My AE 86 build thread
Well i decided to post a little bit about my corolla since i prolly have it forever i figured i could use this as a build log and a project journal so here goes.
When i got the car it it was a broke down Sr5 which if anyone cares here are the specs as they came from the factory
SR5 specifications
Chassis Code: AE86
Horsepower: 87 hp (64 kW) @ 4800 rpm* Torque: 85 ft·lbf (115 N·m) @ 2800 rpm*
Weight: approximately 2200 lb (998 kg) to 2400 lb (1089 kg)
Engine: 4AC, 1587 cc
Engine Type: SOHC 8-valve Inline-4 Carburated
M/T Transmission: T50, 6-bolt flywheel
A/T Transmission: A42DL, 4-speed overdrive w/lockup torque converter, mechanically controlled, with electronically engaged overdrive
Compression: 9.0:1
Differential: 6.38" Open with 4.10:1 Ratio, 2-pinion (Automatic) (S292) or 3.91:1 Ratio, 4-pinion (5-speed) (S314)
Wheels/Tires: 13x5" +33 mm Offset Rims with 185/70-13 Tires
and here are some pics of it when it came home
ill have to get some :(
anyways paid 1200 bucks for it (this was 4 years ago now) and was happy as hell. Anyway i got it home and started to fix it. First look under the hood and i see this mess 20776090002_large.jpg
ill tell you what nothing will put your dick in the dirt faster than trying to fix a fucked up 4ac motor with 1 000 000 vacuum lines and no idea where to start. so thats when i decided it was time for a GT-S swap and here is a list of what that entails
Full motor/ wiring harness
Full front Chassis harness
Tranny swap (has a little better gearing and stronger internals)
Driveline Swap
Rear end Swap ( Upgrades you to a Lsd Capable pumpkin and rear disks )
Adding a electric fuel pump
Full swap of rear wiring harness
Full swap of under dash harness and gauge cluster
and here are stock GT-S specs
GT-S specifications
Chassis Code: AE86 (AE88 in USDM)
Horsepower: 112 hp (84 kW) @ 6600 rpm* Torque: 97 ft·lbf (132 N·m) @ 4800 rpm*
Engine: 4AGE, 1587 cc
Engine Type: DOHC 16-valve Inline-4 AFM Multiport Fuel Injection w/T-VIS
Transmission: T50, 8-bolt flywheel
Injector Size: approx. 180 cc, low impedance
Compression: 9.4:1
Differential: 6.7" Open (T282) or optional LSD (USA Only) (T283) with 4.30:1 Ratio, 2-pinion
Wheels/Tires: 14x5.5" +27 mm Offset Rims with 185/60-14 82H Tires (195/60-14 85H for 86+ models)
anyway so i started the long and very tiering search for all the parts needed and hear comes the gap in this project
and i eventually trade the car off
and then i trade back for it lol
at this point i have owned the car two times and probable towed it more miles than i have driven it lol. Then to top it off after i get it home it sits in the storage unit for another half year and i see the break i was looking for in the form of all the parts i needed in one location. here are the pics
a lovely complete GT-S :) all in one place for a great price thanks again brian
so now having all of the parts i needed it was a location to do the swap in that was giving me trouble...................
well my very rich uncle decided to let me use the garage in his 2nd house to do my swap so here is where it all happened
Thats me thinking Oh what the Fuck have i gotten myself into
both together before the teardown
have the head and all other parts off the SR5 motor getting ready to take the block out
with the block and tranny out getting ready to swap !
now to start the teardown
one of the harnesses
ECU
actually pulling the motor out
and now for the tricky part
i got that under dash harness good
my new rims !
starting to look like a running car again
and after 4 days of hard work we were all done ! i know i am missing a few pics but i will post them in a bit
drove to drews house to hang out
some random activities
lol
and some vids
i love doing brodies its an addiction lol
ill post some pics of how the car looks now tomorrow i think thats enough for today :)
  • Replies 22
 Rad. About two years ago I picked up an '85 coupe. It was an SR5 but had been completely swapped to GTS down to the gas tank. Got it for $1,150. Drove the crap out of it for awhile till I blew the motor. Parted it out and made a profit.
Win.
Initial D (said in a deep voice)
I've always wanted an AE86 but every kid in colorado wants a fortune for them. A few friends of mine found one in boulder owned by a guy in his 70's. They bugged him just about every day to sell it until it was shoved into his driveway by a tow truck with the entire pass side missing. That car was freakin perfect.
  • 4 weeks later...
  • 1 month later...
i already have a 20v swapped hatch and i like the coupes better
im with you on that one, unfortunatly, i traded my ae86 coupe (sr5 :() for my 510....... but i still got my ghia!!!! im going to bug-o-rama tomorrow morning at 6am!!!!!!!!! sweet car dude........
I've always loved those mid 80's rolla's. Not long ago, there was a guy in Yakima, WA selling 3 of them for 3k.
Can't the 85 and older RHD's be legally registered and imported to the US from Japan for being more than 25 years old??? Anybody know??
