It really is an infection...Datsunitis
got the trans back up in the wagon lastnight, i only got a couple hours to wrench so that's all that was done
waiting on the new filter and pan gasket to come in today, got a new seal put in the rear of the trans as well last night, and the Governor/modulator (no clue what the proper name is) got replaced because it was pulling ATM thru it and thru the vacuum line thats attached and into the engine which i believe was part of the wagons smoking issue. If you drove behind it your could see and smell the smoke and it was not oil smoke.....
So im hoping with all this done i can properly diagnose the motor when i get a chance.
  • Replies 1.5k
waiting on the correct trans filter and pan gasket, still gottta install the break master, bleed the system, and install the newest rad.
Got the valves adjusted this weekend, they were all way too tight! driveline is back in, exhaust is back in, idler arm bushings have been replaced and the new idler arm is installed.
Almost there.......
I think
break master is back in! finally!!!!!!! MAUAHAHAHHAHAHAHAHAHAHAHHAHAHAHAHAHA FUCK YA!!!!
that thing has been the biggest PIA ive delt with on a datsun so far, not that its hard to fix just chasing correct working parts and shit.....
gettn the valves done with Nismo Dr
picked up some 610 rad hoses cus the 710 ones dont work with the new rad, and put the trans filter and pan back in. We got distracted last night, my dad bought monks old 620
so, up next is;
bleed the brake system
mount the new rad
plumb the rad
fill the anifreeze
fill the oil
fill the ATF
and drive this SOB!!!!!!!!
the spacer plates for the carb were both loose and the carb was loose, so it was off with the carb
Jassifrass took it in for an alinement this morning!!! drove GREAT! ran strong, completely different car!!!!!! the motor sounds like butter now and 75% of the smoking has subsided!!!! All in all it was a win!!!
BUT
Since so many vacuum leaks had been fixed the carb was running WAY rich, so jassifrass took it over to Nismo Dr for a quick tune before we take it to my carb guy for a real dialing in on Wednesday
I really couldn't have done any of this without you guys, especially Adam :) thank you to everyone that helped!!!
Your welcome Jessi, im happy to see your wagon finally getting some much much much needed love :D
And I know I don't post much anymore but I took lots of those pictures :)
but you did more than just take photos and you know it ;)
So i started to think about it and we did A LOT
exhaust from the non existant cat back
new flex plate
rear shocks
fan belt
stabalizer bar end links and frame bushings
front rotors
front pads
front break hoses
front brake hardware
front wheel bearrings and seals
new speedo cable
Radius rod arms got new bushings too
rear wheel bearrings and seals
rear break shoes, springs, and general cleaning/lube
new rear drums
fixed the ebrake so it works
sealed the windsheild so it doesnt leak anymore
added ipod controlls to the stereo - no more fucking CD's
added a new package tray
added soem decals and stickers - Goon squad for life yo!
took out the mailbox ignition and put in a stock ignition and matching lock set
fixed the horn so it works
new break master cylinder
new heater core hoses
new foam on the heater sore
new radiator
painted the new valve cover
new radiator hoses
new starter
new radiator cap
added the hazard relay so the emergency flashers work
tossed on some amber high beams
painted the grill
shined the grill and windsheild trim
replaced the idler arm and its bushings
replaced the hood bumpers
picked up a cool as ratsun oil cap and a grill badge
new inner door handles so you an actually get out when you want to
retorqued the head bolts'
valve adjustment
new thermostat
rust repair on countless spots
put in new window chanel fet on the drivers door
cleaned and shined the rocker pannel trip and acquired new clips so they arent flapping around anymore
removes tar like substance from the rockers and lower portion or the wagon
replaced the rear main seal
replaced the rear seal on the trans
trans got flushed
tightened down the carb and spacer plates along with a quick carb adjustment from nismo DR
and thats just what i can remember :D
and to think, this all started because the breaks sucked
thank you! it really needed the love, now it needs new floors welded in (which i have found), new wheels for the summer that will clear bigger breaks(still looking cus you stole the snoflakes :P ), new seats. THEN it can haz more lower and new discs :D
