B210 Transmissions
I have the two '78 B210's.I have a 4 speed,& a 5 speed,
both out of the cars & on the ground.Which one should I put back
in?I have a brand new driveshaft for the 4 speed.
What's a 5 speed worth?Is it interchangable with the 210
5 speed?What's the differance?
- Doug
  • Replies 12
Confused.
You have two '78 B-210 with their 4 and 5 speeds out on the ground?
You want to know which one to put back in another car??? A 210???
They are all A series bell housing and as long as they are all the same length put in whichever one you want.
I think the later 210 5 speed came in dogleg and regular pattern and were FS5W60 L or A. The B-210 used the heavier duty FS5W63A 5speed same as the 200sx but with the A series bolt pattern. As I said, if the B-210 trannys are the same length as the 210 tranny it should fit.
ggzilla knows this stuff better.
When my 5 speed took a dump I put in the 4 speed. Fit the same even the drive shaft. Eventually I'll rebuild the 5 speed. It is worth a lot more just because of the MG and Austin Sprite guys using them. There's a kit for them that's been on the market a while.
Rivergate is what that kit is, and i would seriously think about selling that 5 speed to an mg/austin healey guy for good money. My brother has a t5 tranny with the adapter for his mbg (he paid more for that than i did for my whole Datsun roadster) Those british loving car guy's must have deep pockets to enjoy their habit.
The Rivergate adaptation uses the 210 5 speed,not the B210.
The B210 4,& 5 speed driveshafts are differant (the 5 speed one-
is about 1/4" larger diameter.
I've decided to go with the 5 speed.That means I'll have 1-2
extra 4 speed transmissions to sell (+ the parts cars).What to do,
what to do?
- Doug
There is almost zero market for B210 four-speeds. If you find someone that needs one $50 seems about right. But you probably won't find a buyer.
Agreed 100% ggzilla , +1 :) , unless you cruise certain keyword on the internet then shipping gets involved :rolleyes: , eeeeekkkkkk best a local sale ;)
what to do?
- Doug
My bad :blush: Must have skipped over the letter B.
