Skib Posted May 13, 2010 Report Share Posted May 13, 2010 A quick write up on valve stem seals if your L is burning oil on start up and acceleration its probably your seals. they get old, dry and hard and start to leak. you can do it head on or off. if your heads on stuff some rope in the cyl with the piston all the way up to hold the valves in and then remove your valve spring. but thats already pretty common knowledge around here so Im not really covering that part. (if its not common knowledge to you, go look it up and come back :D ) the old one on the left cracked and broke when removed and was hard and brittle. the new seal on the right and a short video on how to actually change the seals. very easy to do. Quote Link to comment
D@tsuks Posted May 13, 2010 Report Share Posted May 13, 2010 Wow never heard of stuffing rope in the cyl. Have to try that next time. I've always used compressed air. Rig up a compression gauge hose with a fitting and use my compressor at 80 - 90 psi and the valves will never move. of course valves need to be shut first. Quote Link to comment
datzenmike Posted May 13, 2010 Report Share Posted May 13, 2010 Wow never heard of stuffing rope in the cyl. Have to try that next time. I've always used compressed air. Rig up a compression gauge hose with a fitting and use my compressor at 80 - 90 psi and the valves will never move. of course valves need to be shut first. Also if there is loss of air pressure, leak or whatever you have a problem. The rope trick allows you to leave it overnight for as long as you want or do it on the side of the road. Quote Link to comment
Creepy Cruiser Posted May 13, 2010 Report Share Posted May 13, 2010 Very nice. And great vid! Quote Link to comment
Unclejesse88 Posted May 14, 2010 Report Share Posted May 14, 2010 Wow never heard of stuffing rope in the cyl. Have to try that next time. I've always used compressed air. Rig up a compression gauge hose with a fitting and use my compressor at 80 - 90 psi and the valves will never move. of course valves need to be shut first. As soon as the rocker assembly is off, all the valves are closed. Quote Link to comment
]2eDeYe Posted May 14, 2010 Report Share Posted May 14, 2010 As soon as the rocker assembly is off, all the valves are closed. There is no 'assembly', all the rockers are individually installed under the cam. ;) Quote Link to comment
Braden Posted September 27, 2010 Report Share Posted September 27, 2010 i know this thread is older but how may i ask do you get the valve springs back on while the head is on the engine, i had a hell of a time using every kind of valve spring compressor you could think of while the head was off! Quote Link to comment
Skib Posted September 27, 2010 Author Report Share Posted September 27, 2010 i know this thread is older but how may i ask do you get the valve springs back on while the head is on the engine, i had a hell of a time using every kind of valve spring compressor you could think of while the head was off! I use this kind of compressor while the head is on. Quote Link to comment
zerow Posted September 27, 2010 Report Share Posted September 27, 2010 ...or do it on the side of the road. What about camshaft removal, and re-timing the motor? The side of the road is not really a great place to be figuring this out... Great vid! Quote Link to comment
Skib Posted September 27, 2010 Author Report Share Posted September 27, 2010 What about camshaft removal, and re-timing the motor? The side of the road is not really a great place to be figuring this out... lol the side of the road is never a great place to figure anything out :P but if you had to you could Quote Link to comment
78kingcab Posted September 27, 2010 Report Share Posted September 27, 2010 great video and work... :D Quote Link to comment
Creepy Cruiser Posted September 27, 2010 Report Share Posted September 27, 2010 Since this thread has come alive again, I'd just like to add. If you're doing a KA, (and the head is still on the motor), this is the killer spring compressor to use. (the bridge style) http://www.toolbaydi...ion=1&size=full Quote Link to comment
