laniadude Posted December 12, 2007 Report Share Posted December 12, 2007 The wipers on my truck are F***ed up...When they are on, the drivers side wiper swings all the way off the window....then when they are off, it doesn't go all the way down....Until I push them down manually..It has a lot of play in it when I move them with my hnds.. Where can I find the bushings for them???? Link to comment
makya Posted December 12, 2007 Report Share Posted December 12, 2007 All the 620's I've had can be moved like that. It sounds like you just need to loosen the nut holding the arm down and re-postion it. Link to comment
yello620 Posted December 12, 2007 Report Share Posted December 12, 2007 Sounds like you need to remove the cowl cover and find exactly which peice you need and see if the dealer can still get them of try nissanparts.cc or try the junk yard. Jason Link to comment
datsunfish Posted December 12, 2007 Report Share Posted December 12, 2007 I have the same problem.I dont know if it had bushings to begin with but it needs them now.The main shaft is inside of a sleeve and just flops around.If I cant find em I will mod some and let you know. Link to comment
mklotz70 Posted December 12, 2007 Report Share Posted December 12, 2007 if it's the "bushings" the shafts that the arms connect to will wiggle around. What you're describing will have more to do with the linkage. If it's the plastic ball sockets, I'm pretty sure you can match them up at the local parts store on the wall of "HELP" parts. I'm pretty sure somebody did that on nwde....so you might check there for info. Link to comment
]2eDeYe Posted December 12, 2007 Report Share Posted December 12, 2007 That was me on nwde lol, did a write up and everything.... :D Link to comment
datzenmike Posted December 12, 2007 Report Share Posted December 12, 2007 I did take the 'spindles' apart and grease them with white lithium grease. They tend to collect dirt and water in them and get tight. This made them a little faster. Don't use ordinary grease as it will mix with water and turn into a grey goo. I put 720 spindles on but they aren't a direct swap. I think they have 3 bolts instead of 2?... something, may be larger bolts too. The linkages won't swap because the wipers are in a different position, wider apart. Link to comment
laniadude Posted December 12, 2007 Author Report Share Posted December 12, 2007 Thanks...I'll post up results after I fix the issue.... What is that website???nwde?? Link to comment
pope_face Posted December 12, 2007 Report Share Posted December 12, 2007 http://nwde.org... North West Datsun Enthusiasts... I think I can spell... Link to comment
laniadude Posted December 12, 2007 Author Report Share Posted December 12, 2007 found it thanks....Although I can't find the how to that redeye did on this issue... Link to comment
]2eDeYe Posted December 12, 2007 Report Share Posted December 12, 2007 I don't think it survived the changover...I have all the pic's though. I can redo when I get some time. Link to comment
laniadude Posted December 12, 2007 Author Report Share Posted December 12, 2007 thanks redeye ...i'll be looking forward to seeing them.... Link to comment
]2eDeYe Posted December 13, 2007 Report Share Posted December 13, 2007 I found the pic's but they are locked in an .mhtl file. I don't have a way to host them anymore. If you PM me I can email you the file. It will open with explorer. Does anyone know how I can save the pics individually from an .mhtl? Bleach? Thomas? Link to comment
laniadude Posted December 13, 2007 Author Report Share Posted December 13, 2007 do you mean .html???? If so, then you can just right click on each photo and click "save as" then save them to your "My Pictures" folder....Same as anyother picture you see on the internet.....If it allows you to right click on it, then you can save the picture...... example : I saved your signature pic to my computer Link to comment
]2eDeYe Posted December 13, 2007 Report Share Posted December 13, 2007 No I meant .mhtl...it's an archived webpage format. All the pic's are embedded and have the same location properties, which is the .mhtl file. Link to comment
Bleach Posted December 13, 2007 Report Share Posted December 13, 2007 I did a writeup too... with pics I'm not sure where the writeup is, and I just looked for pics on this computer and did not find any. I got the "HELP!" parts from Autozone. They have a little box of bushings for wipers. You pick out the two round plastic bushings from the kit. It has four tabs on the bottom of each. Trim two of the four tabs off (opposite each other) Replace those parts, then take the wiper arms off (don't just force them down) and then reinstall at the correct 'off' position on the windshield. You may have already stripped out the base of the wiper linkage. Link to comment
]2eDeYe Posted December 13, 2007 Report Share Posted December 13, 2007 Bleach, do you know how to get pic's from webpage archive? Nice sig link :D Link to comment
71-521 Posted December 13, 2007 Report Share Posted December 13, 2007 if you can view them, then just use Easy Screen Capture to select the area you want to save and then save it to either a .bmp or .jpg file...you will have to do each individually but it's a way to get it done... http://www.longfine.com/ Link to comment
]2eDeYe Posted December 14, 2007 Report Share Posted December 14, 2007 I did use some grease on 'em like Mike said. Link to comment
]2eDeYe Posted December 14, 2007 Report Share Posted December 14, 2007 Haha! Thanks 71-521 dood :cool: Pics are kinda small but they show up. Maybe, laniadude can get some up to date pics :D Link to comment
laniadude Posted December 14, 2007 Author Report Share Posted December 14, 2007 i will take some pics when I do change them out...thanks!!!!! Link to comment
