darrel Posted April 4, 2010 Report Share Posted April 4, 2010 as mentioned in the "what I did to my 620 today" I picked it up yesterday. 500 miles rt and $600 later. http://i30.photobucket.com/albums/c301/dlh2460/620%20kc%20pu/2010-03-30182715.jpg http://i30.photobucket.com/albums/c301/dlh2460/620%20kc%20pu/2010-03-30182548.jpg http://i30.photobucket.com/albums/c301/dlh2460/620%20kc%20pu/2010-03-30145035.jpg Quote Link to comment
darrel Posted April 4, 2010 Author Report Share Posted April 4, 2010 It does run. it had a fuel leak but that was a fuel hose. The smog pump is gone and the egr and tube plugged. It does have a few rust spots on a respray, but still a very solid truck. It was on craigslist for $400, but I told the guy I would give him $600 if he could hold it till I checked it out. He had a lot of calls and mine swayed him. ;-) There was another one in Tucson that would have been better, but I couldn't get out there soon enough. Quote Link to comment
pharouh Posted April 5, 2010 Report Share Posted April 5, 2010 Nice score! Are you going to keep those wheels? They look a little strange on a 620. JMHO. Quote Link to comment
darrel Posted April 5, 2010 Author Report Share Posted April 5, 2010 Nice score! Are you going to keep those wheels? They look a little strange on a 620. JMHO. They are 6 lug nissan mag wheels. btw, anyone have a center cap? I'm missing one. And yeah, When I first saw them I was thinking they were a little ugly, but they are still n issan mags. and the rust. http://i30.photobucket.com/albums/c301/dlh2460/620%20kc%20pu/2010-03-31093852.jpg http://i30.photobucket.com/albums/c301/dlh2460/620%20kc%20pu/2010-03-31093952.jpg http://i30.photobucket.com/albums/c301/dlh2460/620%20kc%20pu/2010-03-31094021.jpg Quote Link to comment
pharouh Posted April 5, 2010 Report Share Posted April 5, 2010 Ebay usually has some. Type in 'nissan cap' or 'nissan rim'. Keep posting! Quote Link to comment
darrel Posted April 5, 2010 Author Report Share Posted April 5, 2010 Thanks P, I haven't begun to search for any parts. That will change soon. A couple of salvage yards had about a 1/2 doz 620's between them here, but now they're all gone. I'm sure something will show up soon. Quote Link to comment
Farmer Posted April 5, 2010 Report Share Posted April 5, 2010 Thats a great find and a reasonable price too. larry Quote Link to comment
banzai510(hainz) Posted April 5, 2010 Report Share Posted April 5, 2010 get soem better wheels and buff that sucker out. Clean truck. Quote Link to comment
darrel Posted April 5, 2010 Author Report Share Posted April 5, 2010 I was told the wheels may have come from an '89 hard body 2wd. I'm sure the wheels will grow on you, they do look a little different. I had a key cut by code and there didn't seem to be any damage from using a leatherman screw driver to pick it to start. The key only comes out when it's in the "OFF" position as it should. I did take it for a spin around the block, I'll have to get used to the sound of all the creaks and rattles old trucks have. There might be an exhaust leak as well. I still need to get it on a lift to check it out further and change all the fluids. Quote Link to comment
Z-train Posted April 5, 2010 Report Share Posted April 5, 2010 There was another one in Tucson that would have been better, but I couldn't get out there soon enough. Ya shoulda said something. Quote Link to comment
darrel Posted April 6, 2010 Author Report Share Posted April 6, 2010 Ya shoulda said something. I was concentrating on craigslist and forgot all about this site. Besides I couldn't ask someone to wait for at least 2 weeks before I could make it out there. I'm kinda glad the first one didn't work out. I think the truck I got is a great starting point. Quote Link to comment
darrel Posted April 11, 2010 Author Report Share Posted April 11, 2010 I picked up a brahma shell for free today. That will go well with the bed slide I will be making. Quote Link to comment
darrel Posted April 23, 2010 Author Report Share Posted April 23, 2010 I got the truck up on a lift today adjusted the valves and it passed emissions :-D Carrier bearing is toast, needs RR axle seal, once the front pads wear down it will need new rotors, fix wiring rats nest at the rear and rf parking light, egr is gone as is the air pump, missing some linkages on the carb, it's a wonder it even passed the sniffer test. There is a broken valve cover bolt that has been "worked on". If I don't replace the head, i will at least take the old one off and have the bolt hole fixed. Gas tank isn't original, i don't even know if it came out of a pickup. I will have to take pics of that once I find a tank and replace it. Only pics can describe how it's mounted. The good news, I know of someone that has a parts truck. Hopefully it will have the tank, a/c bracket and the parts to do a manual transmission swap. Even with the problems found today the truck is still a good deal at $600. Future upgrades,,, possibly will go with a weber carb, new intake and exhaust. I'm not sure if i will go with a 2.4 or just stick with the 2.0. Darrel Quote Link to comment
darrel Posted May 2, 2010 Author Report Share Posted May 2, 2010 Went to the yard today to pick up "stuff" I saw yesterday. Gas tank for the kingcab, one in must be from a short bed. It has a puncture from draining and a couple of dents from the loader they used to move the truck around, but very fixable. Manual tranny driveshaft for when I change to manual transmission. 2 spoke steering wheel from '79 longbed. shift lever, floor plate for manual tranny. And for my 240z, a set of miata seats in very good shape. All this for $100. Quote Link to comment
datzenmike Posted May 2, 2010 Report Share Posted May 2, 2010 Manual and auto use the same drive shaft. The carrier bearing seldom fails, never seen one or heard of one that was for sure the bearing, what does fail is the rubber 'donut' surrounding and supporting the driveshaft. If you got another drive shaft hopefully it has a good rubber in it. Quote Link to comment
darrel Posted May 2, 2010 Author Report Share Posted May 2, 2010 The rubber on the new one isn't great, but it's better than the nonexistent one in the truck right now. Doesn't the carrier bearing assembly come as a unit? Quote Link to comment
darrel Posted May 3, 2010 Author Report Share Posted May 3, 2010 Cleaned the outside of the tank. Got a look inside and it is really clean. Now I need to weld a bung where the yard drilled a hole and pull out the dents the loader put in the tank. Quote Link to comment
darrel Posted May 10, 2010 Author Report Share Posted May 10, 2010 Thanks to kenz240z on classiczcars I was able to pull the majority of the dents out of the tank. Harbor Freight stud guns rule. I am pleased with the results. Quote Link to comment
