Eagle_Adam Posted May 2, 2013 Report Share Posted May 2, 2013 Head gasket is perfect Quote Link to comment
Eagle_Adam Posted May 2, 2013 Report Share Posted May 2, 2013 Atleast 3 of the 4 pistons have a shiny crescent moon shape in em Quote Link to comment
Eagle_Adam Posted May 2, 2013 Report Share Posted May 2, 2013 You can see it on the right Quote Link to comment
MicroMachinery Posted May 2, 2013 Report Share Posted May 2, 2013 Chain slip out of time? Do the valves have flat spots on em? Quote Link to comment
Eagle_Adam Posted May 2, 2013 Report Share Posted May 2, 2013 Cam timing was good, all the lash pads are present, cam sprocket dowel present and intact, the only thing I didn't change when I rebuilt the motor was rings and lower end bearings.... I still wanna know what happened cus I can't stand not knowing, but a new bottom end will be assembled by the machinist this week. Quote Link to comment
MicroMachinery Posted May 2, 2013 Report Share Posted May 2, 2013 This is gonna bug me until you find out what happened.. Quote Link to comment
Eagle_Adam Posted May 2, 2013 Report Share Posted May 2, 2013 Me too, if you wanna look at it ur welcome anytime. The valves looked ok to me but I didn't notice the mark in the pistons till I was on my way out... Ill look again tomorrow Quote Link to comment
MicroMachinery Posted May 2, 2013 Report Share Posted May 2, 2013 If I find myself up in your neck of the woods in the next few evenings, I'll drop in and take a look. Interesting situation.. Quote Link to comment
Eagle_Adam Posted May 3, 2013 Report Share Posted May 3, 2013 still havnt looked at the head, but i will..... IN OTHER NEW!!!!! NEW AND SHINY!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! New L20 bottom end board out to fit Z car flat tops!!!! 3 Quote Link to comment
Eagle_Adam Posted May 3, 2013 Report Share Posted May 3, 2013 Z car flat tops!!! Also gunna do Dmikes 01 altima IR alt upgrade go big or go home right? Im doing both :D 2 Quote Link to comment
Draynor Posted May 3, 2013 Report Share Posted May 3, 2013 Man that sucks :hmm:. Good luck with this next one, Gonna be awesome! B) Quote Link to comment
Eagle_Adam Posted May 3, 2013 Report Share Posted May 3, 2013 its gunna be bad ass when im done, no holds barred this time around!! Quote Link to comment
Draynor Posted May 3, 2013 Report Share Posted May 3, 2013 Yeah it will. SU's going on this time? Quote Link to comment
Eagle_Adam Posted May 3, 2013 Report Share Posted May 3, 2013 YEP!!! gunna need em to feed this beast :D Quote Link to comment
Draynor Posted May 3, 2013 Report Share Posted May 3, 2013 :thumbup: Might have to swap the manual now that it will have moar power ;) :D Quote Link to comment
Eagle_Adam Posted May 3, 2013 Report Share Posted May 3, 2013 for now its gunna have to wait Quote Link to comment
Laecaon Posted May 4, 2013 Report Share Posted May 4, 2013 Wait, im scared about flat tops in a L20... With an open head, you are at almost 10.1:1 CR. And will ping with Premium. With a Closed head, you are at 10.8:1 CR. Pinging characteristics will be different, as closed chambers dont ping as much (quench area), but this is still silly high compression. Quote Link to comment
MicroMachinery Posted May 4, 2013 Report Share Posted May 4, 2013 im scared Doesn't sound like Adam is :devil: 1 Quote Link to comment
Eagle_Adam Posted May 4, 2013 Report Share Posted May 4, 2013 too late, i dropped everything off at the machinist im not too worried and you dont know till you try! guess we will find out :D 1 Quote Link to comment
Eagle_Adam Posted May 4, 2013 Report Share Posted May 4, 2013 also picked up studs for the cylinder head which also got dropped off at the machinist for a full refresh :) Quote Link to comment
izzo Posted May 4, 2013 Report Share Posted May 4, 2013 This is an A motor, but you get the point... Quote Link to comment
Eagle_Adam Posted May 4, 2013 Report Share Posted May 4, 2013 Showed that to jessi and it was all grins and tahehehe's :D Quote Link to comment
Eagle_Adam Posted May 4, 2013 Report Share Posted May 4, 2013 Ordered all new calipers, rotors, pads, and hardware for the front breaks! If I can get as much done as I'm hopping on my truck ill be able to get these on the wagon this weekend. Quote Link to comment
Eagle_Adam Posted May 4, 2013 Report Share Posted May 4, 2013 The motor will come back next week sometime so I'd like to have everything else wrapped up by then. On the list: IR alt swap - need to wire it Pull what's left of the motor and trans Put on the new front breaks Clean all the parts that are going on the new motor And what ever else I'm forgetting Quote Link to comment
