skunk Posted November 16, 2009 Report Share Posted November 16, 2009 :confused::blink::(so i was just out side test fiting my new wheels on my truck to see how much they were going to stick out and well, the bolts are not long enought the thread the lugs on. how do i fix this? can i fix this?:confused::confused::confused: Quote Link to comment
datto510 Posted November 16, 2009 Report Share Posted November 16, 2009 What wheels do you have? You could machine the face of the wheel or get longer wheel studs, depending on the wheel. Quote Link to comment
izzo Posted November 16, 2009 Report Share Posted November 16, 2009 get some longer wheel studs? :D Quote Link to comment
skunk Posted November 16, 2009 Author Report Share Posted November 16, 2009 (edited) i just had got them back from powder coating so id rather not grind anything on the wheels there made by western, there 15x8.5, the holes for the studs on the wheel seem biger then the studs on my truck, or is it ment to have a little wiggel? how hard is it to change the wheel studs? Edited November 16, 2009 by skunktruckin Quote Link to comment
datto510 Posted November 16, 2009 Report Share Posted November 16, 2009 i just had got them back from powder coating so id rather not grind anything on the wheelsthere made by western, there 15x8.5 Those are cool wheels! If the mounting face of the wheel is making good contact you could get longer wheel studs to solve your problem. Its a minor pain in the ass swapping them out. Quote Link to comment
yellowdatsun Posted November 16, 2009 Report Share Posted November 16, 2009 Yeh, looks like you need longer studs, as opposed to the shouldered type lug nuts. Changing out studs isn't necessarily difficult, but it'll take you a few hours at least to do all the wheels. Quote Link to comment
yello620 Posted November 16, 2009 Report Share Posted November 16, 2009 Those old Western wheels will most likely need shouldered mag style lug nuts. That is why the hole in the wheel seems much larger than the wheel studs. http://www.excaliburwheel.com/magnut.html Something like these. I have never done business with them either, they were the first ones in a google search. Go visit you local tire store, bring a wheel with you. You wheel studs are 12 x1.25mm threads. Quote Link to comment
skunk Posted November 16, 2009 Author Report Share Posted November 16, 2009 so if i got thos lugs i wouldnt have to change the studs? because that would be way better :D:D thanks for the fast replys guys, Quote Link to comment
datsunaholic Posted November 16, 2009 Report Share Posted November 16, 2009 I have a couple sets of similar wheels- they need shouldered lugnuts, and those should work fine with the existing studs. You cannot use tapered or acorn nuts on those, they'd never be tight and would destroy the wheels. But the shouldered lugnuts aren't cheap, and I had a heck of a time finding enough for my truck (I had many, but the wrong thread). Need 6 sets (they come in packs of 4), and no one store had more than 2 sets. Quote Link to comment
Braden Posted November 16, 2009 Report Share Posted November 16, 2009 go to the parts house with your wheels and one of your studs, tell them you need some stud that are ? long but the same diameter and thread pitch, if they carry dorman studs they should def be able to help you out, also match up your lugs to your wheels, they should be able to help you with that also Quote Link to comment
nukeday Posted November 16, 2009 Report Share Posted November 16, 2009 Your studs are probably fine, you need a different style lug nut, as these guys have mentioned... I have a couple sets of similar wheels- they need shouldered lugnuts, and those should work fine with the existing studs. You cannot use tapered or acorn nuts on those, they'd never be tight and would destroy the wheels. Those old Western wheels will most likely need shouldered mag style lug nuts. That is why the hole in the wheel seems much larger than the wheel studs. You wheel studs are 12 x1.25mm threads. Give these guys a call, their prices are much better than a tire shop, and they have lug nuts by the barrel... Eugene Fastener 595 Wilson St Eugene, OR 97402-2641 (541) 342-5978 Quote Link to comment
denveratsun Posted November 16, 2009 Report Share Posted November 16, 2009 Yeah...like they said.:cool: Quote Link to comment
HRH Posted November 17, 2009 Report Share Posted November 17, 2009 NAPA has shouldered lugnuts for mag wheels. Easy to find. Almost remember the part number but not quite. Any Les Schwab's will have them. If you need to bigger shank kind, try the local pull and save and rob them from a Nissan/Datsun with mag rims. There are other versions that need even bigger shims, in which case you have a machined seat separate from the wheel and then the mag lug on top of that. Quote Link to comment
sfsoccerstud510 Posted November 17, 2009 Report Share Posted November 17, 2009 I too have these mag slot lug nuts. I have some locks for the wheels too, but they BARELY have any threads to grip :/ Quote Link to comment
lynchfourtwenty Posted November 17, 2009 Report Share Posted November 17, 2009 they're called acorn lug nut, thats what i got.. Quote Link to comment
yello620 Posted November 17, 2009 Report Share Posted November 17, 2009 they're called acorn lug nut, thats what i got.. Acorn lugnuts is not correct for this wheel though. Quote Link to comment
lynchfourtwenty Posted November 17, 2009 Report Share Posted November 17, 2009 Acorn lugnuts is not correct for this wheel though. really? looks like it... im not a fan of those sunk in style lug nuts.. they can be a pita :lol: Quote Link to comment
HRH Posted November 18, 2009 Report Share Posted November 18, 2009 Acorns are an angled seat. Mag lug nuts are a flat seat. Completely different. Quote Link to comment
skunk Posted November 18, 2009 Author Report Share Posted November 18, 2009 i couldnt even try useing a acorn lug nut, the studs dont even stick out of the wheel. there flush with the face of the wheel Quote Link to comment
