rb26 Z
Stony
  • 10 months later...
  • Replies 239
Black car sold here's an update on the red car.
Worked a bit on the car this weekend, everything is final fit now. Missing a couple clamps here and there and i still have to redo the breather stuff. but overall all im lacking is wiring and fuel system plumbed from cell to engine bay. my stock gas pedal wont fit any more. So i will need some sort of custom pedal. All the brake lines are done just need pedal hooked up and bled. Here are some pics. DSC06321.jpgDSC06318.jpgDSC06322.jpgDSC06323.jpgDSC06330.jpgDSC06333.jpgDSC06335.jpgDSC06338.jpg Waiting on the ZCCJDM ZGR wing to be completed. that will be the only body addition prior to paint in december.
one little update;>
I will be driving to and from the track and around town and to car shows on nice days ;>
After i get it running its getting torn back down to go to the body shop for paint in december!!!
  • 3 weeks later...
Well got the ZCCJDM.com tail today
Looks awesome!!! its alot taller then the carbon fiber tail pics make it look.
anyways here they are.
Here is a video hopfull that will show the finish. if you had a white car you could litterally use this as is.
Considering the Gnose now very heavily!!!
Well got the breather mod done.
I cut off the existing piece of the cam cover down to the top of the cover. There is still plenty of material there to tap. Then I used a 7/8 drill bit and tapped it for 3/4 NPT. FYI 29/32 drill bit is what is supposed to be used when using a 3/4 NPT tap. but with aluminum it was close enough.
In the future for anyone else I would highly recommend using -10 line and fittings the -12 stuff was very tight and a PITA to get on and off.
Here some pics.
  • 1 month later...
how ya like the sparrow tail?
Iv been thinkin about going and picking one up from Brian for my Z
I like the way it looks.
it should look really good once its painted and mounted.
  • 2 months later...
Well i succeeded in making more bodywork for myself. no i will be able to go back to the wider wheels ;> hopefully will be painted by the end of may. going to UAE for 6 months in august
  • 1 month later...
On the trailer going to paint shop
All the parts sealed.
Base coat applied to parts
Clear coat applied.
Cant believe i may have a car ready to put back together in a month or so !!!!!
Couple more pics from today
BTW if you ever use POR15 be sure to use gloves…. Because that shit don’t come off your skin!!!
Got both wheel wells welded up. Reinforced the rear section of the rear ¼ and did final fitting of the left side.
