maximo Posted January 20, 2010 Report Share Posted January 20, 2010 I was just wondering what do you guys use to clean your engine parts, to get rid of all the oil. I've notice that when people put parts for sale on this forum they are super clean, do you guys use a sandblaster??? Quote Link to comment
Hi-Definition521PU Posted January 20, 2010 Report Share Posted January 20, 2010 Steam? Quote Link to comment
Skib Posted January 20, 2010 Report Share Posted January 20, 2010 I was just wondering what do you guys use to clean your engine parts, to get rid of all the oil. I've notice that when people put parts for sale on this forum they are super clean, do you guys use a sandblaster??? I usually use some really nasty cleaners :P break cleaner dose wonders on engine block grease, other than that just lots of rags, scrub pads, and elbow grease. you can also give this a try.... http://community.ratsun.net/topic/18455-how-to-build-a-cheap-soda-blaster/ Quote Link to comment
Guest kamakazi620 Posted January 20, 2010 Report Share Posted January 20, 2010 Foamy Engine Brite!!! spray it on let it sit (it's kerosene in a can) for a good 15 mins then spray it off with some water,works wonders Quote Link to comment
izzo Posted January 20, 2010 Report Share Posted January 20, 2010 Exactly! All of the above. Actually what i do is put the block and head in the back of my truck on a tire, head down to the local car wash and then power wash the block. Come straight home and wipe the inside out to try and prevent any rust or flash rust. Then SOS pads on the outside, or engine bright, or hot water + dawn dish soap and a scotch bright dish scrub pad do wonders also. On smaller pieces i just use brake cleaner and a rag or again a bucket of warm/hot water and dawn dish soap. Another thing that works great is oven cleaner. On aluminum pieces you cant let it sit for more than a minute maybe two tops then wash off. But it works great on the block also. Quote Link to comment
72240z Posted January 20, 2010 Report Share Posted January 20, 2010 I use high test gasoline, power purple(both weed and soap lol), dish soap, media blaster i.e. soda, nut shell, sand...., brake clean, carb cleaner, thinner, wire wheels, wire brushes, tooth brushes...... God I'm tired of cleaning parts lol. Quote Link to comment
DanielC Posted January 20, 2010 Report Share Posted January 20, 2010 Basically it boils down to nasty caustic chemicals, or hard work. I also use a pressure washer, and try to clean up as much as I can before I start. Example, pressure wash the engine bay before even pulling the engine out. Pressure wash the engine again, after removal. I also have a tub type parts washer, with paint thinner in it. Yes, it is flammable, be careful. I also use carburettor cleaner on smaller parts. but it still gets down to hard, dirty work. Quote Link to comment
datsunaholic Posted January 20, 2010 Report Share Posted January 20, 2010 I have a solvent tank with a thru-brush solvent supply. But it doesn't clean anything bigger than a 4-cyl head. I mostly use that for internal parts. Brake cleaner works wonders too. Quote Link to comment
bonvo Posted January 20, 2010 Report Share Posted January 20, 2010 foamy engine bright with a preassure washer then brake clean the beautiful thing is that once its cleaned sealed and painted you dont hvae to worry about leaks making it dirty and once its painted any leaks are easy to spot Quote Link to comment
exit64 Posted January 20, 2010 Report Share Posted January 20, 2010 Awesome Orange from the dollar store is about the best biodegradable stuff that I have come across yet. Just don't get it on your paint job. Quote Link to comment
DRIVEN Posted January 21, 2010 Report Share Posted January 21, 2010 Gumout made a degreaser called STEAM that was twice as good as Engine Brite. Three times better if the engine was warm. I haven't been able to find it lately. Not sure if they even still make it. Probably not -- anything that works good is probably gonna be outlawed. Quote Link to comment
