posted January 9, 2008 i actualy never got around to doing the floorboard ones.. i just had to tow it home cause it was running.. and then the fuseable link broke but i could fix that but then it was still not starting.. i think it was flooded cause i could smell gas and the float was full. ill try start it in a bit see what happens.. stupid carbs. Quote Link to comment
Voleurz Posted January 10, 2008 Author Report Share Posted January 10, 2008 points are done.. gunna see how i can fix that later... Quote Link to comment
]2eDeYe Posted January 10, 2008 Report Share Posted January 10, 2008 Matchbox EI or Petronix are the easiest 2 options IMHO Quote Link to comment
Voleurz Posted January 10, 2008 Author Report Share Posted January 10, 2008 http://www.shopatron.com/product/part_number=1741/591.0 that the one? im not sure if i can afford it right now with my brake upgade almost being under way and so on.. then again maybe now is the perfect time to do it.. i might just have to redo the points for now.. anytips? it isnt really anything in the faq and a search turns up nothing or maybe i will get it i dont know. so much shit thats been upgraded already and going to be grrrr. Quote Link to comment
Voleurz Posted January 10, 2008 Author Report Share Posted January 10, 2008 ok i talked to my brother who still owes me some cash from a toyota 4x4 he got off me so i will try and get the point thing from pertronix hopefully it doesnt cost all the much up here. Quote Link to comment
]2eDeYe Posted January 10, 2008 Report Share Posted January 10, 2008 That's the one ;) Quote Link to comment
Voleurz Posted January 11, 2008 Author Report Share Posted January 11, 2008 it costs a whole dollar more up here... this thing is turning into quite a money pit. Quote Link to comment
]2eDeYe Posted January 11, 2008 Report Share Posted January 11, 2008 Whatever you do, don't add up what your spending....:D Quote Link to comment
Voleurz Posted January 11, 2008 Author Report Share Posted January 11, 2008 ok so that rubber boot on the wires inst big enough.. and the wires arent long enough.. i guess add some 20 guage to the wires.. but what about the rubber booty? Quote Link to comment
RacnJsn95 Posted January 12, 2008 Report Share Posted January 12, 2008 It would try to find a matchbox EI distributor before I bought the Pertronix setup... You can usually get them cheaper... Look in junkyards, or maybe ebay? Quote Link to comment
