SRSANDS Posted January 4, 2010 Report Share Posted January 4, 2010 Today I started researching how to wire the vw temp sensor thats in my radiator to a relay and my new fan. After researching for hours I still didnt come up with much as far as the schematic on the sensor. I did learn the RED wire on the sensor is common and the other two are two different degrees, RED/WHITE is 203deg and RED/YELLOW is 221 degrees (for a two speed fan). But I friggin just stare at the components and are dumb founded on how it all goes together. I wired my headlights all up using relays and it worked perfect but now Im stuck. My plan is to use temp switch on the ground side of the fan. That is as far as I could get. Could any wire gurus lend a hand so I can get this small job done. Thanks in advance...and dont tell me to use the search button :) If I dont need a relay then its simple....fused power to the positive fan wire, ground from fan to one of the wires (not what degree to use) then common from the switch to ground or visa versa on he switch fan ground to common on switch and from degree wire to ground eh? I think im just looking to far into this. Quote Link to comment
DanielC Posted January 4, 2010 Report Share Posted January 4, 2010 This is how I would do it. I am assuming the VW temp sensor has power go in the red wire, and at some temp, passes that power to one of the other two wires, and if it gets even hotter, it connects the other red/yellow or red/white wire. Power from the ignition switch goes to the red wire on the temp sensor. Red/yellow temp sensor wire goes to terminal 86 on the relay. Terminal 85 on the relay goes to a good ground. This makes the relay go on and off. You need to make sure the body of the temp sensor does not have 12 volts on it. At this point, you can turn the key on, and listen for the relay to click. It should not. Gently heat the temp sensor by using a match, light bulb, or a lighter. Do not use a blow torch, it could quickly get hot enough to destroy it. You could also find out which wire is the higher temp wire, with a little experimenting. From the positive side on the battery, put an inline fuse. Then go the the positive side of the fan. From the negative side of the fan motor, go to pin 30 of the relay. Ground pin 87 of the relay. Use a heavy gauge wire for the fan motor, all the way from the positive battery terminal, through the fuse, the motor, and the relay and to ground. Quote Link to comment
yello620 Posted January 4, 2010 Report Share Posted January 4, 2010 30 on relay-battery power 87 on relay to fan positive, fan negative to ground. 85 on relay to temp switch output(wichever degree setting you prefer) 86 on relay to keyed power, battery power if you want them to run after you shut motor off. red wire on sender to ground. This should allow the switch to create the ground for the relay at your temp setting. Grounding the relay should turn the fan on. You could also wire a swich in to create the ground so that you could turn the fan on anytime you want to. Quote Link to comment
SRSANDS Posted January 4, 2010 Author Report Share Posted January 4, 2010 Thank you for the knowledge.....I will give it a shot :) Quote Link to comment
yello620 Posted January 4, 2010 Report Share Posted January 4, 2010 updated previous post a little. Left out the need for fuses. Quote Link to comment
DanielC Posted January 4, 2010 Report Share Posted January 4, 2010 Here is my quick and very dirty addition to your drawing. Quote Link to comment
johny5 Posted January 4, 2010 Report Share Posted January 4, 2010 I dont think the switch needs a relay ,Im sure it wont hurt, Im almost positive they dont have any type of relay in the VW , I ran this same switch ( from a jetta ) with out any relay no problem Quote Link to comment
yello620 Posted January 4, 2010 Report Share Posted January 4, 2010 Here is my quick and very dirty addition to your drawing. This is an interesting way to wire a relay, i dont ever remember seeing it done that way. Yet, i dont see a reason it would not work, maybe even work really well because the battery power is going straight to the fan, not even through the relay, then fan. Quote Link to comment
Unclejesse88 Posted January 5, 2010 Report Share Posted January 5, 2010 This is an interesting way to wire a relay, i dont ever remember seeing it done that way. Yet, i dont see a reason it would not work, maybe even work really well because the battery power is going straight to the fan, not even through the relay, then fan. All he is doing is using the relay to switch ground instead of positive. Either way works. Quote Link to comment
DISLEXICDIME Posted January 5, 2010 Report Share Posted January 5, 2010 All he is doing is using the relay to switch ground instead of positive. Either way works. a vw runs hotter then a l series watch out for your head gasket Quote Link to comment
72wagun Posted January 5, 2010 Report Share Posted January 5, 2010 I dont think the switch needs a relay ,Im sure it wont hurt, Im almost positive they dont have any type of relay in the VW , I ran this same switch ( from a jetta ) with out any relay no problem You're right. You don't have to have the relay, but it's not a bad idea. My dad had a Rabbit for years. It didn't have a relay from the factory. After replacing the temperature activated switch several times he wired in a relay. He never needed to replace the switch or relay after that. Quote Link to comment
SRSANDS Posted January 5, 2010 Author Report Share Posted January 5, 2010 a vw runs hotter then a l series watch out for your head gasket Im working on a VG install, all the nic nac crap takes alot of work. Not sure what temp a VG runs at but I will check into it akso...thanks, and thanks for the info and diagram.....off to the garage I go Quote Link to comment
DanielC Posted January 5, 2010 Report Share Posted January 5, 2010 I figured since he had a 510, he was used to the relay switching the grounds, like the headlights. Besides, doing it that way, for the ground wires, you need just a short jump from pins 85, and 87 to ground, maybe with the same screw that mounts the relay. It is not that my way is better or worst, it is just one way of doing it. There are many other equally good options. Quote Link to comment
qwik510 Posted January 9, 2010 Report Share Posted January 9, 2010 Im working on a VG install, all the nic nac crap takes alot of work. Not sure what temp a VG runs at but I will check into it akso...thanks, and thanks for the info and diagram.....off to the garage I go Did you find out what temp the VW switch turns on at? Quote Link to comment
SRSANDS Posted January 12, 2010 Author Report Share Posted January 12, 2010 Ya it turns on the fan at 203 degrees....I hope thats a safe point to do so :) What you think? Quote Link to comment
paradoxx Posted January 12, 2010 Report Share Posted January 12, 2010 I think that will do.....but isnt better a 195°?.....I know VW engines run hot but im just guessing.. Quote Link to comment
fo0manchu Posted January 29, 2010 Report Share Posted January 29, 2010 I've always known nissan engines to turn on at 180. At least thats when most of their thermostats crack open. I would want mine to turn on a little bit before the thermostat opens, that way the temps should stay pretty constant. Quote Link to comment
SRSANDS Posted January 29, 2010 Author Report Share Posted January 29, 2010 Ya I am a little worried about that too....I guess I will will find out how it does once the beast is alive and then swap it out for a s12 one if I need to Quote Link to comment
SRSANDS Posted January 30, 2010 Author Report Share Posted January 30, 2010 Researched and learned the vr6 switch kicks on at 190 degrees......gonna go grab one Quote Link to comment
260zkaboom Posted February 9, 2010 Report Share Posted February 9, 2010 It looks like the connection to the temp switch should be to the red with white, so the fan to come on earlier instead of red with yellow which is closer to over-heating Quote Link to comment
bonvo Posted March 3, 2010 Report Share Posted March 3, 2010 read the write up on the rabbit radiator install and it has a partnumber for a 180 degree switch Quote Link to comment
SRSANDS Posted March 27, 2010 Author Report Share Posted March 27, 2010 Read the write up for the rabbit rad and tell me the part number would ya!? JK......where is this write up you speak of and I will read it Quote Link to comment
