Nissan_Boy85 Posted February 27, 2010 Report Share Posted February 27, 2010 Is there any good way to seal up the timing chain cover up? After my recent rebuild thats the only thing thats leaking/bad in general, except for the carb (needs adjustment, running way to rich). I used new paper-ish gaskets and its leaking. I got some new ones from Nissan that I can use if I need to. Tips/advice appricated. Quote Link to comment
datzenmike Posted February 27, 2010 Report Share Posted February 27, 2010 Leaking where? Sides? The top is the head gasket and the bottom is the oil pan gasket. Did you use a new front crank oil seal? Is it leaking from there and blowing back? Did you replace the oil pump gasket? Set TDC and loosen the front and a few side oil pan bolts and the 4 front 10mm bolts on the head. Remove water pump, the oil pump and dizzy drive spindle. Pull crank pulley. Slide forward and off the crank nose. If one of the side gaskets is leaking then the surfaces weren't clean or some crap got on there. Clean spotless!!! Use clean paper gaskets with a dab of RTV in the four corners where they meet the head and oil pan gaskets. If the oil pan gasket is torn, slice it off with a carpet knife and get a new gasket and trim to fit The dab of RTV in the corners will seal this. Quote Link to comment
Nissan_Boy85 Posted February 28, 2010 Author Report Share Posted February 28, 2010 Its either leaking from the top or the sides cause there's oil down the sides of the cover. I didn't do the RTV the last time though. I'm thinking tha this is my problem. Yes, theres a new oil pump gasket and front seal. Quote Link to comment
datzenmike Posted February 28, 2010 Report Share Posted February 28, 2010 I hate RTV but a dab in the corners is what's needed. Quote Link to comment
HRH Posted February 28, 2010 Report Share Posted February 28, 2010 I coat the entire upper surface with RTV on the L and Z front covers. You can always trim off the excess with a razor blade. Make sure you trim any excess off the inside as well! Don't want bits of silicone in the oil. Quote Link to comment
MAG58 Posted February 28, 2010 Report Share Posted February 28, 2010 I always use a thin layer of Hylomar or Permatex Aviation. Both are used by the VW guys a bunch for case sealing. I like Hylomar because it isn't water or gasoline soluble and was origionally designed by RR for sealing up jet engines. You can get a tube of the stuff at pep boys, and you can probably seal half of the vehicles in your block water tight with it. I have yet to have a leak using the stuff. But be forwarned. Once it's there, it's there. There is no moving the thing around if you forget something and have to take the cover off. Unless of course you have another set of gaskets. Quote Link to comment
banzai510(hainz) Posted March 1, 2010 Report Share Posted March 1, 2010 watch this http://www.guba.com/general/search?query=hainz&set=5&x=0&y=0 hope its not porno. Quote Link to comment
datzenmike Posted March 1, 2010 Report Share Posted March 1, 2010 .... wish it was... Quote Link to comment
hang_510 Posted March 1, 2010 Report Share Posted March 1, 2010 hope its not porno. its you and the 2 fat samoan ladies again isnt it??? all slathered in silicone... <_< Quote Link to comment
Nissan_Boy85 Posted March 2, 2010 Author Report Share Posted March 2, 2010 Hey hey hey, just cause I kinda started the Post-Tits thread doesn't mean that you can turn this one into one too... Quote Link to comment
hang_510 Posted March 2, 2010 Report Share Posted March 2, 2010 :o i dint ask for pix!!! :huh: and i mentioned silicone... Quote Link to comment
Nissan_Boy85 Posted February 5, 2011 Author Report Share Posted February 5, 2011 Figured I should revive a old thread I did consearning the same thing. Is it possible to remove the timing cover without removing the oil pump/dizzy? Quote Link to comment
datzenmike Posted February 5, 2011 Report Share Posted February 5, 2011 Y--e--s, but it will pull the drive gear and oil slinger off the crank with it. That's if they will slide off the woodruff keys. Good luck getting it back on in the same timing position. Much better and easier in the long run to dismantle properly. Quote Link to comment
hang_510 Posted February 5, 2011 Report Share Posted February 5, 2011 isnt there a cover bolt behind the pump? Quote Link to comment
datzenmike Posted February 5, 2011 Report Share Posted February 5, 2011 Yup there definitely is. Quote Link to comment
Nissan_Boy85 Posted February 27, 2011 Author Report Share Posted February 27, 2011 Ok, I feel retarded for asking but do I need to RTV the corners of where the 3 pieces meet (block, cover, pan)? Same with the top end (block, cover, head)? Quote Link to comment
Sealik Posted February 27, 2011 Report Share Posted February 27, 2011 Ok, I feel retarded for asking but do I need to RTV the corners of where the 3 pieces meet (block, cover, pan)? Same with the top end (block, cover, head)? Yes Quote Link to comment
